How to lower speed that cuts out EV mode?
Discussion in 'Prius v Main Forum' started by Adam H, Jul 7, 2025 at 6:14 PM.
  1. Adam H
    Adam H Junior Member
    62
    Is there a way to lower the speed at which the EV is disabled? I would like less EV mode when driving to preserve the hybrid battery. Right now my 2012 Prius V may turn off the ICE below 43 mph. I would like to lower that to say 25 mph.
  2. PriusCamper
    PriusCamper Senior Member
    12,030
    4,888
    Pacific Northwest, USA
    It's all about gaining read & write access to the firmware code... Toyota has kept it locked down better than most. If we were talking about Honda, there would be lots of interesting ways to access and modify code but Toyota is entirely awful when it comes to collaboration because they think it would interfere with their profits on many different levels.
    Basically when it comes to Toyota your best option is spoofing, which means if you can make the computer think you're going 43mph when you're actually going 25mph you can get the result you want. But as you might imagine, that probably is going to cause other problems elsewhere in the system and you'll have to spoof to resolve those problems too. Basically just about any change you try to make is gonna create warning lights and related system shut down.
    As far as I know the only people who have been successful is TRD, which once converted a Gen2 to run on a bigger electrical motor, but because they are an extension of Toyota, they had access to rewriting the code.
  3. bisco
    51,119
    just put it in power mode
