Overheat and coolant loss from reservoir, how to tell if water pump or head gasket
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by QuinnVee, Jul 7, 2025 at 7:23 PM.
  1. QuinnVee
    QuinnVee New Member
    Monday
    Tucson, Az
    Hi there!
    A few weeks ago my 2012 prius (105k miles) overheated, while highway driving for a few hours in the 110 heat. I slowed down and the overheat light went away but the check engine light was on. The codes were po117 and p148f and there was spilled coolant on the reservoir. I refilled the coolant and it hasn't noticeably lowered but I have found marks in my driveway. I've had to drive it around town the last few weeks and it hasn't thrown anymore codes or overheated.
    I brought it to the dealership to see what they'd say and they recommended replacing the water pump and thermostat because of the codes and the spilled coolant around the reservoir.
    I'm planning on replacing the pump and thermostat myself ( and maybe cleaning the egr while I'm in there). Before I do so I want to find out if there are head gasket problems. What should I be looking for/ what tests should I be running. Torque shows no misfires on start up and the oil on the dipstick looks regular to me. I am fairly new to car stuff so any advice is wanted.
    Thanks!
  2. NutzAboutBolts
    NutzAboutBolts Senior Member
    1,601
    1,689
    Bay Area
    If it’s your headgasket, you can remove the spark plugs and put a borescope down there to see if the pistons top is wet or not. Also, you should have a leak in the coolant reservoir if it’s the HG
  3. T1 Terry
    T1 Terry Active Member
    731
    398
    Get a gas test on the coolant, if there is combustion gasses in the coolant, it's a head gasket, if not, put cardboard down under the engine and check in the morning just where the coolant leak is dripping from .... you might need to remove the plastic tray under the engine (if it still has one) and redo the drip test a few times to isolate where the problem leak is .... the water pump leak will appear at the fan belt end of the motor, easy enough to replace, unlike the gen 2, Google Search
    themzlab likes this.
  4. ASRDogman
    ASRDogman Senior Member
    7,225
    3,772
    That test doesn't work on the Prius because it's the coolant that leaks into the cylinders.
    Unless it's REALLY bad, but by then you won't need that test, you'll KNOW it's the head gasket
    and likely a warped head.
    There is no pulley on the Prius coolant pump.
    Brian1954 likes this.
  5. Brian1954
    Brian1954 Senior Member
    1,789
    704
    South Central PA, USA
    I agree with the dealership that you need to replace the engine water pump before you drive the car again. An OEM pump is preferred. Do not buy a cheap aftermarket pump on Amazon or eBay. They do not last very long, and you will end up having to replace it again.
    If you have a bad head gasket, you would get misfires (rattling) during cold startup of the engine. I do not think that you presently have a head gasket issue. The P0117 code indicates that the engine severely overheated. This can lead to the head gasket going bad 6 to 12 months from now.
    So, replace the water pump ASAP and consider a replacement car in 6 to 12 months if you do not want to deal with a bad head gasket.
    QuinnVee, NutzAboutBolts and BiomedO1 like this.
  6. Mendel Leisk
    40,569
    Considering water pump failure reports here, it's prudent replace the engine water pump and associated thermostat at 100K miles.
    The inverter water pump I think is similar construction? Likely best to replace that before long as well. To argue against replacement at the same interval: perhaps it's not used as much, or for some reason just lasts better. There don't seem to a lot of failures, at least not reported here. Also, it's a sandpounder to access.
    BTW: with over 100k miles, I'd do a full EGR system cleaning ASAP, see top two links in my signature. (on a phone turn it landscape to see signatures)
    QuinnVee likes this.
  7. BiomedO1
    2,801
    1,488
    SacTown, Ca
    FWIW: severe overheats can cause leaks in the seams of your plastic coolant overflow bottle. Your engines' normal operating temperature range is around 190F-215F and that overtemp. lamp goes off around 245F. You've overheated for a while to throw a P0117 - long enough for your ECU to think there was a temperature sensor issue.
  8. rjparker
    9,584
    5,885
    This is one of those times you do it now. You are close to having to replace the engine. Change the water pump with oem now.
    QuinnVee and BiomedO1 like this.
  9. QuinnVee
    QuinnVee New Member
    Monday
    Tucson, Az
    Thanks everyone, I won't be driving the car until I change the pump.
    From what I've found Aisin is oem for Toyota. Is there any reason to buy a toyota branded one from the dealership over an Aisin one from RockAuto? (My account is too new to post links, sorry)
  10. QuinnVee
    QuinnVee New Member
    Monday
    Tucson, Az
    Actually nvm, I'll get it from Toyota as it's only a little more expensive.
  11. themzlab
    themzlab Junior Member
    26
    Wisconsin USA
    This test worked on my HG leak. if coolant leaks into the cylinders it stands to reason gases will leak the other direction. The hole goes both ways. If the test is negative it doesn't prove your H.G is ok but it is a good test because it is simple and cheap. I know what others say about this but my leak was a minor situation and this gas test worked.
  12. Mendel Leisk
    40,569
    #12 Mendel Leisk, Jul 9, 2025 at 3:21 PM
  13. ASRDogman
    7,225
    3,772
    99% of rockauto is chinese junk. If you buy it from Toyota, you know you are getting oem.
    How much is the price of a new engine, and labor, that seizes because the chinese copy coolant
    pump fails? Plus, leaving you stranded somewhere?
  14. NutzAboutBolts
    1,601
    1,689
    Bay Area
    I bought my aisin water pump on Amazon for 148$ with 7$ discounted coupon. It’s been working fine.
  15. Mendel Leisk
    40,569
    For me, the Aisin WPT 190 through Amayama is $131~132 USD (at current exchange rate), all-in. I’ve purchased 5~6 items from them, including oil filter conversion items, nary a problem.
  16. ASRDogman
    7,225
    3,772
    Ohh, so you are the "one"! (y):whistle::whistle:
    Just remember, even a broken clock is correct twice a day...
