Panel Under Door Sill Squeaking
Discussion in 'Gen 5 Prius Main Forum' started by daisy555, Jul 11, 2025.
  1. daisy555
    daisy555 Senior Member
    1,682
    694
    CT
    Just curious if anyone else has this issue. I was reaching in to grab a bag on the floor and my shin gently touched the door sill. I heard a high pitched squeaking that startled me. It’s actually the panel along both front and back doors that squeaks. Any ideas? Fortunately it’s not happening when I’m driving. Maybe a clamp is loose. Thanks
    https://youtube.com/shorts/PISmRc6fXHE?si=vQ53RiJ74mp6Nz1e
    #1 daisy555, Jul 11, 2025
  2. Trollbait
    12,379
    Is it repeatable? In just the one spot?
    Could be you just happened to move it in a way not planned for and doesn't happen outside you doing what you did. Unless you start using it as a musical instrument, it could be fine.
    daisy555 likes this.
  3. daisy555
    1,682
    694
    CT
    Ha! Yes I could join a street band. It occurs along the entire panel under both passenger doors. I just went to take a photo for someone who was confused about the location and it wasn’t as loud this time. I’ll leave it alone and maybe it will magically go away.
  4. Trollbait
    12,379
    Could be brought on by moisture, and will be gone when the spot dries out.
