P0AD915 Hybrid/EV Battery Positive Contactor Circuit Short to Auxiliary Battery.
Discussion in 'Gen 5 Prius Main Forum' started by Siyaar, Jul 13, 2025.
  1. Siyaar
    Siyaar New Member
    2023 Prius
    Any Toyota Tech around who can help troubleshoot this? I'm willing to pay for the service. Looking for someone knowledgeable about the HV battery wiring diagram and HV ECU CAN.
    (Hybrid/EV Battery Positive Contactor Circuit Short to Auxiliary Battery.)
    Car won't go into ready mode, only shows ignition on.
    I've checked the fuses, HV battery grip, HV battery junction terminal box, and harnesses, but the error persists.
  2. Brian1954
    Brian1954 Senior Member
    1,863
    734
    South Central PA, USA
    If your car is still under warranty, call your dealership.
  3. bisco
    51,249
    luscious garage. it has a new name, i'll try to remember. earthling automotive
  4. Gokhan
    Gokhan Senior Member
    5,797
    2,286
    Paramount CA
    Probably not under warranty anymore.
    It is not something you can do. Take it to the dealer.
    HYBRID / BATTERY CONTROL: HYBRID CONTROL SYSTEM (for 2WD with NICKEL METAL HYDRIDE BATTERY): P0AD915; Hybrid/EV Battery Positive Contactor Circuit Short to Auxiliary Battery or Open; 2019 - 2020 MY RAV4 HV [11/2018 - 08/2020]
  5. Hammersmith
    Hammersmith Senior Member
    2,073
    2,061
    North Dakota - USA
    2023 Prius
    Limited AWD-e
    Why wouldn't it be under warranty? User profile says 2023 XLE. No 2023 is more than 3 years old(first ones were delivered around Feb/Mar 2023). Plus it's part of the hybrid system, which might be 5yr, 8yr or 10yr.
  6. Gokhan
    5,797
    2,286
    Paramount CA
    Oh, I thought the warranty was two years. Definitely take it to the dealer then. This is a complicated, specialty repair.
