How far / long can a Prius be driven with P0A80?
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by PriusII&C, Jul 12, 2025 at 11:04 PM.
  1. PriusII&C
    PriusII&C Active Member
    374
    131
    San Jose, California
    My 2012 Prius with 144k miles suddenly shows dashboard warning lights of yellow triangle (master warning), check engine, TCS, and brake trouble. A scanner shows a P0A80 code.
    I'm thinking to get the traction battery reconditioned by myeslf. The problem is the car is about 200 miles away from home. How far / long can I still drive it? What kind of potential damage could happen if I drive it home?
    Your knowledge / experience / insight is greatly appreciated.
  2. Tombukt2
    12,210
    2,152
    Probably none I drove a generation 3 with a dying battery in it for about 90 days . Didn't bother a thing change battery wen got to it and it worked like sposed to until engine failed
  3. Grit
    Grit Senior Member
    6,452
    4,186
    Wilkes Land
    Reposting from an existing thread, you’ll be taken to alligator alcatraz!
  4. bisco
    51,152
    shouldn't be a problem, the more highway, the better
