Brake pedal grinding/scratching/vibration
Discussion in 'Gen 5 Prius Main Forum' started by RMI_Chicago, Jul 17, 2025.
  1. RMI_Chicago
    RMI_Chicago New Member
    Chicago
    2025 Prius Prime
    XSE Premium
    About 4 weeks ago I got the 2025 Prius Plu-In Hybrid XSE Premium. At about 66 miles on the odometer I noticed that there is a scratching/grinding-ish sound and pedal sensation when the car transitions to friction braking. If I press the pedal quickly it goes straight into friction braking, and I hear/feel it. This is only heard/felt at low speeds (20MPH or below). This is NOT ABS going off. I know what that feels like, and have experienced it in this car as well.
    I took it to the dealer and they claim it’s normal. They said pads and rotors look fine. However, I tried another Prius on the lot, and it does not behave this way.
    Anyone else here experience this?
    My previous car was a 2022 Lexus ES300h, and it did not have this issue with brakes.
  2. ChapmanF
    17,479
    My Prius gets that way every time it has sat parked over a rainy night.
    I fix it, the next time I drive it, by shifting to Neutral for my first 3 or 4 stops. That rubs off the flash surface rust that has formed on the rotors, making the grinding/scratching/vibration.
  3. RMI_Chicago
    Chicago
    2025 Prius Prime
    XSE Premium
    I see. Mine just never ever goes away. I even tried that thing where you take the car to 40mph and stop about 5 times over a few days. But this happens at every single stop, or when just creeping forward with foot on brake.
  4. KMO
    KMO Senior Member
    1,835
    607
    Finland
    2023 Prius Prime
    If you're really only at 66 miles over 4 weeks, clearly it's getting very little use, and it may have been sitting around the dealer some time. There could well have been a fair bit of build-up, and you're not managing to get through it with your usage pattern.
    I'm pretty certain it can improve, and if you did keep working at the stops it would help. (Do the stops in neutral to get those pads working.)
  5. Gokhan
    Gokhan Senior Member
    5,799
    2,287
    Paramount CA
    My 2021 Prius Prime Limited PHEV brakes at over 40,000 miles are still whisper-quiet. I hardly use the friction brakes; so, chances are that the brakes are still brand-new.
    This was reported by other posters, too. It seems to be a manufacturing defect. Perhaps there is some something wrong with the pad-wear indicators or other brake hardware.
  6. RMI_Chicago
    Chicago
    2025 Prius Prime
    XSE Premium
    @KMO I am at 600 miles now, and sadly it is getting worse, not better. I meant to say I noticed it when it had just 66 miles on the odometer.
  7. ChapmanF
    17,479
    Take a look at the rotor surfaces. Is surface rust visible?
  8. RMI_Chicago
    Chicago
    2025 Prius Prime
    XSE Premium
    Pristine rotors.
  9. Hammersmith
    Hammersmith Senior Member
    2,073
    2,064
    North Dakota - USA
    2023 Prius
    Limited AWD-e
    Considering where you live, and because your dealership hasn't helped you, I'd consider taking it to TCCN Automotive out in Homer Glen for an evaluation. I'd trust them far more than any dealership. Even if they don't fix it for you, they can figure out what's wrong so you can take that info to the dealer and have it fixed under warranty.
    In case you don't know TCCN, it's a Toyota/Lexus/Scion specific repair shop owned/run by TheCarCareNut, a former 15-year Toyota master diagnostic tech and youtuber that opened up his own shop about three years ago.
    Julio_E likes this.
  10. Gokhan
    5,799
    2,287
    Paramount CA
    Ha ha, you say it only happens below 20 mph. Are you sure you are not hearing the “acoustic vehicle-alerting system” that turns on below 22 mph with the engine off and mistaking it for a brake sound, sending everyone on a wild-goose chase?
    Here is how my Gen 4 PHEV sounds—much louder in reverse than in forward. I mistook it for the transmission grinding before I found out what it was. LOL It was less loud in my 2020 Prius Prime XLE than in my 2021 Prius Prime Limited.
    #10 Gokhan, Jul 18, 2025
  11. Hammersmith
    2,073
    2,064
    North Dakota - USA
    2023 Prius
    Limited AWD-e
    Just to add onto Gokhan's post.
    Test by driving right around 22-23mph. If the sound suddenly disappears when you hit 23mph* and suddenly reappears at 22mph, Then what you're hearing is coming from the speaker. You can also test by forcing the engine to start when you're below 23mph. As soon as the engine starts, the noise will disappear.
    If the noise doesn't correspond to any of this, then it's something else. Since you say it's linked to braking, then it probably is.
    *I'm pretty sure 22/23mph is the cutoff, but maybe test +/-1mph to be certain.
  12. RMI_Chicago
    Chicago
    2025 Prius Prime
    XSE Premium
    This is not a speaker sounds. It’s grinding sensation through the pedal. You can also hear it, it sounds like metal grinding, and not the synergistic EV noise it makes.
  13. daisy555
    daisy555 Senior Member
    1,687
    695
    CT
    I have 1700 miles on mine and I’m noticing a slight intermittent break grinding sound during initial driving but it goes away. Just started a few days ago. Almost like the sound my 2009 made after it rained and was parked for a while. Hopefully this won’t be a regular occurrence.
    Yesterday I got out of my parked car and heard a high pitched screechy metal sound. Only lasted a few seconds and haven’t heard it since. WTH I’m trying to remind myself that most things can be repaired but my nerves aren’t believing it.
  14. Hammersmith
    2,073
    2,064
    North Dakota - USA
    2023 Prius
    Limited AWD-e
    Then I'm back to taking it to TCCN.
    Can you tell if it's happening just in regen, physical, or both?
    I'm wondering if there's something caught in one of your brake pads. Maybe a small rock or something is stuck and that's what's you're feeling.
    SM-S901U ?
    RandyPete likes this.
  15. Gokhan
    5,799
    2,287
    Paramount CA
    OK then. The Prius EV speaker sound is a grinding sound though. When I first heard it, I thought the transmission was grinding.
    Perhaps shoot a video and post it here so that we can hear this sound.
    #15 Gokhan, Jul 18, 2025
  16. RMI_Chicago
    Chicago
    2025 Prius Prime
    XSE Premium
    @KMO mentioned stopping in neutral, which I haven’t tried. Holy crap it helps! The rotors seem warped, and aggressively stopping from high speed in Neutral seems to make the grinding much quieter, and most importantly, the grinding sensation through the pedal almost goes away. However, it comes back after a few hours and I have to do an aggressive brake in Neutral again.
  17. Gokhan
    5,799
    2,287
    Paramount CA
    Aggressive braking will help wear out your brakes, traction battery, tires, and other things fast.
  18. Leadfoot J. McCoalroller
    7,907
    7,382
    Pennsylvania
    2018 Prius c
    Aggressively not-stopping is better still. I mean brake a lot, and hard, but don't actually stop. That way the rotor cool-down is a bit more even, which helps keep things smoother longer.
  19. Julio_E
    Julio_E Junior Member
    34
    Michigan
    2024 Prius Prime
    XSE Premium
    Depending on how interested TCCN might be in your braking issue, it may be some time before you can even get an appointment with TCCN. I recently called and left a voicemail and got a return voicemail informing me they are scheduling "typically about 2 1/2 months" out. From some of his videos, it seems he may accommodate an earlier appointment if the problem is "interesting" (and maybe he can make an interesting video out of it.
    I will say in the almost year, I've had my car, maybe this has happened once or twice and I attribute the event(s) to times when I wasn't driving as carefully as I usually do. And also probably my lack of knowledge on how regenerative braking and normal braking are supposed to work.
