Nutz About Bolts Prius Maintenance Videos
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Tideland Prius, Feb 17, 2016.
  1. Mendel Leisk
    40,615
    The 12mm triple-square points are very slightly further out. Also, each point is 90 degrees (corner of a square) whereas with the 10 mm double hex the corners are 60 degrees (corner of hexagon). The latter just fits better, same shape as the head bolt pocket.
    part2: just getting into it, the summary of the Toyota gasket kit is very helpful, with inset pics for each application. Never seen anyone else do this summary.
    NutzAboutBolts likes this.
  2. NutzAboutBolts
    NutzAboutBolts Senior Member
    1,619
    1,699
    Bay Area
    Here’s the 3rd video
  3. ChapmanF
    17,394
    Yeah, because of the different geometry, a 12 mm triple-square and a 10 mm double-hex are about the same size, and they both fit the head bolts. It's just that the Toyota head bolts are double-hex, so the double-hex bit fits them better.
  4. NutzAboutBolts
    1,619
    1,699
    Bay Area
    Glad to know that, will try that next time and see if it feels differently or not.
    nvm
  5. ChapmanF
    17,394
    Mendel drew this picture six years ago or so. Magenta for triple-square, cyan for double-hex:
    Putting the triple-square driver in the double-hex bolt head kinda transfers torque only at the points of the square. The double-hex driver will have its faces flat against the bolt-head faces transferring torque.
  6. NutzAboutBolts
    1,619
    1,699
    Bay Area
    thanks, yeah I can see how different it can be. So far, I don’t have issues with it. It’s like a 6 point socket and a 12 point socket, which one gives better bite. All works the same, just better torque when tightening it down.
  7. Mendel Leisk
    40,615
    Curious, did you reuse the head bolts? Likely all good.
  8. NutzAboutBolts
    1,619
    1,699
    Bay Area
    Yes, I reused the head bolts, I asked the parts guy if they sell head bolts and he said they do, but they rarely replace head bolts. So I just reuse it. It was expensive for 1, I believe it was 8$ or 18$ for one I think.
  9. ASRDogman
    ASRDogman Senior Member
    7,263
    3,789
    Did you measure them? They are stretch bolts, and they stretch.
    I bought new ones from Toyota, I believe it was less than $50.
    johnHRP likes this.
  10. johnHRP
    johnHRP Active Member
    582
    173
    KA, DE
    Excel
    $50 is relatively cheap, comparable to Felpro bolts.
  11. Noahdoge
    Noahdoge Active Member
    201
    141
    Mississippi
    @Mendel Leisk can you link this double hex for sale please, I can’t seem to find it. I can only find regular hex and triple square bits. I also looked at Tektons website and couldn’t find anything there either.
  12. Mendel Leisk
    40,615
    Googling:
    10mm double hex
    I eventually got to this on Amazon.com
    An intermediate step, description found on Amazon Canada:
    CTA Tools 9292 10mm Head Bolt Wrench
    the manufacturer’s website page:
    CTA Tools - 9292 - Toyota Head Bolt Wrench - Double Hex - 10mm — CTA Manufacturing
    #572 Mendel Leisk, Jul 20, 2025 at 9:50 AM
    Noahdoge and johnHRP like this.
  13. ASRDogman
    7,263
    3,789
    You might have to go to Snap on to get one.
    Toyota won't sell them to the public. Unless you know someone that works there that will
    get it for you.
  14. Mendel Leisk
    40,615
    Snap-On has one too:
    Snap-on Store
    There's a caution in the "Features" paragraph, regarding the triple-square.
  15. NutzAboutBolts
    1,619
    1,699
    Bay Area
    no i didn’t measure them
