What's on the back of engine, above oil pan? (Wet!)
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by MrPete, Jul 19, 2025 at 1:07 PM.
Tags:
  1. MrPete
    MrPete Active Member
    481
    188
    Colorado, USA
    @PriusCamper your wish came true, unfortunately. ;)
    I'm suddenly seeing a pool of wet on the garage floor after each of the last couple of drives. Not oily. No real smell.
    I need to find what this is and solve it. We leave on a 4000 mile driving trip in one week.
    My main questions:
    • what are the (wet) bolts/devices on the back-right side of the engine, above the oil pan, and below-right of exhaust???
    • Could the black bolt in photos be loose?! (I've not attempted to change anything.)
    Jacked up car. Looking at the back side of the engine I see some wet components, particularly a black bolt, and another wet one above it that's hard to see.
    In the photos, "down" is toward the front of the car. I am lying beneath the oil pan, whose attachment bolts are visible in the final photo.
    The black bolt "under" the metal plate (and clip for some wire) was quite wet. A lighter bolt above it was dirty/wet. Then in the first two photos you can see a black bolt or cap or ??? that's also glossy/wet.
    I'll search for appropriate engine diagrams...
    THANK YOU! What an amazing community :)
    20250719_104930.jpg 20250719_105011.jpg 20250719_105059.jpg 20250719_105111.jpg
  2. NutzAboutBolts
    NutzAboutBolts Senior Member
    1,621
    1,701
    Bay Area
    It’s probably your timing chain tensioner gasket that is leaking from the top, it’s a common leak on that gasket. Mine was leaking too and I changed it when I did the head gasket.
  3. MrPete
    481
    188
    Colorado, USA
    Hybrid Pitstop replaced my entire engine (with a Gold 2015 rebuilt from ground up) only 30k miles ago.
    Is that a likely gasket leak so quickly?
  4. ChapmanF
    17,396
    I saw that black-painted block, and wondered about that.
  5. NutzAboutBolts
    1,621
    1,701
    Bay Area
    looking at the first picture, it looks wet underneath the timing chain tensioner.
  6. NutzAboutBolts
    1,621
    1,701
    Bay Area
    Is that black looking bolt suppose to be where the oil pressure sensor is at? I’ve never seen that type of black bolt before.
  7. MrPete
    481
    188
    Colorado, USA
    Good question. And THANK YOU for digging in with me on this!
    Here's a new picture from the side w/ the right front wheel off.
    100% of the wettish area is around the two connectors and the black bolt (which is behind (left of) and a bit below the upper connector.. Above these, it's dry dry dry.
    I do not know if this helps w/ identification: I notice that the upper connector is at right angle to the back of the engine. The lower one is tipped by 10-20 degrees or something like that.
    I am also wondering... could this simply be condensation from the A/C unit? Doesn't really sound right to me... grasping at straws I admit!
  8. NutzAboutBolts
    1,621
    1,701
    Bay Area
    from the looks of it, I’m not sure what that black bolt is since you have the oil pressure sensor and the crank position sensor there. I’d definitely call the dealership to see if they can see what that part is because it’s not on my 3rd gen Prius engine.
    and the ac condensation line is below with a hose that goes down on the passenger side seat. It wouldn’t be on the engine like that black bolt.
  9. MrPete
    481
    188
    Colorado, USA
    Interesting. From the link below (sub-figures "C" and "D"), looks like those are "Plug, w/ Taper Head Screw" -- just a bolt that does nothing?! Perhaps they have some kind of manufacturing purpose. (NOTE: my engine is 2015 now... I looked it up. Those parts haven't changed.)
    https://www.amayama.com/en/genuine-catalogs/epc/toyota-usa/prius/zvw30/13503/engine/1105?frame_no=JTDKN3DUXB1414344
  10. ChapmanF
    17,396
    Often, manufacturing a block requires making passageways in it, like oil galleries, that have to be bored through from the outside. Then the outside holes are closed with plugs.
  11. NutzAboutBolts
    1,621
    1,701
    Bay Area
    Yeah looks like just a bolt plug they plug up, not much you can do to it. Is it really leaking from there? Try cleaning it with brake clean and see if the leaks come back from that bolt hole or from the timing chain tensioner.
  12. Noahdoge
    Noahdoge Active Member
    201
    141
    Mississippi
    You state the substance is not oily. It’s summertime so are you sure you’re just not seeing the ac condensate? I have a small pool under my car after driving in the summer but it’s just water. Take a paper towel and soak it up to see what it is. If it’s oil, coolant, brake or transmission fluid it’ll be pretty obvious.
