Just need to vent...
Discussion in 'Fred's House of Pancakes' started by Mendel Leisk, Jul 6, 2022.
  1. Mendel Leisk
    40,666
    Using the lube in the BlackJack kit I've had no subsequent leaks either. I suspect either will work, the glue option is "belts and braces", but has a shorter shelf-life, the volatile solvent(s) bleed off, and it dries up.
  2. Trollbait
    12,379
    Commercial ones are more robust, and have the tighter fit to not need replacing regularly. Might also save a tiny bit of electricity. Harder to get the plug in, but you won't have to worry about a loose contact.
  3. Mendel Leisk
    40,666
    Concur, sounds plausible.
  4. Isaac Zachary
    Isaac Zachary Senior Member
    2,343
    1,161
    Does yours leak out if not lying flat? Mine does. And then my wife is constantly reorganizing the tool basket in the car, and keeps putting the Black Jack box in vertically. So it's getting pretty slimy in there.
  5. Mendel Leisk
    40,666
    Good to know. I’ve got it in the tray under the hatch floor, right way up.
    Related tip: I’ve got a pricey Milwaukee multi-meter, impressive looking, waterproof case. Found out the hard way, if you store it facedown, and the batteries leak, they leak all over the internal printed circuit. I’m on my second one… (thankfully warranty claim)
    Isaac Zachary likes this.
  6. Isaac Zachary
    2,343
    1,161
    One pet peeve of mine is how cars these days have such a cluttered area around the driver, especially that space hogging center console.
    Now I know that some newer Toyotas are getting a "bridge" center console with space under it. But as an amateur radio operator, I want space to be able to install my radio heads.
    Right now I have a flexing bar attatched to the base of the driver's seat up to my HF radio contol head. But it really limits the leg room up there as my knee always hits it.
    Some Teslas, and the ID.Buzz apparently have more spartan front interiors, but then have glass roofs that won't work well for what I'm doing. Are there any modern cars out there that don't have a center console yet have a metal roof so I can keep an eye on their used prices?
  7. hill
    8,664
    Our 2016 model S had a metal roof. It was the last year before they switched.
    Carfax shows a 60kWh version w/ 72K miles going for under $16K. The 60kWh models can be software upgraded to 70kWh too.
    Not too shabby.
    #2787 hill, Jul 23, 2025
  8. Isaac Zachary
    2,343
    1,161
    Nice! That would be a car I'd want to buy as long as I'm not too afraid of it being too expensive to repair if something did need fixing.
  9. bisco
    51,246
    yeah, i'd be really afraid unless i was jay leno
    Merkey and Isaac Zachary like this.
  10. hill
    8,664
    ½ of those 2016s had transferable supercharging too. Haven't had that model in 2016 I must say you ain't going to get the latest and greatest charge speeds that do nowadays was a measly 60 kwh traction pack. The upside, having a 10K wh buffer means it doesn't suffer from degradation like many of the others.
  11. Isaac Zachary
    2,343
    1,161
    Charge speeds don't concern me that much. What car for $15,000 has noticeably better charging speeds? The charging speeds of our 2013 Nissan Leaf SL that we had was sufficient, even at mostly L2 and sometimes L1 speeds. What wasn't was the range, especially in the winter.
    The price and longevity are of most concern to me. I guess that's why I bought a Toyota. It might be a while before I actually need another car, although my boys are starting to look for their first car.
  12. bisco
    51,246
    charging speed requirements are related to typical use, or to unfounded concerns from neophytes.
    over in the bolt forums, (a slow charger) those who purchased for a local runabout are unconcerned and prefer lower pricing, while those who travel distances regularly would like faster speeds in the next iteration or have moved on to a faster charging vehicle
    Trollbait and Isaac Zachary like this.
  13. Mendel Leisk
    40,666
    Noticed a silver gen 3 in a parking lot this morning, with the 17" rims, with the saggy rear bumper, went around to the front to verify the LED headlights and yup, but all fogged and yellowed. :(
    For comparison, our “garage queen”:
    #2793 Mendel Leisk, Jul 28, 2025 at 2:03 PM
  14. xliderider
    xliderider Senior Member
    8,077
    3,235
    Honolulu, HI
    Same thing happened to me. Now, I always take the battery out of the meter now and store it on the side, outside of the meter case.
  15. hill
    8,664
    Brands Klein & Fluke - the last bastion of USA made multimeter. Their products have been in my cabinets for decades now. Got rid of Dad's ol' timie analog multimeter from the 60s when he passed in 2021. Impedance was a little sloppy.
    tochatihu likes this.
  16. tochatihu
    tochatihu Senior Member
    9,590
    3,700
    Kunming Yunnan China
    2001 Prius
    Ah the Simpson 260... was nothing to complain about.
  17. ChapmanF
    17,462
    My Fluke handheld is 35 years young and its DC accuracy, when I checked a couple years ago, still spot on. AC V off by a hair but nothing that would affect what I do with it.
    The only thing to vent about is it's old enough to predate the IEC measurement categories (or at least to predate Fluke's use of them in this model), so it's not CAT-anything rated. Their newer versions of the same model, of course, are.
    I suppose I ought to buy a new one, but it just doesn't feel right when the old one still works so well.
  18. tochatihu
    9,590
    3,700
    2001 Prius
    Follow your feelings, Fluke Skywalker.
    Trollbait, xliderider and hill like this.
  19. ChapmanF
    17,462
    A professional organization I belong to just sent me an offer for group term life insurance.
    The rates looked really good, because the rates quoted on the cover letter (all personalized and mailmerged with my name and address) were the rates for 35-year-olds.
    Huh, so maybe they don't have my birthday on file?
    Never mind my birthday, I've been a member of their ding-binged organization that long! Are they thinking I signed up in diapers?
    Merkey likes this.
  20. ETC(SS)
    6,965
    GRRRR!!!
    :mad:
    My <5 year old $700 (**) Fluke 289 just went Tango-Uniform with the infamous "lead connected incorrectly" error message.
    (**) OK, so my company bought it for me and it was only $550 in pre-Bidenflation dollars. :D
    But still.....
    It would APPEAR that there are IR emitters and photodetectors in the bottom of this meter to warn the operator (and disable the meter!) if the leads are not connected properly....or at all.....OR(!!!) if one of the SMT component is dislodged by dropping it, or if the clear plastic lead bases get dirty....or......or.....
    Investigation to follow.
    Meanwhile:
    $10.99 replacement, delivered in less than 48 hours.
    It's even fairly accurate!
