2006 Prius Engine Replacement
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by KitsuneVoss, Jun 24, 2025.
  1. KitsuneVoss
    KitsuneVoss Member
    302
    46
    Virginia
    Starting this as a new thread. This is going to try to be as "Step by Step" as possible. Also so I can look back if I need to.
    Everything "small" is being put in ziplock backs and being labeled with a sharpie.
    Day One:
    1. Start with removing battery plug and disconnect the aux battery (10 mm on the wall of the car)
    2. Moved the lock of the hatchback so that it will not lock
    3. Disconnect bolts holding hood and line for windshield wipers (12 mm)
    Note that when I tried to replace the hood before I put a plumbing fixture in to make it easy to remove
    4. Remove wiper arms (14 mm)
    The double one you need to wiggle around a little to get it off.
    Prying does not really work. Wiggle it
    5. Remove plastic cover on windshield wiper "tray." Came off easy.
    6. Disconnect the wiring harness to the wiper motor assembly and remove bolts holding motor in (10 mm)
    Remove plastic clip from wiper motor "tray"
    Wiper motor should come out easy
    7. Remove bolts holding relay box on tray (10 mm), remove clips holding relay box to tray, and then tray on (10 mm). Should come off easy once bolts are removed.
    Waiting on the electrical system to drain completely so covered engine compartment with plastic so that no water, or at least little water, gets in the engine compartment. Going to try to do just a little a day.
  2. Tombukt2
    12,287
    2,165
    This is cool I want to see engine n trans split whilst in car . Haven't had to do this gen2 yet on a keeper in my junker w trans in position in car and engine hanging from boom and front mount removed pass side. I still couldn't get enuff room to slide engine to pas side to let go of trans output shaft. Sucked . So on this junk car I undid trans. But in my keeper I'm always hoping not to drop trans. But I've not looked at any vids or anything but looking at it quickly I saw trouble . Maybe undoing trans mount at driver side w jack under and tilting trans output side towards over pass fender at angle not there's enough room for that angle . I just hate to disconnect suspension . But if I have 2
  3. KitsuneVoss
    KitsuneVoss Member
    302
    46
    Virginia
    The insulation is falling off the underside of metal wiper tray where it is over the engine.
    I worry about fragments falling in the spark plug openings when I am working there.
    I think I can use my 2009 tray but what is the next best option?
    Remove the insulation completely?
  4. ColoradoCrow
    ColoradoCrow Senior Member
    1,103
    457
    Leawood, KS
    I
    I removed mine completely after it fell apart. I would think it would quiet engine noise a bit... But I havent had one on our white Prius for 4 years now.
  5. Tombukt2
    12,287
    2,165
    Yep pull it off.
  6. KitsuneVoss
    KitsuneVoss Member
    302
    46
    Virginia
    Day Two:
    1. Removed air box. Two 10 mm screws on engine. When I last removed the air box, the hose clamps were not worth trying to reuse so replaced with new ones. If you are reusing the old ones, may need a lot of PB Blaster first. Wire harness holding the MAF sensor. Used a pick to get it loose. Spraying down the bolts / screws to the MAF sensor in hopes of replacing the screws.
    2. Disconnected fuel injector and coil connectors.
    3. Disconnect wire harness in front of brake fluid reservoir. I don't think it connects to it but the position
    4. Unbolted, slid out intake manifold
    Five bolts, all 12 mm. Sprayed them down heavily with PB Blaster. The outer ones however will need a deep socket to remove. Of note, the two hoses that go into the manifold just use butterfly type clips. The bolt on the driver's side was crazy to get to and why it took so long. Could have likely just removed the two hoses and gotten to it far easier. Also like 100 degrees outside. Ended up prying a bit with a large screwdriver to get the intake manifold off. Some wires still are attaching the intake but have not removed yet. I removed a clip holding the wire to the driver's side of a bracket on the intake manifold and then that bracket to get to the driver's side of the intake manifold. 10 mm holding bracket and royal pain to get to. What you do that is pry outward on the other side of where the hose / wire bundle is. Removed wire harness on passenger side of manifold. Carefully used need nose pliers to unlock.
    Fourth image is really blurry
    Stopped at that point. Covered engine with plastic and put away my tools.
    A few questions
    1. Using a video. Not trying to overwhelm myself by watching the whole thing. Will I be removing the fuel rail at some point? Will I want to use these fuel injectors. Not had any problems with the old ones from the 2009 but these are just rebuild. I am planning to replace the spark plugs of the replacement engine when I get there.
    2. I assume that I want a new intake manifold gasket but just checking?
    3. May actually be crazy but can I put the engine hoist in the back of the ranger instead of on plywood?
    Thinking then once the engine is out, could just drive forward with it.
    #6 KitsuneVoss, Jun 25, 2025
  7. Tombukt2
    12,287
    2,165
    Yer hoist should pick up engine enuff to push car back . Or this hoist I'm using swivels 280 or so degrees once engines up I swing it from front of car to beside it by pushing on the beam. .
  8. Tombukt2
    12,287
    2,165
    You need secure the cherry picker to truck bed you gonna be at angle . I usually use short chain .
  9. KitsuneVoss
    KitsuneVoss Member
    302
    46
    Virginia
    Day Three:
    Yesterday it was my birthday, so wanted to spent one day not working on things. Did not study either. Studying for a cyber security certificate with planned test day of first week or second week of July.
    Felt that Wednesday I did not do enough pictures, so trying to do better today
    Also saw that the video I have been following completely removed the manifold / throttle body.
    Better picture of the top of the engine with the manifold loose
    1. Disconnect this black and red wiring harness connector
    2. Disconnected lower hose clamp on manifold / throttle body on engine side of throttle body
    3. Trying to remove oil dipstick pipe but actually broke off near the pan. Hose in the way but needed to remove the hose anyway.
    Passenger front side of manifold / throttle body
    Ended up mangling it when getting it off so likely try to replace with a screw on hose clamp if I can get it to fit
    Note, started leaking some kind of red looking fluid after removal. Can see it in the picture for #4. Put pan under car to catch it. Does anyone know what the fluid is?
    4. Removed oil dipstick pipe from exhaust manifold / throttle body (10 mm bolt)
    5. Removed white wire harness connector from driver's side of exhaust manifold / throttle body.
    6. Unbolted wire harness from driver's side of exhaust manifold / throttle body.
    Some one as white connector (10 mm bolt)
    7. Released wire harness that is kind of under exhaust manifold / throttle body.
    Driver's side I believe
    8. Disconnected hose clamp on driver's side front of manifold / throttle body
    9. Bolt holding wire harness on passenger side of manifold / throttle body
    Picture is not great but look later picture of location. Removed bolt (10 mm)
    10. Removed plastic clip holding final wire harness on manifold / throttle body
    Passenger side
    Engine compartment with no manifold / throttle body
    Put away my tools and covered up engine at this stage
    Only about 50 minutes of work but need to review next steps first
    #9 KitsuneVoss, Jun 27, 2025
    ColoradoCrow likes this.
  10. KitsuneVoss
    KitsuneVoss Member
    302
    46
    Virginia
    Day Four:
    Another short day due to working last night and working tonight as well
    Need to get sleep for work tonight. This website is also the journal for what I am doing however so want to post this.
    I do figure it may help others though.
    1. Pushed the plastic shield out of the way. Released Hose that goes to back side of driver's side of engine block that came from the throttle body. Also released the hose that went to the front side of drives side of engine block. Labeled both hoses with tape. 90 degree angle side goes to engine side.
    There is a plastic clip that was loose and while I suspect it held the two hoses together under the plastic but not 100% sure. I guess check carefully for that clip when taking out the second engine.
    Hose Clamp-06.jpg Hose Clamp-07.jpg Hose Clamp-08.jpg Clip-01.jpg Hoses-01.jpg
    2. Removed bolt holding wire harness to upper part of engine. (10 mm bolt)
    3. Removed clip holding fuel line on - Do I use an easy connect / disconnect to remove the fuel line?
    4. Removed wire harness from driver's side of engine
    5. Four bolts holding grounds and or wiring to driver's side of engine. Removed the four as well but had issues getting pictures due to being pretty cramped. When I remove the second one, I will at least show where the socket was. (10 mm bolts)
    Called in for dinner at that point so put away tools and covered engines
    Questions
    1. Is the fuel line disconnected with a quick disconnect? Know what size if so?
    2. Will I be able to tell where the ground wires go by where they can reach to or will I have an issue. Reconnecting them in that enclosed space is going to be a pain in any case
  11. KitsuneVoss
    KitsuneVoss Member
    302
    46
    Virginia
    Day Five and Six:
    Been a while but been busy studying for Security+ (IT)
    Passed the test BTW
    1. Removed Fuel Line
    Used a standard disconnect
    2. Removed Sensor on driver's side of engine to try to get at hose clamps on that side.
    3. Tired to remove hose on driver's side of engine but hose clamp broke and having trouble removing it
    4. Disconnected Wire harness on front lower area area of engine
  12. Tombukt2
    12,287
    2,165
    No none of that stuff I'll be an any kind of issue. Usually I'm at the engine connect to chain point in about 1. 5 hrs or so going back is way faster all wires n hoses fall wer they go more or less seriously.
  13. KitsuneVoss
    KitsuneVoss Member
    302
    46
    Virginia
    I don't understand what you mean? Do you just cut the hoses? I am thinking I should replace all hoses anyway.
    I have had two hose clamps now snap instead of opening. They are badly rusted.
  14. Tombukt2
    12,287
    2,165
    You can cut pull and use zebra clamps
  15. KitsuneVoss
    KitsuneVoss Member
    302
    46
    Virginia
    I spent hours today trying to get one clamp off.
    Going to try cutting the other one off using my roommate's dremel.
  16. Tombukt2
    12,287
    2,165
    Dremel or bolt type cutters w short handle
  17. KitsuneVoss
    KitsuneVoss Member
    302
    46
    Virginia
    I know I just wasted way too much time on the hose clamps
    Tombukt2 likes this.
  18. KitsuneVoss
    KitsuneVoss Member
    302
    46
    Virginia
    Day 7:
    I know I am working slow but not trying to push. More in the groove now though I hope.
    Day 5 and 6 were more or less wasted days.
    1. Used a Dremel to cut clamp on the the front water line from the engine.
    Managed with minimal scoring
    2. Removed the crank sensor (I believe) from driver's side of engine
    Uses 19 mm socket. Was just a light turn in order to be able to remove it the rest of the way by hand.
    3. Used long length needle nose pliers to turn the clam so it faced up and then used locking pliers to pull the hose clamp down.
    That lower pipe is very long
    4. Removed the bolts holding the brake reservoir on the engine.
    All 10 mm but needed a long extension to get to the one underneath.
    Did not disconnect the brake lines
    Looks like the next step will be to raise the car and remove the water pump.
    Likely going to try to get the car lifted Tuesday if it does not rain.
