Leaky Head Gasket and Prior Complete Coolant Exchange - "Non-Hybrid"
Discussion in 'Gen 2 Prius Main Forum' started by Bechi, Jul 25, 2025.
  1. Bechi
    Bechi Junior Member
    37
    US East Coast
    2025 Prius
    Limited AWD-e
    This is still troubling me, so thought I'd see if anyone had any thoughts.
    About two weeks ago my 2007 touring with ~340K miles beeps and red triangle appears briefly with thermostat icon. We pulled over, could find no issues and overflow tank is full. No other symptoms so I figured "Princess" was getting pissy in her golden years at having my young man drive her. Later, checked for codes and found none, but saw level in radiator was low so added asian pre-mix coolant, and let her run with full heat until radiator would take no more - about a quart total. Took her out next day for a long ride while young man monitoring temps using techstream and averaged 180°F to 190°F. Seemed all was well.
    A few days later when I was driving to work, same thing happened - beep, red triangle, and thermostat icon. When this happened, I noticed that the heating system was acting strange and I wasn't getting heat. I brought her in to the nearest stealership and they were not able to pull any codes, but did notice flakes of dried coolant on the bottom of the engine bay, but no evidence of a leak or any coolant loss. The technician though it was possible that it could have been due to a coolant splash that got pulled through the fan when my local stealership replaced the coolant two months ago.
    Since they didn't have an answer, I asked them to replace the thermostat since it seemed like a reasonable place to start being as it had never been replaced. When replacing the thermostat, the technician noted that there was evidence of a leaky head gasket and it could last for "a while" or go at any time. Princess still runs fine; no shudder, no white smoke, and no sludgy oil. I have not had to add any coolant since picking her up at the stealership a week ago.
    I have been casually looking at new models for a few years now, but with this diagnosis, plus an intermittent combi meter issue, and the original traction battery I decided now was the time and have a Gen5 AWD Limited reserved. This is still bugging me though, because according to all reports, Gen2 head gasket issues just aren't at all common, I am not only the original owner of this vehicle, but ordered it from the factory, so can say with all certainty that she has always been maintained (between my father who was a mechanic for almost 70 years, my quasi-mechanic motorhead young man, and the local stealership). I also read back through the service record for the coolant replacement done in May, and it's listed as "Complete Coolant System Fluid Exchange in both Engine and Radiator. Non-Hybrid". Why would it be listed as non-hybrid? I don't know of any reason why changing the coolant in a hybrid would be any different than changing it in an ICE-only vehicle, but that just seems weird.
    I'm curious if anyone has any thoughts about this. Thanks,
    Bechi
  2. dolj
    dolj Senior Member
    8,428
    4,285
    Wellington, New Zealand
    My interpretation of this phrasing is that they only changed the engine coolant and not the inverter coolant, so they serviced the non-hybrid portion of the system.
    BiomedO1 likes this.
  3. rjparker
    10,080
    6,244
    It was losing a lot of coolant and likely had air pockets that fooled you when adding coolant. Gen2 has more air pocket issues.
    A better explanation and picture of the evidence would have been my request but it sounds like it was leaking outside of the engine if he saw something. Gen3 hg fails leak into the cylinder and foul the plugs causing misfires and shutters.
    I agree with the above, a complete "hybrid" flush is two separate cooling systems, not just the engine.
  4. Bechi
    Bechi Junior Member
    37
    US East Coast
    2025 Prius
    Limited AWD-e
    Thank you, both! That makes more sense to me. I'm pretty sure he said he did put a borescope into the cylinder and saw evidence of coolant leaking in, but after pretty much spending the day in the waiting room losing my sanity, I could be misremembering. There was someone who insisted on singing while they waited for quite some time...
    When I have taken it out in the past week, I've been running it with full heat just to purge any lingering bubbles and just topped off the radiator to the top of the neck in the event that not only was the system not fully bled during the May coolant change, but also during the thermostat replacement. I'll continue that and monitor it to see how much it's going down from here.
  5. rjparker
    10,080
    6,244
    With a coolant leak into a cylinder, combustion gases can be pushed into the cooling system replacing coolant burned off in a cylinder. A positive borescope test is the gold standard for head gasket leaks.
  6. Bechi
    Bechi Junior Member
    37
    US East Coast
    2025 Prius
    Limited AWD-e
    I did notice a bit of a "whoosh" when I opened the radiator cap to check and add more coolant. I'll continue to monitor it (for scientific purposes natch), but with all reports of a leaky head gasket on a Gen2 being so rare, and usually accompanied with codes, white smoke, shuddering, etc. I'm just curious (hopeful?) that maybe it was just the thermostat and any bubbles may be getting bled out. If that's the case, it should become apparently pretty quickly. If it IS the head gasket, I've duly reported that it isn't so rare after all, and isn't necessarily accompanied by the obvious symptoms.
    Thanks!
  7. highmilesgarage
    highmilesgarage Active Member
    467
    173
    Kansas City
    my 426k miles 09 Prius suffered the same fate, head gasket issue. Simplest way to check is to look at the level in the reservoir tank, if it's at max all the time (even when parked overnight) then there's a possibility of head gasket (or a bad cap) Fluid from the tank should go back to the radiator/engine when things cool down. When opening the cap, if there's a burst of coolant going out (also parked overnight) then definitely a sign of head gasket. Hybrids are typically tolerant of head gasket leak just like in gen3 and they don't exhibit obvious symptoms like white smoke, you can drive them as if it's okay until it get worst. Anyway the gen2 head gasket is perhaps the simplest DIY job I've ever did compared to other cars.
  8. BiomedO1
    3,488
    1,811
    SacTown, Ca
    Yep, exhaust gases getting pushed into the cooling system, may be misinterpreted as a bad or incomplete bleed of the cooling system.
    Has the ICE coolant pump ever been replaced? Slipping vanes may cause intermittent over heats. Assuming your electric radiator fans are fully operational and your cooling system isn't plugged up with stop leak.
    Good Luck tracking it down and keep us informed.....
    FWIW: Toyota does not log overheats in it's CEL only temperature sensor low, out of range. By the time you see that, you've probably done some damage to the engine. The sensor is probably fine, you've just been overheating so much that the ECU thinks there's a problem with your temp. sensor.
    #8 BiomedO1, Jul 27, 2025
  9. pasadena_commut
    pasadena_commut Senior Member
    2,584
    765
    Southern California
    On this car that could result in coolant being first pushed into the overflow tank and then out from there through the final overflow hose once that tank reaches capacity. The coolant would likely just disappear since it would happen while the car is being driven. I would assume that when the vehicle cooled off it would normally suck most or all of the coolant from the overflow tank back into the radiator. Perhaps not though if the head gasket issue was such that an intake valve on the affected cylinder(s) was open when the engine shut off. In that scenario the car could suck air into the coolant through this abnormal route, and perhaps the overflow tank would still be full?
  10. Bechi
    Bechi Junior Member
    37
    US East Coast
    2025 Prius
    Limited AWD-e
    Yeah, it just bugs me that it's supposedly NOT a common ailment with Gen2s and she's been well looked after. Finalizing the paperwork on my new Gen5 later this week and hopefully picking it up soon as well.
  11. rjparker
    10,080
    6,244
    Any car can blow a head gasket but it usually takes an overheat episode.
    A gen3 does it routinely without overheating due to several 1.8L engine design issues which were partially addressed through tsbs and totally redesigned for gen4s.
  12. Bechi
    Bechi Junior Member
    37
    US East Coast
    2025 Prius
    Limited AWD-e
    Now, she's really messing with my head (this car has always been smarter than I am). I've been continuing to cautiously drive her locally and noticed a puddle of coolant under the front bumper on the driver's side last Monday. It wasn't clear exactly where the leak was coming from, only that it was dripping down onto the metal rail beneath the radiator and then onto the ground, from it appears, the lowest spot. I put a small dish under that spot so I could monitor how much was leaking. Over the course of the past week it ended up totalling just a few tablespoons and then stopped leaking after the first few days. For fun, we also did the rubber glove test and found no evidence of any exhaust gasses leaking into the coolant at startup. Coolant level now appears to be stable; I haven't added any in over a week.
    I'm really starting to think there is no problem with this car and that when Toyota did a really excrement job of bleeding the coolant when they did the coolant exchange a few months back, and a hose wasn't completely seated and sealed when I had the other dealership replace the thermostat. Am I crazy?
    Thanks!
    Bechi
  13. pasadena_commut
    2,584
    765
    Southern California
    Maybe they left the bleeder valve open? It is on the top/back of the radiator at the top in a location more or less above where you describe the leak.
  14. Bechi
    Bechi Junior Member
    37
    US East Coast
    2025 Prius
    Limited AWD-e
    Now that would be something! I'll check the bleeder valve.
    Thanks, pasadena_commut!
