Wrapping stock intake with tinfoil bubble and then heat resistant wrap?
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by h1ph0panonymous, Jul 11, 2025.
  1. h1ph0panonymous
    246
    33
    I’ve been playing with the fan speeds with the cabin air temp set to HI (highest heat), no recirc, no AC with air positions to feet and windshield and noticed two bars of fan speed (second fan speed) is enough to help dissipate (vent or exhaust) the engine bay heat through the cabins and not cook your feet at a stop light. Goes from 188-190 to 182-184 in less than 30 seconds like that instead of sitting at 188-190 the whole time at the stop light. I’m still going to go through with my gold wrap measures to combat heat soak in general along with thicker insulating tubing for radiator and coolant lines than the stock insulation they put on it, even cold wrap sections of the new insulation tubes where the engine is facing them.
    #201 h1ph0panonymous, Jul 18, 2025
    Brian1954 likes this.
  2. frodoz737
    frodoz737 Top Wrench
    4,574
    2,455
    33
    Congratulations! This makes post 203...and you've still done nothing.
    h1ph0panonymous likes this.
  3. Brian1954
    Brian1954 Senior Member
    1,868
    736
    South Central PA, USA
  4. Brian1954
    1,868
    736
    See post #199. He ordered the parts one day ago.
  5. ASRDogman
    ASRDogman Senior Member
    7,285
    3,803
    Oh just soak it up! o_Oo_O:ROFLMAO::ROFLMAO::ROFLMAO::LOL::LOL::LOL::whistle::whistle:
  6. h1ph0panonymous
    246
    33
    I like blue matches the Hybrid blue accents.
  7. h1ph0panonymous
    246
    33
  8. h1ph0panonymous
    246
    33
    As expected, decreased heat soak temps from stop light to stop light driving especially in combination with cabin exhaust method with the fan speed to 2 notches. Took an hour or two to take out the intake assembly and cut out a hundred jigsaw pieces of the reflect a gold tape to cover the whole underside of the assembly, left the top of it alone because it’s a porous plastic material and can see it not adhering correctly with the tape but mostly because most the engine heat radiates from under there.
  9. Hayslayer
    Hayslayer Member
    247
    127
    So, clarify this for me. You believe covering your air intake tubing with gold reflective bubble wrap is lowering your engine coolant temperatures while you redline it from stoplight to stoplight?
  10. h1ph0panonymous
    246
    33
    I ended up not using the bubble wrap tinfoil stuff, only used the reflect-a-gold DEI tape on the complete underside of the air intake assembly for obvious reasons. Yes a small gain is still a gain when it comes to lowering heat soak temps. Even at highway driving speeds I noticed decreased temps albeit 1-2 degree lowered difference. The bubble wrap stuff I’m still theorizing where or on what that could be used best, it also deals with condensation so could use for those type of applications as well.
  11. ChapmanF
    17,479
    Temperatures from what sensor(s)? Ones built into the car, or added? How much data from before and how much from after? How do the distributions and means compare? What other variables were measured and controlled for?
  12. h1ph0panonymous
    246
    33
    Havent seen it rise to 195 degrees post acceleration from a heat soaked idling stop light condition since the gold wrap was put on nor have I seen that temp on highway driving when I normally have during the same strips of highway, of course in addition with the cabin exhaust measure it can drop as low as 173 degrees within the time it takes the light to go green from the time of stopping when it turned red. (Usually 30 seconds or less unless you have an unfriendly intersection light that takes minutes to give you the right of way then you’re looking at it going as low as 150 degrees in that time).
  13. ChapmanF
    17,479
    Is the reading you are talking about the coolant temperature at the cylinder head outlet sensor, as reported by the ECM to an OBD-II device?
    What extent of saved data have you got from before and after the modification (both data from that sensor, and data on other conditions in effect for the test drives)?
    At the stop lights, was the engine running or stopped?
    Generally, the smaller an effect being reported, the larger the number of repetitions and samples needed to get any decent confidence in the difference observed being a real effect. You mention "1-2 degree lowered difference" in #211, down in the range where an experiment could easily be too loosely controlled or collect too little data (both before and after) to make the difference of that size interesting.
  14. frodoz737
    4,574
    2,455
    33
    ...but did you fix your car?
  15. Brian1954
    1,868
    736
    You need to turn off the heater fan to determine how the gold foil wrap is performing. When you have the heater fan turned on, you are seeing the effect of the heat being dissipated by the heater, not by the foil wrap.
  16. h1ph0panonymous
    246
    33
    I mean I do and have been looking at the scan gauge coolant temp right above my steering wheel base quite a lot for the past two weeks ever since noticing how high the highest temp would get after a heat soak stop post acceleration at a red light and noticed it sat at 190 at the lights, but that initial observation of mine is probably because I didn’t have regen braking then and still today I don’t so the engine was probably working harder and showing higher temps then what I’ve usually seen in the past two years owning it now. Yet still with no regen braking I’m still seeing lower temps at certain checkpoints (conditions when I usually check and stare at the scan gauge for 5 seconds at a time or until temps fluctuate), I don’t think the battery is magically back to its regen braking health state so that variable is excluded.
    #217 h1ph0panonymous, Jul 25, 2025
  17. h1ph0panonymous
    246
    33
    Yes I did, on accident left it off when going on a highway after a door dash delivery (was door dashing for 3 hours after the wrap) noticed it didn’t reach to 193-195 zone on the 0-65 acceleration to merge onto the highway from an already warm and running engine. Only time it reached 193 was when speeding up to 70 from 60 to see what efficiency was like at those speeds, dropped to 191 after cruising at 70 less than a minute. Getting a stable 188 at 67mph with 50mpg. Outside temperatures were 80 and humid (Minnesota).
  18. h1ph0panonymous
    246
    33
    No I didn’t want to change more than one variable for the data.
    In order to get my regen braking back (which is actually a variable in heat soak temps) I have to muster up the confidence to dissemble the rear wheel well plastic housing and remove the old ABS wheel speed sensor pigtail and put the new one in which my mechanic friend said there is soldering involved. Is this true?
  19. Brian1954
    1,868
    736
    Leave the heater fan off for two to three days and check the temperature data versus the temperature data that you had before you gold foil wrapped the air box.
