"Volts mean nothing. Amps mean everything!" - Your Battery
Discussion in 'Gen 3 Prius Technical Discussion' started by HyBatteryMan, Jul 25, 2025 at 10:03 PM.
  1. HyBatteryMan
    HyBatteryMan New Member
    Friday
    I’d like to start a discussion about hybrid battery repair — specifically looking at capacity in ampere-hours, not just voltage.
    In my experience, many batteries show decent voltage, but completely fail under load.
    I’m curious how others here measure real battery health, and whether anyone tracks amp-hour capacity or drop under high current.
    I’ll be happy to share some of my own testing results and methods.
    Let’s talk amps, not just volts. ⚡
    — Your Battery
    51,224
    isn't the best way with tech stream while driving?
  3. ChapmanF
    17,435
    Seems like people have been talking amp-hours since the earliest battery-reconditioning posts I ever saw around here.
    Brian1954 likes this.
  4. Hayslayer
    Hayslayer Member
    227
    119
    Step one: there's ten thousand posts on this topic that you could catch up on........
  5. T1 Terry
    T1 Terry Active Member
    774
    411
    The first question when testing for Ah is the load the testing should be. No point in the lead acid high load test, depending on the chemistry, NiMh in this case, the load current can be huge, enough to destroy the testing machine, so the load in amps over a given time will determine the C value, C is the capacity, the number after the C is the number of hrs this battery should be able to provide a current (amps) before dropping below a given voltage .....
    This sort of testing is done at cell level generally, can't do that with a Prius module, because each module is made up of 6 cells, it only requires a single cell to be weak to condemn all 6 cells, so a high C value could destroy a cell that simply needs to be balance charged and most likely, all 6 cells need to be topped up, they refer to it as rehydrating on this forum, so try looking up that topic to get more information regarding that topic, along with forcing the pressure relief valve free so the electrolyte no longer leaks out of the terminal seals ......
    To find the C value, you need the cells to be in their best condition first, so all those steps must be completed first, then we can talk about C values, the cell capacity is only 6 Ah in as new condition, so a C1 test would be possible with 6 cells in good condition, so, get that part sorted first ....
    T1 Terry
  6. HyBatteryMan
    Friday
    A lot of information that confuses me. I understand that inside one cell there are six blocks and one of the blocks can be broken, so the whole cell will break, but I don't care about that, but I care about the whole cell in general. Therefore, if one section out of six inside the cell is broken, it means that you can already consider that the test has passed negatively. The load should be like in the real life of the car. That is, about 40 A, this value is shown by Doctor Plus when you drive and press the brake.
  7. ChapmanF
    17,435
    The terminology is one of the first things to make sure you get right, and that helps everything else be less confusing.
    'Cell' is the smallest unit. It's a standard term. One cell has an anode and a cathode and an electrolyte between them, and the chemistry of the anode and cathode and electrolyte determine its characteristic voltage. For one NiMH cell, that's 1.2 volts, nominal. (Doesn't depend on who built the cell or how big it is or what it looks like, but only on the chemistry.)
    'Modules' are the smallest things you can take the Prius battery apart into. Each module is long and flat and contains six cells. So the voltage of one module is 7.2 volts, nominal.
    'Blocks' are pairs of modules. Because the modules have terminals on both ends and are all wired in series, and all the ECU's voltage sense wires attach to the terminals along one side of the battery, each pair of those adjacent terminals will measure the combined voltage of two adjacent modules, otherwise known as one block. So the nominal voltage of a block is 14.4.
  8. PriusII&C
    PriusII&C Active Member
    393
    133
    San Jose, California
    It looks like one of the parameters used to trigger a P0A80 is the Delta SOC.
    But how does the computer know the SOC of each block? As I see it, the computer can only monitor the voltage (or change of voltage) of each block (amp is the same for every block). Therefore, the voltage is the cricual parameter used by the computer to report the Delta SOC afterall, and therefore the P0A80.
    Maybe C is the root cause, V (or change in V) is the symptom. They are related.
    Of course, maybe I understand it wrong.
    #8 PriusII&C, Jul 27, 2025 at 12:34 AM
