Current State of the Art in Battery Balancers?
Discussion in 'Gen 3 Prius Main Forum' started by jimolson, Jun 21, 2025.
  1. Hayslayer
    Hayslayer Member
    241
    123
    Just in case anyone is looking, the G9510-47063 hybrid battery (2010-2011 probably others gen3 prius) is now available for $1535 new. The 28 modules inside are 100% interchangeable with the Gen 2. You can essentially have a brand new Gen 2 battery, built with the latest Gen modules if you're able to DIY the module swap. You'd probably want to buy a new sensor harness also for about $60.
  2. PriusTech
    PriusTech Member
    108
    63
    Reno
    I'm still learning how to identify bad modules.
    I cleared the P0A80 with a generic code reader and by disconnecting the 12V small battery, it keeps coming back
    The Delta SOC was 40
    All three cycles the battery was charged to 237V - 238V
    I had the metal cover off and a box house fan on top running on medium for the entire process
    The before charge-discharge-balance volt test showed a .05V difference between high and low modules. (Picture on my post #36 above)
    The after charge volt test also shows a .05V diff between high and low modules. (pic attached)
    Haven't done a volt test after discharge, will do so. So any module that is lower than .03V from the highest module is suspect bad?
