Adjustment Required?
Discussion in 'Gen 2 Prius Main Forum' started by George Leatherman, Jul 26, 2025.
  1. George Leatherman
    George Leatherman New Member
    Alamogordo
    My travelings include going over a 5000 ft mountain in 15 minutes. New hybrid battery works great. But at the top or before the battery indication goes into the pink. When this happens I pull over and manually charge the battery as I don't like to drain the battery too much.
    Is there an adjustment or settings that can cause the system to charge the battery more aggressively ?
    The car does well otherwise. On flat ground it never goes below 50% (blue) and charges the hybrid battery well. No problems. New battery this year. Few minor problems (ie.. level sensor for headlights is warn out and occasionally it throws a (bad cat oxygen sensor).
    51,884
    there are not any adjustments available. battery charging is software regulated for efficiency, life expectancy and safety.
    did you buy a new, oem battery from a dealer? mountains can sometimes be a bit of a challenge for prius, especially an old one.
    they are not the most powerful cars in the world.
  3. pasadena_commut
    pasadena_commut Senior Member
    2,609
    771
    Southern California
    I don't recall our 2007 dropping to pink bars going up the grapevine (I5 N of Los Angeles, long steep grade) or on any other long uphill grade. I have seen it in other scenarios when the last pack was on its way out. Maybe use Dr. Prius or another app to check the state of the pack? What it should do is force the pack to charge, at which point the car feels like it has lost half its power, and top speed going up drops.
  4. qmanqman
    qmanqman Active Member
    428
    146
    CO
    Couple questions:
    1. Do you mean purple? The bottom two bars on my screen are purple. Its real easy to get there revving high going up hill.
    2. How do you manually charge your battery?
  5. bisco
    51,884
    put your foot on the brake and floor the accelerator
  6. qmanqman
    428
    146
    CO
    Seems like a waste of time. What would be the reason for manually charging it?
  7. bisco
    51,884
    idk, people do it for various reasons, i never did.
  8. bisco
    51,884
  9. pasadena_commut
    2,609
    771
    Southern California
    It actually does look more (dark) pink than purple to me most of the time. I always drive with sunglasses during the day (and rarely drive at night) and even though they are supposedly just a dark grey they still distort colors somewhat. Red cars, for instance, take on the color of cough syrup.
  10. qmanqman
    428
    146
    CO
    Yep . . . strange indeed. Not really a practical reason. Just a reason. There are probably zillions of them.
