Oil Catch Can, Eliminate that knock!
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by danlatu, May 22, 2017.
  1. Abarnabe
    Abarnabe Active Member
    168
    100
    Netherlands
    I inspected the staus of the hoses and replaced the splicers with plastic barbed ones , I believe the melting point of the splicers is 160 °C, question is how hot will it get in there.
    The hoses provided with the occ kit are choked, without wire mesh and too thin, my advise is to discard them and not waste your time with it.
    The new hoses are advertised as heat and oil resistant up to 240 °c, they are thicker and have a wire mesh which helps not to choke, they are 5 euro per meter on aliexpress.
    I ordered stainless steel splicers, they were advertised as 8 mm, but they actually were 7.3 mm, so too small, I returned them and ordered new 9mm brass ones.
    I also had some 9mm plastic splicers around so I'm using them until the brass ones arrive.
    At the same time I replaced the intake gasked.
    It was about 4 euro on aliexpress.
    #2341 Abarnabe, Feb 1, 2025
    RightOnTime and Mendel Leisk like this.
  2. joeboppppp
    joeboppppp Junior Member
    north miami beach
    Wondering if geographical location changes severity or likelihood of issues
  3. ASRDogman
    ASRDogman Senior Member
    7,571
    3,905
    Not really. It’s the weak pressure for the piston rings and lack of large enough ports on the piston
    for the oil to distribute out.
    Also, doing 10,000 miles oil changes makes it worse. So some say.
    Also, driving in the city with stop/go driving, the engine is on an off a lot.
    Highway drivers have less of an issue because the engine is running constantly.
    Grit and RightOnTime like this.
  4. Mendel Leisk
    41,402
    Which issue in particular?
    For the steady delivery of oil to the intake manifold via PCV, the location of the PCV input might be a factor. Gen 2 took it only from the valve cover if I’m not mistaken. On Gen 3 it mostly from the block, feeds into intake manifold, just below throttle body. There’s also a hose from valve cover to engine air intake (downstream of filter, upstream of throttle body); it doesn’t seem to do much, and no evidence of oil.
    I don’t think geographical location matters, for the PCV oil dump anyway.
  5. wukong sun
    wukong sun Junior Member
    66
    me
    My PCV rubber hose is clean, but there is a spoonful of oil under the throttle.
    I try to understand that the crankcase is positive pressure ventilation and the valve cover is negative pressure.
    1 Cold start will spray a lot of gasoline
    2 Ethanol gasoline
    3 Oil evaporation Oil quality is also critical
    4 Blowby
    5 Frequent start-stop in the city or too short daily driving distance is not conducive to evaporation
  6. PTS
    PTS Member
    89
    39
    Austin, Texas
    2013 Prius v wagon
    Is this a question, comment or tutorial?
    Brian1954 likes this.
  7. RightOnTime
    RightOnTime Senior Member
    789
    1,657
    183
    Kidnapped in OC, CA
    Burna J likes this.
  8. NutzAboutBolts
    NutzAboutBolts Senior Member
    1,693
    1,739
    Bay Area
  9. RightOnTime
    789
    1,657
    183
    Kidnapped in OC, CA
    Just use some of your YouTube $$$ with your 84.5k Subscribers JK
    This is a high grade aluminum bracket that was cut from a square aluminum piece. Due to tariff Prices going up this is the lowest that they can offer.
    Can you post a picture of your 3d printed bracket that was installed 7 years ago? Just curious to see if the plastic mount did not get warped from all the heat from the engine bay.
    NutzAboutBolts likes this.
  10. NutzAboutBolts
    1,693
    1,739
    Bay Area
    :ROFLMAO::ROFLMAO::ROFLMAO: Yeah it’s not warped from the heat, it’s just dry. I’m sure that aluminum piece is of high quality, but the 3d printed piece is still good after all this time. I’ll take a picture of it when I do my next oil change.
    RightOnTime likes this.
  11. ASRDogman
    7,571
    3,905
    Less than $1 to 3d print it. And they make different types of filament that will hold up against
    the heat.
    And where it's placed, you have cooler air blowing over it....
  12. NutzAboutBolts
    1,693
    1,739
    Bay Area
    you know, just for that, I might order one from you so I can send my subscribers to the place to buy the bracket. :ROFLMAO::ROFLMAO::ROFLMAO:
  13. RightOnTime
    789
    1,657
    183
    Kidnapped in OC, CA
    Maybe it’s California weather? Last 4 we replaced looked pretty bad. Not as bad as the ‘Mike 2&$’ brace we saw on a car last week Inside PC joke
  14. NutzAboutBolts
    1,693
    1,739
    Bay Area
    :eek: It’s possible, it all depends on the driver :ROFLMAO:. The aluminum definitely would blend in well with the engine bay.
  15. Mendel Leisk
    41,402
    It’s appropriate for one particular location.
    I chose another location, mounted atop lower cross beam. This is the first, for single can:
    I subsequently went to 2 cans, similar bracket wider upstanding leg obviously. You can just see it:
    for anyone considering this: that beam flexes when the front jacking point is used, so you want a compressible gasket between bracket and beam.
  16. Grit
    Grit Senior Member
    6,573
    4,226
    Wilkes Land
  17. Grit
    Grit Senior Member
    6,573
    4,226
    Wilkes Land
    Raytheeagle and I went with a corn can that uses a can opener to open. we drilled holes on the can and zip
    Ties and strapped it to the beam. Put the catch can inside the can and I drove off, still holding it down since 2018
  18. NutzAboutBolts
    1,693
    1,739
    Bay Area
    :ROFLMAO::ROFLMAO: We got some creative people in here lol.
  19. Mendel Leisk
    41,402
    Easy, just temporarily remove can and bracket, push pex style 3/8” splicer (easier to remove than barb) between the 2 loose hose ends, tuck it all down where the sun don’t shine.
  20. RightOnTime
    789
    1,657
    183
    Kidnapped in OC, CA
    This
    iPhone ?
