2007 Prius. Hybrid battery (original) failing...
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Danica, Aug 6, 2025 at 7:04 PM.
  1. Danica
    Danica Junior Member
    31
    True, and true. But I just heard back from the dealership. Apparently all the lights came on and the triangle appeared while he had the car out for the test drive. After 35 miles in the heat. So I may have to pony up for the 12V AND the hybrid batteries to be replaced. Crap, crap, crap. The new 12V has already been installed.
  2. JC91006
    JC91006 Senior Member
    16,704
    8,532
    This is very typical of how dealerships/any trade works. They replace the easy money items they deemed "failed" and not address the real issue so they know you'll be back.
    It's like calling an AC tech to your house when it's 110 degrees, you'll agree to anything they say is wrong with your AC. They'll replace 5 parts when all you needed was 1
    Danica likes this.
  3. Danica
    31
    Maybe so. But he sent me a text with a photo of some test they ran on the 12V battery, showing it had failed. At the time, the car was not throwing any other codes, and he said that a bad 12V could cause the P3011 code. So at the time, it seemed like the right decision to go ahead with the 12V installation.
    I just got off the phone with him, and he said the triangle came on just as they were pulling into the dealership. He said the car is now showing two codes: P0A93 ans C1241. The first code is for the inverter cooling water pump (the thing Hayslayer warned me about), and the second code is for the hybrid battery.
    He said that MAYBE if the inverter water pump issue is fixed, that will resolve the apparent issue with the hybrid battery . But he wants to run more testing -- which he said I am not being charged for -- and the tests will all have to wait until Monday morning. He also mentioned something about "before you sink any more money into this" so I didn't get the feeling he's just trying to get as much money as he can from me.
  4. pasadena_commut
    pasadena_commut Senior Member
    2,344
    700
    Southern California
    Failing when hot is typical of P0A93, but it wouldn't normally take half an hour in 115F heat. A couple of minutes tops, or maybe a minute on the highway. The code can mean other things, any of which make the inverter overheat. In this particular case I suspect that the same thing will be happening after the pump is replaced. Make them check for low coolant and fan problems. "Failed when it pulled into the dealership" could mean "the cooling fans didn't come on when we stopped moving".
    Edit: maybe post the picture of the 12V battery report. If the 12V is not fully charged when a battery test is run the tester may fail it even though it would pass when the same battery was charged. That said, it wouldn't be surprising if the 12V had given up the ghost - high heat kills 12V batteries.
    #44 pasadena_commut, Aug 9, 2025 at 8:42 PM
    Danica likes this.
  5. Danica
    31
    Thanks for the advice. I hope this works.
  6. Brian1954
    Brian1954 Senior Member
    1,878
    739
    South Central PA, USA
    Code C1241 is not about the hybrid battery. The code is detected by the ABS and Electronically Controlled Brake System. The description for the code is "Low Battery Positive Voltage". The 12 volt power supplied to the brake booster is lower than it should be. Do a search for C1241 code in this forum.
    Danica likes this.
  7. Hayslayer
    Hayslayer Member
    266
    147
    Your situation is hurting my heart. That pump costs me about $140 at a dealership. It takes about an hour or less to replace by removing the driver headlight for access. It's been a while since I checked dealer pricing, but a few years ago, they charged around $600 for this job. I can only suspect it's gotten worse. I really hope they're not going to nickel and dime you to death or convince you it's a money pit and you should get a new car. A 130k mile Gen 2 is a diamond in the rough.
    and the 1241 was probably caused when they did the 12v battery swap..they probably disconnected the brake backup power supply while swapping the battery. Hopefully they reconnected it.
    Danica likes this.
  8. Danica
    31
    Thank you. The guy at the dealership quoted me a price of $850-$900 to replace the inverter pump. Rest assured I will NOT get the job done there, at least not unless he significantly drops the price, which I very much doubt he will do.
    Thanks to you and Brian1954 for altering me about the C1241 code, I have been trying to research this and yes, I believe you are probably right that this may be related to the new 12V installation. I will bring this up to the dealership guy when I talk to him Monday.
    I have been warned that the dealership will probably offer me $500 to take the Prius off my hands and tell me I'm better off with a new car. I won't be surprised if they do this.
    Once again I am getting a little ray of hope that maybe the hybrid battery hasn't gone bad after all.
    The dealership guy wants to run more tests on Monday, and he promised I will not be charged for these tests. So at present I figure let's run the tests, see what comes up, and go from there. But unless the dealership offers me some kind of amazing deal on the needed repairs, I am very strongly disinclined to let them do any more work on my car. I've already paid too much for the new 12V.
    Thanks again for all of your help and advice.
  9. pasadena_commut
    2,344
    700
    Southern California
    I'm not familiar with the tool they used. There are DCA-8000 manuals on the web but the one I looked at did not say what it meant by "Ah replaced" or exactly how that test was performed. If that voltage is after the charge then yes, that was a bad battery for sure. I don't see how they could have managed 16.2 "Ah replaced" over only 54 minutes without subjecting the battery to around 16 Amps, which is way, way, way over its specified max of 4 Amps. ("Ah" is "amp hours" - integral over time of input amperage. There is a correction for charging or discharging at high currents but I don't think it would make 4A look like 16 A) It would have been fine to discharge 16.2 Ah out of the battery in a relatively short period though.
    Danica likes this.
  10. Danica
    31
    I have absolute faith that you know what you're talking about, but all the information on that image, and everything you just said, is way over my head, lol. It's like I'm watching an episode of Star Trek where they're talking about a resonant frequency field to contain a graviton wave for the photon torpedo guidance system. It's all Greek to me.
    At any rate, the deed is done and they've already put in the new 12V battery. But, lesson learned. Unless they give me a great deal on the remaining repairs, which I strongly doubt they will, I will look elsewhere to have the rest of the work done.
  11. Danica
    31
    UPDATE 2:
    Just got off the phone with the dealership guy. He told me their technician stayed late on Friday to run the diagnostic tests that were originally slated for this morning. And the new tests show that the ONLY thing wrong with my Prius is the inverter cooling water pump. He told me that if I get the pump replaced, my Prius should be good to go. He quoted me a price of $877 to get a new one installed.
    I asked about the C1241 code, and if it could have been caused by the 12V battery swap. I believe it was Hayslayer who mentioned the possibility that the technicians disconnected the brake backup power supply and perhaps forgot to reconnect it. I asked about that specifically, and dealership guy said it was a possibility, and he would look into it, but in general he didn't think the code had anything to do with the 12V. He said he thinks the bad inverter pump is actually causing the C1241 code. Something about the electrical system.
    I also asked about the P0A93 code, and if it could have been caused by low coolant or a fan problem. He said no, their tests show the inverter pump is just bad.
    Dealership guy thinks the car is drivable for short distances in the early morning. We're in the middle of a heat wave here, and our LOW temps in the early mornings are in the low-mid 80s F. To drive the car home, or to my regular mechanic, would be at least a 30-minute drive on some busy streets, and probably through some heavy traffic. A tow to my regular mechanic would be about $150.
    I told dealership guy that I wanted to look at other options for fixing the inverter pump, given that their pricing is not exactly competitive. Dealership guy was not happy, but said he understood. He tried to sweeten the deal a bit by saying they could give me a ride from my house to the dealership (I am outside their normal range for this service) which would save me maybe $30 on an Uber.
    My regular mechanic (not the one who told me the 12V was fine) doesn't open for another 30 minutes. I'll see what he has to say about this, what price he quotes me for the work, and if he can even do it soon.
    Since the hybrid battery is apparently OK, I am anxious to start driving the car again soon, and get it out of the heat.
    Much depends on what my regular mechanic says, but if his price isn't THAT much lower, or if he cannot do the work for a few days, I would consider just getting it done at the dealership. In its current condition, driving the car to the mechanic shop in heavy traffic would be nerve-wracking for me, so I'd probably opt for the $150 tow.
    Anyway, thanks again to all of you for all of your help and advice. If anybody has any additional advice or suggestions, I would be grateful.
  12. saneesh8
    saneesh8 Member
    146
    37
    Allen, TX
    Replacing the inverter pump (G9020-47031) is easy. This was the first thing failed on my first trip from local dealership to home. The part, it was $150 (this happened last year) and now it is $166. Your local mechanic should be able to do it easily. It is a straight forward job. Remove headlight or move the inverter little bit and can be taken out easily. Just buy a gallon of coolant also and replace the coolant while doing it. Here is what i did. May be you can suggest it to your local shop
    1. Drain the inverter coolant from bottom
    2. Replace the pump
    3. Fill coolant and follow YouTube on how to bleed it. It is pretty easy to do it.
    Try not to drive in this condition for long distance.
    Good to know that the hyrid battery is still good.
    Danica likes this.
  13. Danica
    31
    New wrinkle.
    I just got off the phone with my regular mechanic. He suggested I go ahead and get the job done at the dealership, because "it's their diagnosis." I got the impression he is worried that if his shop does the job, and the car still has problems, he will have a headache on his hands. He was reluctant to even give me a quote for the inverter pump, and promised to call me back later.
    FWIW, I've been going to this mechanic shop for over 20 years, and I've always been happy with their work, and the shop has great reviews in general.
  14. saneesh8
    saneesh8 Member
    146
    37
    Allen, TX
    May be he is researching on how it is done. For a shop, this is easier than a water pump. Bunch of videos on how to do it. May be he can watch few and fix it. Since you know him for long enough, you can suggest him.
    Danica likes this.
  15. Danica
    31
    Anything is possible, I suppose. It's a big repair shop with several mechanics on duty every time I have gone there. When I called this morning, the shop had just opened and he said he was swamped with waiting customers, and he would call me back after he had dealt with those customers.
    I get the impression he is very skittish about doing any work related to the hybrid battery. For example, if the car still has issues after replacing the pump. The shop didn't used to be like this, and there hasn't been a change of ownership. I wonder if they had a bad experience with working on another hybrid car?
  16. JC91006
    16,704
    8,532
    For anyone that is following this thread, this is where we all caution about the Stealerships that we are suppose to trust. Danica's initial problem has always been the inverter pump. This failure happens regularly on these cars over 100k miles. The initial diagnosis should have picked up code P0A93 from the very beginning. Instead they recommended she replace a 12v battery first, without reporting the P0A93 code to her. Only after did they "oh the lights came back on at the very end of our test drive BS". This is a legitimate complaint for the dealership service manager about this practice.
    The P3011 weak battery is most likely due to the car sitting for a short period of time, since this battery is 18 years old, the imbalance from the modules caused this weak code to appear. So this battery is most likely on it's way out but not surprisingly after 18 years of service.
    This car should not need a tow if you are driving in cool weather and under 20 miles. It should operate just as normal until the car heats up, you'll know when the car gets hot because with this inverter pump failure, your AC system will cut out and won't work until the car cools again.
    Danica likes this.
  17. Danica
    31
    I am so grateful for all of your help and advice, and I hope you won't be too annoyed with me for saying I'm afraid to drive the car under these circumstances. It is August in the desert, and our low temperatures are in the low-to-mid 80s. By 7 AM, when the dealership opens, it's already almost 90 F. Whether driving home, or to my mechanic's shop, I would need to drive on some busy street and in some heavy traffic, and the drive would be around 30 minutes. I'm an anxious person in general, and I don't want to put myself through this.
    Incidentally, my regular mechanic just called me back and quoted me a price of $650 to replace the inverter pump. That includes putting in new coolant. But he still recommends I get the repair done at the dealership, because he doesn't want to be stuck with fixing a hybrid battery situation if the car still has issues after the new pump is put in.
  18. PriusTech
    PriusTech Member
    145
    75
    Reno
    Congratulations, you found an honest dealer and tech. See if you can get the techs name, he's a keeper.
  19. pasadena_commut
    2,344
    700
    Southern California
    This is one of those instances where the part is $150 (ish, check, what with inflation and tariffs just kicking who knows today), a jug of coolant is around $20, a little piece of tubing, some corks or bolts (to plug hoses temporarily) and that's all that is needed besides a few common tools and the labor. If you are going to change the fluid at the same time skip the corks or bolts, just drain the system, swap the pump, and refill. (Either way one must run the car for a while with a tube on a bleeder valve to get the air out of the loop.) It is a simple enough job that many people here have done their own. So when we see a price like $877 or $600 our response is "Screw that, I'll do it myself" saving $600 or $450, which isn't chump change. The problem is if one can't "do it oneself" even a simple job like this becomes very expensive very fast. Independent car shops have to stay in business, so while their labor rate is generally lower than the dealer's, they generally mark up the parts by at least 50%, which is why those quotes are as close as they are,
    Given the various constraints here, I would look for a mechanic near the Dealer, one that can be reached on relatively empty streets. OP has AAA? They could tow it for free a short distance unless this would count as the same event for a prior tow. Pick up the coolant and pump at the Dealer and then drive over to the mechanic. They probably have one in stock but check, they might need to order it. DO NOT order a pump from Amazon, many of the parts there are fakes and fail quickly. Only get an OEM pump directly from a dealer, although it is OK to have it mailed to you.
    Danica likes this.
  20. Danica
    31
    I'm sure everything you say is true. I would be immensely better off if I knew more about the inner workings of my car, and how to do some of the repairs myself. It's just not my wheelhouse, so to speak. But now that my car is so old, powered by an 18-year-old hybrid battery, I should make more of an effort to educate myself.
    Confession time: I already told the dealership guy to go ahead with installing the new pump. Given that my regular trusted mechanic wasn't that much cheaper, and other factors including the heat and my desire to not let the car keep sitting idle too much longer, I didn't want to spend a lot of time hunting around for other options to save a few hundred dollars. Although you are absolutely correct that a few hundred dollars is not chump change.
    The dealership is right off of a major street. There is no way for me drive home, or to the other mechanic's shop, without driving on that street for several miles. I wish there was.
    I used to have AAA, but allowed it to lapse last year. I should probably consider re-joining, huh?
    Thank you again for all of your advice.
