What's the best way to fix this broken-wire to the 12V battery?
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by priuslyfe, Aug 11, 2025 at 3:50 PM.
  1. priuslyfe
    priuslyfe Member
    222
    55
    There are two white housing that plug into the square thing that goes into the positive side of the 12V battery. The small white housing holds a lone white-wire going into the 12V battery. It is to the left of the larger white housing that holds a thicker wire-bundle.
    Prius still starts and runs however there is a small red car-symbol on the main center screen and everyone once in a while it'll say "PROBLEM".
    1. What is this small white-wire for?
    2. What is the best way to fix it? I know I need to trim and fit the existing white-wire and clamp it in there but not sure how to do it without breaking the white plastic housing (does that matter).
    3. i plan on fixing it immediately but it is that necessary or can i put it off til tomorrow?
    Thanks for your advice.
  2. Tombukt2
    12,403
    2,198
    Go to a car extract the piece with a wire hanging out plug it to your business user red squeeze connector and you're done or could cross wind it solder it and shrink wrap it
    priuslyfe likes this.
  3. priuslyfe
    priuslyfe Member
    222
    55
    thanks. I was hoping I could take it out of its housing to make sure its secure, but I'll try with needlenose pliers.
    Do you know what that white-wire is for? Can i drive it without fixing it. Kinda a busy day and might not be able to get to it til later.
  4. Tombukt2
    12,403
    2,198
    It keeps the car from doing something I can't remember what right now charging sensing etc . They're a tool set that ll allow ya to remove the insert out of white plug Assy I have a key ring full of em
  5. ChapmanF
    17,559
    The small white wire senses the voltage right at the battery, so that the converter at the front of the car can regulate its output to accurately hit a voltage target at the battery.
    If you look on this page, under Electrical Wiring Diagram, you will find two useful things:
    • You'll learn about the Wire Harness Repair Manual, which is not paywalled. It doesn't have the latest precise information about your model and year, but it will answer your general questions about how to extract the old terminal from the housing, and how to make a proper and properly-protected parallel crimp repair to Toyota's standards.
    • You'll learn about the Electrical Wiring Diagram for your car model, which will give you specific information like the Toyota part number for the proper repair terminal and for the parallel crimp sleeve to use with it. Scrolling down the page, you'll see your options for getting access to the EWD.
    It's a little disappointing that most generic auto parts stores carry butt crimp splices instead of parallel ones. The ones you buy at a Toyota dealer are proper parallel splices, or you can get them from TE Connectivity.
    When you go to a Toyota dealer to buy a "repair terminal" (using the part number you find in the EWD, or asking the parts-counter person to find it for you since they already have access), you get the proper terminal to click into that housing, preattached to a short length of wire so you can splice that to the good part of your car's existing wire.
    If there is a salvage Prius near you where you can extract that terminal and cut its wire a few inches up to take it with you, that's essentially the same thing. It might be easier and cheaper than buying at the dealer, if you have convenient access to a nearby salvage Prius. If not, it could be more trouble than just going to the dealer.
    #5 ChapmanF, Aug 11, 2025 at 4:11 PM
  6. priuslyfe
    priuslyfe Member
    222
    55
    thanks.
    Does it need to be fixed immediately or can I drive like 10 miles without this issue resolved?
  7. ChapmanF
    17,559
    It'll be ok; the converter just puts out a default reasonable voltage instead of tailoring it accurately to what the 12-volt battery needs.
    I didn't remember whether a gen 2 will actually drive in that condition. Good to know that it only reports the error, and doesn't balk at driving.
  8. priuslyfe
    priuslyfe Member
    222
    55
    UPDATE: FIXED!
    Initially the wire broke while I was driving due my battery being unsecured with the bolts/clamps. Probably had been slowing moving back and forth over many miles and finally snapped. That said, the wire itself seems like the thinnest-gauge; don't understand the logic in using wire that can break so easily.
    Started to try to fix the white wire/housing but soon figured out you need the dexterity of a Swiss watchmaker to do so. THEN i thought...."Do I still have that wire bundle on my wrecked PartsPrius?", and sure enough I have it. I then cut it off the positive-terminal bundle, left the plug-in alone and twisted it onto the existing wire that snapped.
    TL;DR: Keep a wrecked Gen 2 Prius in your backyard so you can get parts as needed
  9. dolj
    dolj Senior Member
    8,265
    4,214
    Wellington, New Zealand
    To make a good repair, you need to get a butt crimp and crimp those two wires together.
  10. Mendel Leisk
    40,748
    Or solder?
    I appreciate crimped connectors are effective and widely used as well. I’ve got a butt connector assortment and decent crimp tool, but usually resort to solder and heat-shrink tube, less bulky, more seamless looking.
  11. ChapmanF
    17,559
    For whatever reason, butt crimp connectors have usually been what's easiest to find in general auto parts stores.
    Toyota doesn't use butt crimp connectors, but parallel crimp connectors, where the two wires being spliced are in direct contact with each other inside the crimp. If you go to Toyota and buy the crimp connector by part number that you see listed in the Electrical Wiring Diagram next to your repair terminal, that will be a parallel crimp connector. Elektroingenieur also kindly wrote a post showing suitable connectors from TE Connectivity.
    Toyota, like other auto/marine/aerospace manufacturers generally, won't use solder on flexible stranded wires that are subject to vibration. Crimp connections exclusively there. They do use solder, of course, on PC boards and inside modules where everything is rigidly fixed in place.
    priuslyfe and Mendel Leisk like this.
  12. dolj
    dolj Senior Member
    8,265
    4,214
