Best spark plugs for 05 Prius
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by shepdawg, May 14, 2014.
  1. douglasjre
    douglasjre Senior Member
    2,121
    704
    Null, NL
    Chinese fakes from Amazon will grenade your engine
    Metrolens likes this.
  2. T1 Terry
    T1 Terry Active Member
    816
    425
    I very recently replaced both the plugs and coils on my V10 6.8 ltr Ford chassis motorhome. Near fell off my rocking chair at the cost, the plugs were more than the coils :eek: ...... but chalk and cheese on the first hill, and even on start up. The old ones had done 176,600 kms (roughly 110,000 mile).
    Remember to put some thread lubricant on the plugs befor you install them, they will be there for the next 100,000 miles so you don't want the thread coming out with the plug .....
    The gen 2 1500 goes for ever, if you look after it, my ex taxi Prius had 750,000kms on it, it wasn't the motor that took it off the road, needed parts for my other Prius on a holiday weekend where no one had front pads and rotors .... then the new NiMh battery got transferred to the other Prius ..... and that was about the end of it going back on the road ....
    T1 Terry
  3. Mendel Leisk
    40,755
    Not knowing for sure if they’ve ever been changed, yeah change them. Instead of gambling to save a few bucks, get them from dealership or reputable, local auto supply place. Stick to the stock plug (spec’d in owner’s manual, and attached).
    Repair Manual makes no mention of lube, and it complicates things, specifically torque.
    You can check the gap, but the plug manufacturers recommend to not adjust. If it’s off they might have been dropped or something.
    In particular when installing the new plugs, if you’ve got an especially grippy spark plug socket, it’s prudent to tape the extension to socket, otherwise the socket may stay on the plug when try to pull it off.
    #23 Mendel Leisk, Aug 14, 2025 at 9:05 AM
