B2430 LED Headlight LH
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by ToyotaCoyotta, Aug 24, 2025.
  1. ToyotaCoyotta
    ToyotaCoyotta Junior Member
    56
    Lithuania
    Hello, I have the following DTC Fault on my prius, It always says check headlight system on the dashboard and the yellow triangle keeps flashing, its getting annoying.
    im not sure where is the issue because
    both of the headlights work fine.
    I tried changing the xenon module for that headlight because i have a spare one but it didnt help, so where exactly the issue is ?
    Can you please confirm if LH means the left hand headlight?
  2. Tombukt2
    12,898
    2,315
    Left hand as far as I know in fuse box on most they're lh and rh headlite fuses well in many . This model halogen had wiring issues in this systrm do not know about LED models other than not very repairs le and costly no aftermarket support yikes . And youve a spare board .
  3. Tombukt2
    12,898
    2,315
    Did ya watch mid East video of the guys working on you're model they messing with fuse box a yellow wire off board and a test light . Look carefully at his wiring laying on fender to that module something between fuse box and module kinda like gen2 p conn error . So e kinda jumper or such but it working . Cool scanner he has brings up manual diagrams on fly automatically can't see name of tool .
  4. ToyotaCoyotta
    56
    Lithuania
    still need help :(
  5. ToyotaCoyotta
    56
    Lithuania
    can you send me link ?
  6. Tombukt2
    12,898
    2,315
    H crap let me get it for ya .
  7. Tombukt2
    12,898
    2,315
    You get a kick out a this you got a watch real close if you've a huge monitor use it
  8. Tombukt2
    12,898
    2,315
    I'll get one of my buddies if I can this afternoon to translate it for me I'll try n record his translation
