Low battery message after inflating tires while charging
Discussion in 'Gen 5 Prius Technical Discussion' started by bob12345, Aug 24, 2025.
  1. bob12345
    bob12345 New Member
    22
    Knoxville, TN
    2024 Prius Prime
    SE
    A little background info:
    I had my car charging for around two hours and state of charge at around 45%, then I decided to add some air to all (4) tires at around +2 - 5 additional PSI, with the vehicle still charging on level 2.
    I turned on the "Accessory", filled up one or two tires within 10 minutes before the Accessory turned off automatically. I did not look up at the MID screen at this time so possible the message was there at this time.
    Turned accessory back on and filled up the remaining tires.
    I estimate the entire process took no more than 15 minutes.
    Note: Owners manual does state Accessory does turn off automatically after 20 minutes.
    Then when I entered the vehicle, still charging on level 2, I received a "Low battery" message on the MID screen per attachment.
    Vehicle started in EV mode without issues, but I find this interesting since I thought while charging the vehicle, the 12 volt battery was also receiving a charge? Maybe the 12 volt battery does not charge while the 12VDC outlet is in use? I find the message surprising since the vehicle was plugged in while I was using the 12VDC outlet to inflate the tires by a small amount.
    #1 bob12345, Aug 24, 2025
    51,541
    you were using way more juice than the 12v was receiving. in the future, only use acc with the car ready, or get a 120v compressor.
    the prius battery is small, and the charging system barely adequate for normal use. you should probably put a charger on the battery since it ran low enough to trigger the warning, or leave it in ready for a long time.
    schja01 and BiomedO1 like this.
  3. BiomedO1
    3,156
    1,670
    SacTown, Ca
    The DC-DC converter is ON while actively charging to ensure power to fans and control units charging the car. Some would say that the aux. battery is getting a charge; just because the 12VDC line is active. I don't know how the gen5 systems are programmed to respond - but I wouldn't classify it as receiving a 12VDC charge. Some people here has watched and charted those cycles and the 12VDC current varies a lot. When you pumped up the tires, did you use a cigarette lighter powered tire inflator? In other words, pull a high current off of the 12VDC line?
    That's why we say, NEVER use the accessory mode and place the car into ready mode. In ready mode, ALL systems and ECUs are active, so a higher 12VDC current draw would be compensated for. The system would ramp-up 12V power on demand. Don't know if it'll do that while the traction battery is charging, because that ECU may be asleep.
    You should probably get your aux. battery checked out and recharged, if needed.
    Hope this helps
    I find my 12VDC battery below 11.75 volts about once a year. I place it on a charger for an hour or two and it's good for another year. It has never failed to start. I believe that data point is below 10.75VDC.
    #3 BiomedO1, Aug 24, 2025
    PrimeDan likes this.
  4. Paul Gregory
    Paul Gregory Senior Member
    1,987
    505
    Alberta
    2024 Prius Prime
    XSE
    I never use ACC. It's always better to use READY mode.
  5. bisco
    51,541
    and you can't do that while charging, so it's an either/or situation
    BiomedO1 likes this.
  6. Paul Gregory
    1,987
    505
    Alberta
    2024 Prius Prime
    XSE
    Mine goes into "Room Mode" which allows you to use power with the DC converter on.
    #6 Paul Gregory, Aug 24, 2025
    otatrant likes this.
  7. bisco
    51,541
    that's cool!
  8. bob12345
    bob12345 New Member
    22
    Knoxville, TN
    2024 Prius Prime
    SE
    1). I used a 14-15 max amp draw compressor through the 12VDC outlet. Yes, I understand the manual states to not exceed 10 amps.
    2). From the comments above and reading through other threads, my lesson learned is to inflate the tires with the vehicle in an "ON/ready state" since that is when the DC-DC is converter is powered on from the high traction battery.
    I really like this video that explains it at 11:30 time stamp for the 4th generation with actual data.
    3). I didn't have any issues starting the vehicle after the error message so the 12volt battery still had enough charge to start the hybrid system.
    Later in the day, I hooked up a OBD-II dongle to check voltage and voltage was at 12.5V. This was after the vehicle sat for two hours during another level 2 charge session and not in ready mode.
    I will later check voltage again after my daily commute in 100% EV mode since in theory, the 12 volt battery should be charging during that drive as well. TSB T-SB-0025-23 Rev 1 does state 12.6V and above does not require a trickle charge. The same TSB does state the vehicle should stay in "Ready" mode for 30 minutes with all lights and accessories off and HV battery charging. I'm guessing this is enough to charge the 12 volt battery enough as well.
    #8 bob12345, Aug 24, 2025
  9. Paul Gregory
    1,987
    505
    Alberta
    2024 Prius Prime
    XSE
    I was guilty of occasionally blowing the 15 amp fuse to the lighter socket. I installed a 20 amp circuit breaker instead. I'm not worried about it in the slightest.
  10. BiomedO1
    3,156
    1,670
    SacTown, Ca
    You need to use a DVM, turning-on the car also powers up the DC-DC converter; rendering your voltage measurement meaningless. Someone here was trying to say their battery was OK when measuring the 12VDC through the cigarette lighter outlet. Well on a gen4 that's on a relay that turns-off with everything else, so turning on the car will also wake up the DC-DC converter.
    YMMV
  11. Gokhan
    Gokhan Senior Member
    5,923
    2,339
    Paramount CA
    You should get this so that you could monitor and record the 12-V-battery voltage continuously:
    BM2 battery monitor on Amazon
    The ON mode does not charge or float the 12-V battery. It is similar to the Accessory mode.
    The READY mode turns on the DC–DC converter but does not necessarily charge the 12-V battery. It keeps it at a float voltage (13.53 V at idle or 12.89 V while driving) for most of the time. You need close to 14.0 V for charging to happen. The 12-V battery management system (BMS) has a very complicated and buggy algorithm that decides when the 12-V battery should be charged, even when the car is in the READY mode. The BMS controls the DC–DC converter voltage.
    For a flooded cell, 100% SOC is about 12.64 V, and for an AGM, it is about 12.89 V.
    It is interesting that the car turned off the DC–DC converter when you switched into the Accessory mode. It is on in the OFF mode during active traction-battery charging.
    So, yes, you will learn a lot more if you install a battery monitor.
  12. Paul Gregory
    1,987
    505
    Alberta
    2024 Prius Prime
    XSE
    I have a VGate battery monitor. It's not much help, but it does track the small changes in battery voltage.
  13. Trollbait
    12,438
    Does the car actually keep charging when set to Accessory mode? Or does it stop and the EVSE cut power to the car?
  14. Paul Gregory
    1,987
    505
    Alberta
    2024 Prius Prime
    XSE
    Everything in my experience with my Gen 3 and Gen 5 says that ACC mode will not charge the 12V battery.
  15. Gokhan
    5,923
    2,339
    Paramount CA
    I would guess it still charges the traction battery while the driver listens to the radio etc. It probably does not go into the READY mode until you unplug the cable.
  16. Paul Gregory
    1,987
    505
    Alberta
    2024 Prius Prime
    XSE
    No need to guess. It provides you with all the interior services while the hybrid battery charges. There is a gauge to indicate the portion of power going for each usage. Of course, you can't drive with the charge cable connected.
  17. Gokhan
    5,923
    2,339
    Paramount CA
    He is asking about the traction battery.
    And what would that gauge be? Could you post a pic so that we can learn about it?
  18. bisco
    51,541
    sounds like the car gives the 12v warning before it gets too low, which is a good thing.
  19. Gokhan
    5,923
    2,339
    Paramount CA
    Only in the accessory mode per the manual.
    Do you really get 5.9 mi/kWh with your Bolt EUV?
  20. bisco
    51,541
    yes, but i only do local driving and highway once a week. most see around 4 if they do mostly highway, depending on driving style and conditions. it has a terrible cd
    Gokhan likes this.
