Red Triangle and no codes. Help!
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Raghav, Aug 25, 2025.
  1. Raghav
    Raghav Junior Member
    44
    My 2006 prius has a reconditioned battery and has been running fine. Recently when I was driving, the red triangle came on (and small red car on the console). No check engine light though. I immediately returned home and switched car off and on. Now triangle and all lights in the dash was on, including check engine light. I used an OBD II scanner (not the bluetooth one, a decent one). However, it did not show read any codes. In frustration, I used clear code option, and triangle and other lights went off.
    I think I should have used the techstream, but didn't occur at that point. I have to wait till the triangle comes back now I guess.
    Now it is driving ok, but I am hesitant to use it normally. I initially thought it may be hybrid battery, but battery seems fine, holding charge and works as it used to, drives quite a distance at low speed on battery without dropping charge rapidly. I checked the oil and coolant. Coolant reservoir was close to empty, but the coolant tank had sufficient fluid. I topped up the coolant reservoir, and got the coolant circulation checked with a mechanic. Oil level is fine.
    Is there anything else that can cause red triangle? How do I troubleshoot?
    I got the front bearing hubs and brakes replaced recently by a local mechanic (he is good at what he does). Could anything have gone wrong with that procedure?
    Thanks in advance!
  2. PriusCamper
    PriusCamper Senior Member
    12,736
    5,151
    Pacific Northwest, USA
    Let us know what type of device you're using to read the error codes?
    Also go back to mechanic and ask them to connect these two pins in the OBD2 port together so he can read the blink codes because sometimes no error codes and red triangle mean brake problems that require reading the blink codes.
    If red triangle comes back before you visit him, then you can:
    1. Short pins 4 and 13 of the OBDII port and then make car Ready.
    2. Press the brake pedal 8 times within 5 seconds.
    3. lights should go off if no problems remain.
  3. Brian1954
    Brian1954 Senior Member
    2,187
    859
    South Central PA, USA
    Odds are that the red triangle will return if you drive the car. Once the triangle returns, use Techstream to check for codes. If you get the P0A80 code, take a picture of the freeze frame data and post it here.
    There are over one hundred different problems that can cause the red triangle to be activated. Begin troubleshooting by getting the trouble codes using Techstream.
  4. Brian1954
    2,187
    859
    The red triangle comes on when there is a problem with the hybrid drive system in the Prius. The problem could be the inverter, hybrid battery, MG1 or MG2 electrical motors, etc, etc. The trouble codes will give you a clue what the problem is. Techstream will give you the trouble codes so that you can start to fix the problem.
  5. ChapmanF
    18,149
    Yes, there often will be brake codes at the same time, but as the result of the hybrid system lighting the red triangle, not as the cause.
    The hybrid system and the brake system communicate (because regen braking calls on them to cooperate), so the brake system knows when there are hybrid system trouble codes. The brake system then sets its own codes, C1259 / C1310, which mean "there are hybrid system codes, go look at those".
    If you read the blink codes, C1259 shows up as 58 on the ((!)) light, and C1310 as 51 on the skiddy-car VSC light. Naturally, there's little point trying to clear those as brake codes. Given that they mean "there are hybrid system codes", they'll go away when those are dealt with.
    Brian1954 and PriusCamper like this.
  6. mr_guy_mann
    mr_guy_mann Senior Member
    4,045
    1,969
    NJ-USA
    If you have a capable scantool like Techstream, then use it to check all systems for codes. Some systems will keep "history" codes in memory for awhile, even if the fault is no longer active
  7. Raghav
    44
    Thanks for all the suggestions. I drove for 26 miles hoping to get the triangle back so I could run the techstream. But no triangle yet. I will try running the techstream anyway today as mr_guy_mann suggested and post the results later in the day.
    Brian1954 likes this.
  8. PriusCamper
    12,736
    5,151
    At this point it'd be wise to keep a cheap $20 OBD2 reader like this one in your glovebox: http://www.ebay.com/itm/265484403768 You'll be able to use Dr. Prius and other apps to monitor vital signs of your battery pack in real time as well as clear red triangles for the most common problems a Prius has. It's way less clumsy and slow than Techstream on an old laptop.
  9. Raghav
    44
    I ran techstream. The only code i found was P0420 for catalytic converter inefficiency (the check engine light comes and goes, at this moment it is off). No other codes.
    I guess i have to drive till I get the red triangle back.
    Edit: 50 miles, still no luck. Check engine light is back with P0420 though.
    #9 Raghav, Aug 27, 2025
  10. saneesh8
    saneesh8 Member
    184
    46
    Allen, TX
    I think you have to wait for it to come back. It could be the Inverter coolant pump and weather may be making a difference and not causing the condition. Can you check the inverter coolant reservoir for coolant movement?
  11. Raghav
    44
    Finally codes are here. P0AA6, 526 and 612.
    I got the PDF with long list of steps to troubleshoot .Before I start, any suggestions / tips? After I cleared code last time, it ran for 160 miles before red triangle came back. Does that indicate anything?
  12. ChapmanF
    18,149
    An isolation fault doesn't really care about miles traveled, but may be more readily detected in some environmental conditions, like higher humidity.
  13. Raghav
    44
    Thanks. The PDF has a flow of "NG" and "OK" at each step. There is no info on how to interpret it. I guess "NG" is equivalent of "Not OK" for the check/condition of that step?
  14. ChapmanF
    18,149
    Or "No Good", yes.
