Low battery message after inflating tires while charging
Discussion in 'Gen 5 Prius Technical Discussion' started by bob12345, Aug 24, 2025.
  1. Paul Gregory
    Paul Gregory Senior Member
    1,976
    501
    Alberta
    2024 Prius Prime
    XSE
    Gokhan likes this.
  2. Gokhan
    Gokhan Senior Member
    5,919
    2,338
    Paramount CA
  3. Gokhan
    5,919
    2,338
    Paramount CA
    And also, next time when you do this, you should use the my-room mode, not the accessory mode. To use the my-room mode, turn the power switch to the on position (not the accessory position) and select yes for the my-room mode. Traction-battery charging will continue and the DC–DC converter will remain on.
  4. Paul Gregory
    1,976
    501
    Alberta
    2024 Prius Prime
    XSE
    ACC mode gives you none of these benefits in my experience. I never use it.
  5. BiomedO1
    3,154
    1,668
    SacTown, Ca
    I'm guessing that your talking about "Room-mode"; NOT Accessory mode...:rolleyes::sick::sleep::whistle:
    Ya need to be specific, when your talking about all the different modes in these car and some iterations may not have that option.
    Gokhan likes this.
  6. Paul Gregory
    1,976
    501
    Alberta
    2024 Prius Prime
    XSE
    I was quite clear. I think the problem is at your end.
  7. BiomedO1
    3,154
    1,668
    SacTown, Ca
    You see; this is why your getting warnings from the moderator.
    Who belittling other people NOW!!
    Gokhan likes this.
  8. Mendel Leisk
    40,983
    How about this mode:
    bob12345, Gokhan, bisco and 1 other person like this.
  9. BiomedO1
    3,154
    1,668
    SacTown, Ca
    Looks like a heart attack waiting to happen.o_O:p
    We're mostly overweight Americans.:ROFLMAO::LOL::cry::whistle::giggle:
    Mendel Leisk, Gokhan and bisco like this.
  10. Paul Gregory
    1,976
    501
    Alberta
    2024 Prius Prime
    XSE
    Nope. You have it wrong again.
  11. bisco
    51,535
    BiomedO1 and Gokhan like this.
  12. Gokhan
    5,919
    2,338
    Paramount CA
    Give it up, Mendel. If you had a digital tire inflator, you would never go back to that one. I used foot pumps for many years before I got mine last year. LOL
    The instructions clearly state to run the car while you use the inflator. You are not supposed to use it in the accessory mode. Fortunately, Gen 5 also has a my-room mode when plugged in.
    Mendel Leisk and bob12345 like this.
  13. Hammersmith
    Hammersmith Senior Member
    2,185
    2,190
    North Dakota - USA
    2023 Prius
    Limited AWD-e
    I have to agree on this one. A have a hugely expensive $40 Ryobi inflator that sits in my car full time. It lets you set the desired pressure so you just set it, pop the hose on the valve stem, and press start. Maybe 30 seconds per tire if you're just topping them off in the winter(including unscrewing/screwing the valve caps). Longer if you're filling from empty, but you can just press start and then sit in the car while it works. That's sure a nice option if it's cold and/or raining.
    It's far from the only option on the market, but it's perfect for someone like me that's already got a dozen or more Ryobi tools in the garage and at least half a dozen batteries. I just try and remember to exchange the battery every once in awhile with one of the garage batteries so the car battery doesn't sit at 95% charge forever. I've also got a matching Ryobi impact wrench, so tire changes are a breeze. I even have an adaptor on the scissor jack so I can use the impact wrench to raise and lower it. (haven't had to use it yet, but I'm glad I'm all prepped if I get a flat when it's -20F)
    This is the inflator I have:
    18V ONE+ HIGH PRESSURE DIGITAL INFLATOR
    And I think this is the impact wrench(though I might have a 3/8" one - I don't remember - I think I got it free when I bought some batteries):
    18V ONE+ HP COMPACT BRUSHLESS 4-MODE 1/2" IMPACT WRENCH
    BiomedO1 likes this.
  14. BiomedO1
    3,154
    1,668
    SacTown, Ca
    I've got a no-name one with all the bells and whistles that plug into the lighter.
    Used it several times, when I caught a nail or screw to get me home. Repaired it at home and reinflate. I think it was on-sale for <$30 USD. Used it to inflate a few balls to a specific pressure.
    Gokhan likes this.
  15. Paul Gregory
    1,976
    501
    Alberta
    2024 Prius Prime
    XSE
    I carry a 12V air pump in my car, but I've never used it.
    I just pull up to a tire shop and they check my tires for free.
  16. bisco
    51,535
    i have a regular compressor at home, nothing in the car. just got a jump pack and am considering it, along with a spare tyre
  17. Gokhan
    5,919
    2,338
    Paramount CA
    Definitely carry a digital air compressor in your trunk in case you get a low tire pressure warning etc.
    BiomedO1 and bisco like this.
  18. bisco
    51,535
    we hit a partial truck tyre in the dark on I-95 in savannah last winter. it knocked a plastic aero piece up against the front of the rear tyre in our hycam.
    it was making an awful scraping noise, and i thought something was badly damaged.
    i pulled off the highway and crawled under with a pliers and flashlight and straightened it out.
    mer. b was quite impressed that i had tools under the front seat :cool:
    Gokhan likes this.
  19. Gokhan
    5,919
    2,338
    Paramount CA
    Does any doctor leave home without his/her bag? Does any mechanic leave home without his/her tools?
  20. BiomedO1
    3,154
    1,668
    SacTown, Ca
    Just keep an eye on the black Friday sales ad ect... I'm partial to the cigarette lighter style ones. Yes they have a cord; but my history with battery operated unit is NOT good. Mine lives under the passenger seat. I probably use it once year or every other year. I've got a home compressor for the bigger jobs. If it was battery powered and baking in the car or freezing; don't know if it'll work when you need it. @Mendel Leisk method would probably work; if the o-rings and seals don't dry rot; again baking or freezingo_O
    Just my 2-cents
    Mendel Leisk and Gokhan like this.
