ECU ID code or IMMOBILIZER LOCATION
Discussion in 'Gen 3 Prius Technical Discussion' started by Dxta, Aug 26, 2025 at 12:10 PM.
  1. Dxta
    Dxta Senior Member
    1,934
    769
    Lagos
    Hi people. Been battling with a 2015 Prius, that I need to get the dashboard light, and the ignition to turn on, but without success.
    When I turn on the ignition switch, the dash lights are blank, with only "key not detected" displaying, and the key sign blinking.
    I recently replaced the HV ECU, driver side fusebox, smart key module, etc, because the vehicle was a flooded one.
    I am trying to get access to the ECU ID CODE module, but without success.
    A colleague told me, the ECU ID CODE is behind the AC evaporator. If so, it appears , I need to remove the dashboard again.
    I want to confirm if that is correct. Does anyone has the body main wiring harness, that can point me to where the module is?
    Thanks for the help.
    Dxta
