2012 Prius C AC Drain Tube Location
Discussion in 'Prius c Care, Maintenance and Troubleshooting' started by Sosa, Aug 13, 2025.
  1. Sosa
    Sosa Junior Member
    Utah Valley, Utah, USA
    Hello,
    As the title suggests, I cannot, for the life of me, find the location of the ac condenser drain tube under the car. I can't even find it anywhere online either and it's driving me up a wall. I'm wanting to do a flush for it to remove bad odor. Any help here would be fantastic, thank you.
    51,451
    it's not in front of the firewall like other prius?
  3. Sosa
    Sosa Junior Member
    I thought it would've been and maybe I'm just missing it but definitely having a difficult time finding it.
  4. bisco
    51,451
    might be a free service manual here:english-prius-c-manual-available.102440
    Sosa likes this.
  5. Mendel Leisk
    40,901
    Just editorial, and it may help with searches: the AC "radiator" in the dash is called the "evaporator".
    The drain tube should be findable, likely on right underside. Maybe tucked in behind something. Are you able to raise the car safely?
  6. Sosa
    Sosa Junior Member
    I haven't been able to but I will be able to lift it on a ramp either Tuesday or Wednesday. Should give me a better look and I should be able to find it then hopefully. I'll use information provided by both of you and hopefully it gets me there.
  7. Sosa
    Sosa Junior Member
    Okay, so I was able to raise it better and get under it. If anyone can confirm, this is the A/C evaporator drain tube, correct?
  8. bisco
    51,451
    i think so, is there a drain for the front vent intake grids as well?
  9. Sosa
    Sosa Junior Member
    Not that I was able to find, although I do think it's the same drain if I read it correctly.
  10. rjparker
    9,813
    6,053
    Run the ac on max cool for a few minutes and you will see water dripping out. It is behind the passenger's side inner wheel well close to the firewall.
    Without a shop lift you need to jack up the front passenger side or the whole front end. I used to remove the front passenger's wheel to access the drain hose and then inject the foam cleaner into the evaporator. After a few minutes the foam liquifies and drains out. You then repeat. After a few cans over a two year span the mold does not return.
    Early on I added the drain hose extension which allows access on the ground with the wheel turned as shown. I can reach in and pull the hose toward me to inject foam.
    #10 rjparker, Sep 8, 2025 at 11:22 PM
  11. rjparker
    9,813
    6,053
    Here is a video for a gen2 where the owner pulls the condensate drain into the cabin and injects cleaner foam from there. One comment noted this was necessary if a cat shield was added that blocks access from below. It requires pulling up the carpet.
    The instructions say to inject half the can, let it drain and repeat. This guy appears to use the whole can at once. Since there is no rinsing step, using half at a time is likely more effective.
    The small can of fragrance is not a sanitizer so is optional.
    #11 rjparker, Sep 9, 2025 at 5:17 PM
