2017 Prius Prime Questions
Discussion in 'Prime Main Forum (2017-2022)' started by richard203, Sep 16, 2025.
  1. richard203
    richard203 Member
    265
    56
    SF
    I was wondering is the gen3 prius cat and 2017 prius prime the same? Im asking because the heat exchanger is broken and im leaking coolant out of the exhaust and my friend have a gen3 cat.
    another question do i have to buy the whole center piece or i can just buy the green over lay?
    #1 richard203, Sep 16, 2025
  2. PriusCamper
    PriusCamper Senior Member
    12,665
    5,111
    Pacific Northwest, USA
    They're identical. To confirm do some comparison shopping for catalytic converters for both 'em and see if there's any mention of them being different vs. compatible.
  3. richard203
    richard203 Member
    265
    56
    SF
    I compared gen3 to gen4 they don’t look the same
  4. bisco
    51,823
    i thought gen 4 had less precious metals, which would be a new design, i would think.
  5. BiomedO1
    3,441
    1,792
    SacTown, Ca
    The CATs are different and a totally different heat exchanger setup.
    I believe the grill is a one piece unit from Toyota. You can try to find a used one and separate the front from the rear backing. You'll have to remove the whole front bumper assembly anyways - so snapping in the Toyota unit will speed up the process.
  6. richard203
    richard203 Member
    265
    56
    SF
    do you know whats that part called?
  7. PriusCamper
    12,665
    5,111
    Apologies... I misread that. I thought you were comparing Gen4 regular to Gen4 Prime. There's a definite difference between Gen3 and Gen4 cats.
  8. richard203
    richard203 Member
    265
    56
    SF
    if i buy a used cat is there any way to tell if the heat exchange is working and not leaking?
  9. BiomedO1
    3,441
    1,792
    SacTown, Ca
    Technically speaking; it's illegal to install a used CAT in the Peoples Republic of Ca. (CARB rules). You do you, I'm not going to narc on you. Are you beyond your CARB emissions warranty? Have you checked with your local dealership, because there is a TSB out on this issue - so they may do a courtesy replacement if your nice and slightly beyond CARB warranty.
    You can pressure or vacuum test the exchanger for leaks. Do Not exceed 15 psi; that's about the coolant pressure in your system.
    Good Luck
    #9 BiomedO1, Sep 17, 2025
  10. richard203
    richard203 Member
    265
    56
    SF
    it got 180k mile on it i think the warranty goes up to 150k only?
  11. rjparker
    10,056
    6,222
    It would be easier to bypass it
    Bottom bypass with standard Gates 18777 hose
    Or a top engine level bypass, no parts required but the wiper assembly has to be removed to access hoses and temperature sensor.
    Heater-hoses top right
  12. richard203
    richard203 Member
    265
    56
    SF
    ya im planning to either bypass it from the top. do people leave the metal pipe and the bottom hose open? i was planning to cap it off
  13. rjparker
    10,056
    6,222
    I would cap them off since a leak inside of the heat exchanger could push exhaust gasses out.
  14. BiomedO1
    3,441
    1,792
    SacTown, Ca
    FWIW; Whatever you do, don't make it look obvious that someone has been there mucking around with it. I needs to pass smog and a quick visual inspection.
