2008 won't start after sitting for 2 weeks. CM, ECU, or Hybrid battery?
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by PriusOwner428, Sep 17, 2025.
  1. PriusOwner428
    PriusOwner428 Junior Member
    70
    IL
    2008 sat for 2 weeks while we were on vacation. Upon returning it would not start. Hooked up charger and connected charger cables to the positive post on the fuse panel in the engine compartment and a bolt for ground. Battery is reading 12.4V now, but ignition will not start. Dashboard display is completely dark and shows no life at all when the start button is pushed with the keyfob in the slot. But headlights, horn, cabin lights etc all work. Also, while completely dead, it does show the car door open red LED light and when the start button is pushed without the key in the car it displays the "no key detected" symbol. So the battery is working for all these items but it seems like the ignition has been disabled. Is there some major fuse or other disconnection point that might need to be reset?
    #1 PriusOwner428, Sep 17, 2025
    52,112
    maybe the load on the 12v is too much to close the start up relays. how old is it?
  3. Hayslayer
    Hayslayer Active Member
    421
    249
    I don't remember all the details, but your symptoms sound similar to the AM2 fuse being open.
    PrimeDan likes this.
  4. PriusOwner428
    70
    IL
    Right. And that was the first thing I checked. Visually it looked OK. Tested with a meter & it was good. Had a 6.8 ohm reading so replaced it with a new fuse for good measure. Didn't help.
  5. PriusOwner428
    70
    IL
    Not sure about age. Bought car used 2 years ago and have never changed the battery. But would the start up relays need more power than the headlights and horn?
  6. dolj
    dolj Senior Member
    8,461
    4,297
    Wellington, New Zealand
    There is a short but significant power draw during the start-up sequence. You need to monitor the 12 V voltage while starting up to ensure the car does not dip below 11 V while starting up. A low voltage condition during start-up can set codes that prevent the car from going READY.
    Before doing any diagnosis, you must confirm that the 12 V battery is in good condition and fully charged. If it is not in good condition, the battery needs to be replaced.
    You could also have a combination meter (CM) failure. See the Combination Meter Repair - DIY thread for details. The link will take you to a post detailing all the parts that Hybrid Texas Batteries (THB) replaces when they remediate a CM board. Most people can replace only the 110 µF/16V capacitor (replacing it with a 220µF/16V) and get lasting results. As people pay money and THB gives a lifetime warranty, they replace all the parts in the list.
    #6 dolj, Sep 18, 2025
  7. PriusOwner428
    70
    IL
    OK thank for the detailed and thorough info. I'm lucky in that I have another 2008 Prius that is working just fine. So I will swap batteries and see if the problem follows the battery. When you say it could set codes that prevent the car from going ready, does that mean I now have to somehow clear those codes before trying again?
  8. dolj
    dolj Senior Member
    8,461
    4,297
    It depends on the codes. Some will clear themselves after some number of cycles of not seeing the problem again. Disconnecting the battery will also clear most codes, so if you have codes after that, you should really investigate those first, as in that case, you do have a real problem that most likely needs fixing before you can clear the codes.
    If you are talking about the 12V battery, I wouldn't swap it; I'd just charge it. But if you insist on swapping it, make sure you charge the spare battery (and load test it to confirm it is in good condition) before installing it in the car.
    Now that you mention clearing codes, if you have the CM problem, you will not see lights on the dash that indicate codes have been set in the corresponding ECU(s). If you do have codes, it would be best practice to read and record them before clearing them.
    Report any codes you currently have in this thread.
  9. PriusOwner428
    70
    IL
    Well the battery I would be swapping into the car with the problem is coming from a car that is working just fine right now. So the swapping battery is definitely good. However, I am currently charging the potentially bad battery over night in place. I disconnected the positive lead and placed the charger cables directly on the 12V battery. So it's charging over night for 8 hours. I will check with a meter in the morning to see what voltage it reads after over night charging. If it's 12V and above I will connect the positive lead in and try to start the car. I will do what you said and have someone connect a meter and see if the voltage drops below 11V during the start attempt. If it won't start I will then swap batteries and try with the known good battery in place.
  10. Hayslayer
    421
    249
    .......does your car have sks? Where you keep the fob in your pocket? If all is good with the car, but you put the fob in the slot and nothing works, it may also be the car is not reading the RFID chip that should be in the fob. It only uses the RFID chip when using the slot. If you got a new case, did you swap the rfid chip to the new one?
    If you have sks, but the car does nothing when the fob is in your pocket, did you accidently deactivate the sks system using the "KEY" button on the dash under the steering wheel? In this case, the slot should work, but only if the RFID chip is present.
  11. PriusOwner428
    70
    IL
    Thanks but none of those are the problem in my case.
  12. PriusOwner428
    70
    IL
    Update. Took the 12V battery to be tested and it tested OK, This matches the fact that the headlights, horn, and interior lights work just fine.
    Any chance the problem could be the hybrid battery? If in those 2 weeks of sitting idle could one of the cells have died and could that be preventing the hybrid battery from coming online? Checked all the fuses & all were OK. Running out of ideas.
  13. Hayslayer
    421
    249
    No, the hybrid battery isn't even placed online until the car 12v system energizes the dash, etc and once conditions are verified, the main relays in the HV battery case go closed.
    Any chance the 12v got jumped backwards and smoked a fusible link in the underhood fuse box?
  14. PriusOwner428
    70
    IL
    When I said I checked all the fuses, I checked the ones under the hood, the ones under the drivers side, and the 2 in the luggage compartment.
  15. dolj
    dolj Senior Member
    8,461
    4,297
    How did you test the 100A fusible link that is in the engine room fuse box?
  16. PriusOwner428
    70
    IL
    Hi dolj. I had not checked it because it was under a cloudy plastic covering, but I checked it now and from what I can see it looks fine. I see where the metal plate narrows to create a weak point and that is still intact. Let me know if you see any issues with it or if you have any further ideas. I can attach a pic of it if I can figure out how to do that on this site. But it looks like the pic did attach as separate file.
    UPDATE:
    Car does not go to ACC mode even with the key in the key slot. Press the start button and nothing happens - no display, no green light on the start button, no indicators on the instrument panel.
    door open alarm does not sound when key is in fob - but once in a while we get a steady high pitched tone when we open the door - different from the beep beep beep door ajar alarm on our other good 2008 Prius.
    When key is in key slot, there is no "no key" indication when you press start.
    However, when the wrong key is in the key slot, there IS a "no key" indication when you press start, therefore, the good key fob IS recognized by the system.
    The door open icon DOES work, just not the alarm.
    Two different key fobs that usually work have the same results described above. Key fobs have had the batteries replaced with new batteries just to make sure.
    Headlights work.
    Internal cabin lights work.
    Horn works.
    Brake lights work.
    Remote lock and unlock work.
    12V battery is verified good.
    AM2 fuse is not blown. Voltage across AM2 fuse location with the fuse removed was 12.5V. But, when the key was put in the slot or the door was opened, the voltage oscillates between 0 and 15 V.
    Because this is a classic symptom of a short circuit in the inverter coolant pump, unplugged the coolant pump connector. The voltage remained steady at 12.5 V across the AM2 fuse location and no longer oscillated between 0 and 15 V.
    However, the car still would not start, go to ready mode, or go into Accessory mode.
    #16 PriusOwner428, Sep 20, 2025
  17. bisco
    52,112
    try resetting the 12v with the pump unplugged
  18. PriusOwner428
    70
    IL
    Good idea. Disconnected the battery for 1 minute and reconnected. Nothing changed.
  19. dolj
    dolj Senior Member
    8,461
    4,297
    Your pic only shows one of the links in that assembly. A nice close-up photo that shows the entire assembly would be useful.
  20. PriusOwner428
    70
    IL
    Finally got around to checking out your link to the scary combination meter. I'm trying to read through it but it's very long. From what I've read so far it seems like that problem could address the dark dash display. But would a bad combination meter also prevent startup?
