New Member; Old, Very Old Prius
Discussion in 'Newbie Forum' started by FrankNPrius10, Aug 10, 2025.
  1. FrankNPrius10
    FrankNPrius10 New Member
    Colorado
    Greetings, fellow Prii owners. About a month ago we visited my daughter, etc., in Alameda, CA. I noticed a rather sad, basic 2010 Gen3 ignored in their courtyard, 203K miles on the clock. Yes, I could haul it away. In 3 days under that shade tree I:
    1. Changed all cooler fluids.
    2. Installed a new EGR from Jeff.
    3. Cleaned its cooler.
    4. Rotated the tires.
    5. Cleaned/lubed the caliper pins.
    6. Serviced the AC.
    We drove the 20 hrs back to CO, mostly desert, 10 at 80 mph, no problem. Back home, I:
    7. Changed out the dark molasses in the CVT for fresh pink from Lexus.
    8. Pulled the hybrid pack.
    9. Cleaned the cooling fan + all ductwork.
    10. Installed an Oil Catch Can system.
    11. Installed a new PCV valve.
    12. Cleaned the intake manifold.
    13. Replaced front fender liners while re-fastening fore and aft plastic body parts.
    14. Concurrently with the above, reconditioned 28 modules using two CQ3 rigs.
    The vehicle now has 206K, and hey, under 25 mph, it's running again in stealth mode.
    Next on the list:
    a) Change out the inverter pump - it's due (engine pump's been done).
    b) install a back-up camera - never had one.
    Running sweet so far. Rewarding.
    If anyone needs DIY how-to tips on the above, send it.
    Good luck, all.
    F
    PS. I have another 2010 that may need a bit more love. We'll see.
    bisco and PriusCamper like this.
  2. PriusCamper
    PriusCamper Senior Member
    13,030
    5,295
    Pacific Northwest, USA
    Welcome to PriusChat! Very impressive first post... If we had a prize for most knowledgeable/well studied on needs of a gen3 on first post you'd win.
    Only thing I disagree with Gen3 owners on is replacing the inverter pump. That was a problem with a bad batch of Gen2 pumps that created a recall long ago and there's no problem with the lifespan of Gen3 inverter pumps, but most people on here replace it any way.
    When the time comes I'm certain you will be very pleased with the improved performance of a Sodium battery pack.
    Also when it's time to deal with headgasket and premature wear on piston rings that 2010 Prius are known for this guy in Oklahoma does high performance engine rebuilds for a super reasonable price: http://www.skimmilkhybrid.com/
  3. bisco
    52,371
    congrats and welcome, all the best!
    PriusCamper likes this.
  4. FrankNPrius10
    Colorado
    As a one-post newbie to this forum, I'm denied a reply to PriusCamper. :unsure:
    Interesting. Engineers are trained to have alternate solution sets at the ready. Here's this one:
    Thanks, PriusCamper. Will keep both tips in mind. Several years ago my wife's small, 4-banger Honda died. Failed both wet/dry compression tests. Pulled the head, dropped the crankcase, honed the cylinders, one oversize new rings, new journals. Learned a great deal; gained confidence that most/all automotive issues may be assessed, repairs attempted.
    A separate issue: online, some folks comment the 2010 is amongst the least reliable. Perhaps that's because this vehicle year might be the least "understood" in terms of lack of focus, lack of maintenance. As mentioned, this 206K 2010 example, shown love, now runs extremely well, even does stealth mode as when new.
    My other 2010 suffered the last Maryland winter parked outside without being driven, etc. Noted. I'll again do 38 module reconditioning and replace the Bettery Voltage Sensor Control module - several pins scorched. Then diagnose from there.
    With that in mind, I may decide to learn board-level electronic testing/repair/replacement. (as I did with the control board of our notorious Maytag Neptune washer - $10 worth of triacs, resistors - 22 years later, still running).
    Thanks again. Good luck, all.
    F
  5. FrankNPrius10
    Colorado
    If "The proof is in the pudding: (mileage, here), the aforementioned 201p Gen III
    An update to the aforementioned 2010 Gen III, 206K miles, hybrid battery reconditioned plus other issues resolved. First mpg log entry: 341 miles driven; 6.58 gallons consumed; 51.8 mpg. Not bad for a senior citizen.
  6. ukulelegeek
    ukulelegeek Active Member
    159
    112
    Welcome to the forum! We have a 2010 Prius as well. It was well love when we got it. It’s kinda gotten dirty inside since then, but gets regular care and wax jobs too. The gas mileage has dropped a bit…..we’re trying to figure that out.
  7. FrankNPrius10
    Colorado
    See basic thread, Old, Old Prius. About 15 work elements, the successful accomplishment of which should improve mileage, many other factors. Our 2010, post those works, recently logged 51.8 mpg. On the flat and, of course, downhill, the car runs only in battery mode. Amazing "rebirth". Very satisfying.
    bwilson4web likes this.
  8. FrankNPrius10
    Colorado
    206K miles; all "long term" maintenance items have been completed, including original 28 cell NiMH hybrid battery reconditioning. After 2nd fill-up, performance now calculated as 53.2 mpg.
    Next task: adding a WOLFBOX G840S dashcam system with backup assist function.
  9. Sb129
    Sb129 Junior Member
    Arizona
    Yeah I've had to deal with my head gasket already, wasn't fun, it was how I found this forum.
  10. FrankNPrius10
    Colorado
    2010 Prius, 206K miles. Running sweet so far.
    50,000 miles maintenance.
    1. Drain old engine coolant (all fluids, actually).
    2. With the old fluid drained, it's easy to replace the engine coolant pump rotor, o-ring, etc. with an Aisin (Japan-made), as follows: After air box stuff removed (10 min), jack up, remove right front wheel (5 min). The pump is readily available.
    3. With the old fluid drained, remove and clean thoroughly the EGR/cooler assembly. The lower back stud/bolts are easier to access if the vehicle front is up on jack stands about 12-16 inches. Block both rear wheels.
    4. Add Asian Red coolant to spec.
    Happy knuckle-busting!
  11. indel
    indel Member
    273
    88
    Northwest Indiana
    That's incredible. You seem to be a very talented mechanic. Would love to have the kind of experience you have in refurbishing Prii.
