2013 Prius C "check hybrid system"
Discussion in 'Prius c Care, Maintenance and Troubleshooting' started by Memphis_Sean, Sep 22, 2025 at 2:21 AM.
  1. Memphis_Sean
    Memphis_Sean New Member
    Friday
    Memphis
    No issues with the car until after it sat for several months. I just replaced the 12v battery and received the "check hybrid battery" message/car didn't start. What things can I check myself prior to taking it to the dealer?
  2. Brian1954
    Brian1954 Senior Member
    2,005
    781
    South Central PA, USA
    Purchase and use an OBD2 scanner to read the trouble codes. Take a look at this thread, Gen2 OBD2 app review | PriusChat
    Read post #1 and then scroll down to post #37. You want to buy a scanner that can communicate with all the ECUs in the car. I recommend the Autel AP200 scanner. It is an OBD2 Bluetooth dongle, and you install an Autel app on your phone. The Autel AP200 costs about $60 on Amazon.
  3. Leadfoot J. McCoalroller
    8,000
    7,476
    Pennsylvania
    2018 Prius c
    yeah you won't get far until somebody does a proper scan of the on-board diagnostics. The thread linked above has lots of great info.
    That Autel is a very good unit, gives you access to all the same stuff the dealer can tell you except you own it forever at about 1/3 the price of a single dealer diagnostic visit.
    Good luck!
    Brian1954 likes this.
