Error Code P0303 After Oil Change
Discussion in 'Prius v Care, Maintenance and Troubleshooting' started by Chris Papaya, Sep 23, 2025 at 9:45 PM.
  1. Chris Papaya
    Chris Papaya Member
    64
    32
    Fort Lauderdale
    Hi there, quick question:
    I just changed my oil at 210,000 miles with 0W-20 full synthetic. Unfortunately I didn't have the correct oil wrench so I had to leave the filter on. (I'll change it sometime soon because I bought one since). I overfilled the oil and simply put the whole 5 quarts.
    However, after I did the oil change, now when I start the car and the ICE kicks on, the engine knocks and rattles a lot. I checked the error code and got error P0303 which shows misfire in cylinder 3.
    I just wanted you guys' opinion? Is it ok to drive the car until this weekend and then I can change the ignition coils?
    Thanks.
  2. rjparker
    9,877
    6,088
    It is possible the 3/4 to 1 quart oil overfill forced liquid oil through the pcv system into the intake manifold.
    Don't waste money and time on ignition coils or plugs before you check out the most common issues.
    1. Does it continue to shake and rattle after the initial start and warmup? Or does it run pretty good?
    2. Is this the very first time for a rough rattling start?
    3. Does it idle poorly and try to stall? Obviously with the engine running.
  3. Chris Papaya
    Chris Papaya Member
    64
    32
    Fort Lauderdale
    1A---From a cold start, when the ICE kicks on it rattles and shakes for about 5-10 seconds but then after that it drives fine for my 50 minute drive to and from work.
    2A---Yes this is the first time it started rattling like this, right after the oil change.
    3A---No it does not idle poorly. It idles fine and drives fine all the way home. Only on a cold start where the car sits for a few hours and cools down does it do the rattling thing.
  4. BiomedO1
    3,125
    1,658
    SacTown, Ca
    So why do you think there's a problem with coils or plugs, when it only does it on cold start-ups????
    Check and mark ICE coolant level, see if it slowly goes down.....
    Good Luck.........
    #4 BiomedO1, Sep 24, 2025 at 12:25 AM
  5. rjparker
    9,877
    6,088
    You certainly have misfires but not coil, plug or injector based. Not when it clears quickly and runs fine. In fact you may go days or weeks before it repeats which often fools mechanics into thinking the $500 - $1000 with of replacements actually did something.
    Answers 1 and 2 point to an early onset small head gasket leak. Borescope inspection is the only definitive test at this point.
    Answer 3 suggests it's not an egr valve stuck open and certainly not a clogged egr cooler causing misfires. But a block egr flow test can prove it.
    Car Care Nut HG Borescope at 660s
    Excellent Borescope Footage at 6:50
    Honda Misfires on Coldstart Only
    Egr block flow test
    At about 10:15 in the video he starts talking about the egr valve letting "air" into the intake manifold. He means exhaust gasses.
    #5 rjparker, Sep 24, 2025 at 2:09 AM
  6. Mendel Leisk
    40,967
    Air_Boss likes this.
  7. rjparker
    9,877
    6,088
    Ah the sweet innocence of youth. A flashy body and a warm interior sucks in many a young man.
    A can of head gasket stop leak "fixes" it - for a couple of months. Welcome to the gen3 repeat offender club. It's a small group but not that exclusive anymore.
    Now that the bloom is off the rose you can see the thorns.
    I will say Ms V does have a very good body and she cleans up well creating a very good first impression. It's not her fault, her handler probably was not very good to her and dumped her for a younger model.
  8. Chris Papaya
    Chris Papaya Member
    64
    32
    Fort Lauderdale
    The weird thing now is that when I was leaving work, I turned on the car from a cold start, and when the ICE kicked on it did not rattle at all? Its weird. That happened earlier this week too on one or two or my commutes commutes where the ICE did not rattle at startup. It seems like the rattle happens only like 75% of the time.
  9. rjparker
    9,877
    6,088
    That is normal in early stages on a Prius gen3.
    #9 rjparker, Sep 24, 2025 at 7:09 PM
  10. BiomedO1
    3,125
    1,658
    SacTown, Ca
    Well if it only happens 75% of the time - that means it's only 75% broke. Run it until you can get the last 25% out of it. Don't worry about it leaving you stranded somewhere - key in banjo music. Have you ever seen Deliverance or those slasher movies where someone is stranded on the side of a lonely road out of cell service range?
    Sorry, in a corny mood - Denial isn't just a river in Egypt......:(
