Driving gen5 prius prime to empty: how far?
Discussion in 'Gen 5 Prius Main Forum' started by Templeton, Sep 26, 2025.
  1. Templeton
    Templeton Member
    272
    82
    usa
    2024 Prius Prime
    SE
    I am curious if anyone with a gen5 prime has driven it (in HV mode) beyond "zero" HV miles remaining. If yes, how far were you able to drive on gasoline before the car shut down the ICE and started running on EV mode?
    Also, in what conditions did you do this? City driving, highway driving, or? Was it an SE or XSE? (asking because the different wheels/tires affect fuel economy)
    #1 Templeton, Sep 26, 2025
  2. Paul Gregory
    Paul Gregory Senior Member
    2,122
    555
    Alberta
    2024 Prius Prime
    XSE
    Mine will give a warning at 40 kms (25 MI) remaining, and then the engine quits about 40 kms after that.
  3. Paul Gregory
    2,122
    555
    Alberta
    2024 Prius Prime
    XSE
    My Gen 3 Plug in went nearly 200 kms after the red light came on.
  4. Templeton
    Templeton Member
    272
    82
    usa
    2024 Prius Prime
    SE
    I am confused, so for a gen 5 prius prime/phev, the engine quits at zero km remaining, as shown on the display?
  5. Hammersmith
    Hammersmith Senior Member
    2,302
    2,316
    North Dakota - USA
    2023 Prius
    Limited AWD-e
    No. You've got at least 1gal left at 0 mi, maybe more. I know I've done 30mi after zero, maybe as much as 40. I've never driven until the engine died. When I get to 0 miles remaining, it normally takes 8.5-8.8 gal of fuel to get back to full. My tank(HEV AWD) is supposed to be 10.6 gal(same as Prime), so the reserve might be as much as 2 gal.
    And, of course, miles available will depend driving conditions. 1.5 gal at 85mph gives you about 55mi. 1.5gal at 50mph gives you about 90mi.
    PrimeDan, GeoJ, otatrant and 2 others like this.
  6. Templeton
    Templeton Member
    272
    82
    usa
    2024 Prius Prime
    SE
    Good info, thanks. Do you know if the gen5 PHEV fuel tank is the same shape as the gen5 HEV AWD? (asking because the shape of the tank affects the quantity of unusable fuel in the tank)
    Has anyone here ever posted about driving a gen5 PHEV all the way to empty, i.e., until the ICE actually quits?
  7. BiomedO1
    3,496
    1,818
    SacTown, Ca
    It'll be wise to do your own experimentation, than rely on the cloud for that sort of specific information.
    I know that I can get at least 50 miles beyond the zero miles to empty in both my old Prius C and Prime. I had more options in my Prime, since I can do additional miles in EV mode alone. I wouldn't recommend doing this too often, since the fuel pump relies on the fuel in the tank to cool the motor.
    Good Luck.....
    Templeton likes this.
  8. Templeton
    Templeton Member
    272
    82
    usa
    2024 Prius Prime
    SE
    Thanks, I might.
    But if several others have done this (with a gen5 prime/phev) and they have some range numbers to when the stops, this info can at least give me a rough estimate of what might typically be possible, at least in some conditions.
    #8 Templeton, Sep 26, 2025
  9. BiomedO1
    3,496
    1,818
    SacTown, Ca
    The problem is that you don't know how rigorous their scientific method is and how they normally drive and under what conditions. That's why results vary. I figure 50 miles beyond zero is good enough for me and has a margin of safety I'm comfortable with. I recall on one of my cars, the odometer options became non-functional and was locked to LOW FUEL - was several miles beyond zero miles to empty. Everything else in my cluster was working, but couldn't determine how much further I could go - even if I had the distance to the nearest gas station. Fuel needle was on E and had been there for a while.
    YMMV
  10. Hammersmith
    2,302
    2,316
    North Dakota - USA
    2023 Prius
    Limited AWD-e
    They're different shapes, but I don't know how much that affects usable fuel. The PHEV tank is more of a mild saddle-style than the HEV tanks, if that means anything.
    FWD HEV: https://toyota-img.amayama.com/imgus24/A1/776182A.png
    AWD HEV: https://toyota-img.amayama.com/imgus24/A1/776184B.png
    PHEV: https://toyota-img.amayama.com/imgus24/A1/776183.png
  11. Templeton
    Templeton Member
    272
    82
    usa
    2024 Prius Prime
    SE
    Agreed.
    But I was curious if there was already a thread on this with maybe some folks posting how they tested this, and what their results were with a gen5 phev.
  12. Templeton
    Templeton Member
    272
    82
    usa
    2024 Prius Prime
    SE
    Thanks again, those images are interesting. Looks like the AWD and FWD fuel tanks have very similar shapes, with the PHEV being definitely different.
    Do you know if all of the gen5 tanks (in the usa) have the same rated/claimed total size?
  13. Hammersmith
    2,302
    2,316
    North Dakota - USA
    2023 Prius
    Limited AWD-e
    Some did early on, but the thread died off quite awhile ago. I think the final consensus was something like:
    1. Assume 1gal reserve.
    2. Check your tank average when you reach 0 miles.
    3. That's roughly what miles you've got left(including a small safety margin).
  14. Hammersmith
    2,302
    2,316
    North Dakota - USA
    2023 Prius
    Limited AWD-e
    The FWD HEV is a little bigger than the rest. 11.3 gal versus the 10.6 gal versions in the AWD HEV and PHEV.
  15. bisco
    51,843
    keep in mind that gas range (like ev) will be dependent on driving style and conditions.
  16. BiomedO1
    3,496
    1,818
    SacTown, Ca
    You've got a 10.6 gallon tank and figure a conservative 50mpg would put you around 500 miles on ICE alone. You'll still have to factor in your EV distances, weather, terrain. My normal commute along with groceries runs usually yielded me more than 1K miles a tank, so pretty much month or month and a half fuel-ups depending on how far I strayed on the ICE on weekends. You've got almost twice the EV range I have so adjust accordingly. I've never been able to pump more than 9 and some change gallons into my 11.3 gallon tank. I don't try to run it dry on purpose, but sometimes you forget to fill-up on long road trips. Don't forget to compensate for additional weight and traveling faster than 75mph too. Locking the CC above that; your mpg takes a serious nose-dive. I'd use 40mpg just to be safe in that instance to plan for breaks and fuel stops.
    YMMV
  17. Templeton
    Templeton Member
    272
    82
    usa
    2024 Prius Prime
    SE
    Thanks, but, yes, I know that total HV range varies hugely depending on driving conditions.
    I was more curious if anyone has tested a gen5 prime regarding how far they can go, but measured after the Guess-O-Meter shows "zero HV miles" remaining.
    For example, I have read that the rav4 prime can go nearly 100 miles on gasoline after it shows "zero HV miles" remaining on the GOM. So am curious if people measured a similar no. in the gen5 prius prime.
    #17 Templeton, Sep 26, 2025
  18. BiomedO1
    3,496
    1,818
    SacTown, Ca
    As stated earlier; your pretty safe at 50 miles. Now if your trapped in bumper to bumper snow storm - you'll have plenty of company. You may only get a few hundred yards - but you'll likely outlast all those SUVs around you.
  19. KMO
    KMO Senior Member
    1,947
    676
    Finland
    2023 Prius Prime
    No. That's not really plausible. The low fuel warning light comes on with 1.6 gallons remaining, and that comes on some time before the remaining distance reaches zero. You'd have to significantly beat 60 mpg to go 100 miles.
    All the people telling you 50 miles are correct - you can significantly beat 30 mpg to achieve that.
    BiomedO1 likes this.
  20. bisco
    51,843
    at 1.6 g remaining, just multiply times your current mpg. i'm sure there is no exact number, everyone would achieve different but similar results in the real world
