ABS warning lights after catalytic converter replacement
Discussion in 'Gen 3 Prius Technical Discussion' started by Travis Antonissen, Sep 28, 2025.
  1. Travis Antonissen
    Travis Antonissen New Member
    United States
    2015 Prius. Catalytic converter was stolen. Took it to the mechanic to replace under insurance.
    Car worked for a couple days, now have ABS warning, traction control, and parking brake light permanently on. I hear the brake actuator cycle on very quickly.
    Whats the most likely cause of what the mechanic messed up?
  2. BiomedO1
    3,488
    1,813
    SacTown, Ca
    It may not be the mechanic's fault, but damage that was missed when the thieves stole your CAT. Everyone was concentrating on the missing CAT and nobody did a full inspection of the undercarriage. Thieves could've done some damage when jacking up the car to steal the CAT, the shop could've damaged it when they jacked it up, or you could've ran over something that ripped down something down in the ABS system.
    Good Luck.......
  3. ChapmanF
    18,072
    We need to start by asking the car what it thinks the problems are.
    If you don't have a suitably-capable scan tool for doing that, then do this:
    Blink (a/k/a Flash) Codes – How to. | PriusChat
    Once we know what problems the car is reporting, we can reason about whether they were likely caused by the mechanic, or by the thief, or by something else.
    Whatever the answer to that is, we will at least know what it is that needs to be fixed.
    Brian1954 and BiomedO1 like this.
  4. Travis Antonissen
    United States
    Thanks for responding. Autozone scan tool was able to find C1391 warning code, which points to brake booster and accumulator.
    Brian1954 likes this.
  5. ChapmanF
    18,072
    ... which is a sign to proceed cautiously, because in a gen 3 car the "booster" and the "accumulator" are different parts.
    The detection conditions are either the accumulator pressure doesn't rise at the expected rate when the ECU has turned the pump on, or that the pressure falls faster than it should while the pump is off and the brakes aren't being used.
    What do your ears tell you about how often / how long the pump is running? A pump that runs and runs, without the pressure building fast enough, is one kind of explanation. A pump that doesn't run when the ECU tries to turn it on is another kind of explanation, and a pump that has to keep cycling on and off because the pressure falls quickly between pump runs is still another kind.
    You can see the "Trouble Area" box concentrates on the booster (top thing in the drawing above) as the likely suspect (it has the most internal valves and seals to possibly go leaky). But there are three pages of troubleshooting steps for that code, and you can also end up at the accumulator/pump (bottom thing in the drawing) as the culprit sometimes.
    Probably the cat converter replacement didn't do this.
  6. Travis Antonissen
    United States
    Thanks for the reply. I just paid a mechanic to replace both booster pump and accumulator. It was like $2,000 or something. But I wonder how the previous mechanic sabotaged it. Probably yanked on some hoses or messed with some seals. Anyways, $2,000 later and a cry and now moving on.
    Thank you,
