What is this part?
Discussion in 'Prius v Main Forum' started by MattFL, Sep 28, 2025 at 4:11 PM.
  1. MattFL
    MattFL Member
    181
    Can anyone identify this part, from a 2012 Prius? We had the A/C evaporator replaced about 2 weeks ago, just today we went into the cargo area and found this sitting there, they apparently forgot to put it back. Am I correct guessing it should go around the traction battery somewhere?
  2. ChapmanF
    17,763
    Looks to me like what sits over the 12-volt battery in the aft starboard corner of the car.
    douglasjre likes this.
  3. rjparker
    9,884
    6,092
    Looks like it fits over the 12v battery or the similar opening on the left.
    Brian1954 likes this.
  4. MattFL
    MattFL Member
    181
    Ah you guys could be right, thank you! I'll check that area out.
  5. bisco
    51,536
  6. ChapmanF
    17,763
    Looks like someone separated it from the flat carpeted piece that attaches on top of it. Me, I always just take mine out as one piece. I haven't unclipped the top piece from it.
    Did they just sort of put the top piece back over your 12-volt battery, hanging by the edges?
    Do you have a non-original-size-shape battery back there, that this support piece won't fit over?
    Or does 2012 just have one wide deck board all the way across, instead of separate pieces in those corners like my 2010?
  7. Air_Boss
    Air_Boss Senior Member
    4,167
    1,167
    New Yawk
    Our 2012 v Five has no such aux battery cover.
  8. ChapmanF
    17,763
    Hmm, interesting. This is the Prius v forum, but the OP just says a 2012 Prius.
    Air_Boss likes this.
  9. bisco
    51,536
    maybe they left someone else's part in there.
  10. Paul Gregory
    Paul Gregory Senior Member
    1,976
    503
    Alberta
    2024 Prius Prime
    XSE
    It's the right shape to fit into the rear fender well.
    What fits into it, I don't know.
  11. RRxing
    RRxing Senior Member
    2,538
    1,810
    NEPA
    Looking up the part number might help... ;)
  12. ChapmanF
    17,763
    The one in my 2010 liftback looks very much like that (from memory, I haven't run out just now to bring it in or take photos). OP's first photo shows its normal orientation. Third photo shows it upside down, looking at its black-felt-covered 'feet'. The tall feet on the inboard edge rest on the hatch floor sheet metal. The shorter feet rest on the top of the 12-volt battery.
    The notched tops of the 'buttresses' along the inboard edge support the lip of the big black cargo tray (so, the cargo tray must be taken out first, or at least lifted, before this battery cover can come out).
    The one in my car is topped with a flat carpeted piece, missing in the OP's photos, of matching height with the carpeted deck board that lies over the cargo tray and serves as the carpeted bottom of the hatch area.
    I might have to go look more closely at mine to be sure whether the flat carpeted piece can be removed (if it can, I've never done it), leaving the substructure as above, or it's really just a single piece in my 2010, as I have always thought.
    Nah, being too lazy to stand up and go out to the car ... screenshotting the 2010 and 2012 Prius owners' manuals side-by-side shows they did change it: one piece on the left (2010), "deck board" plus "battery cover" on the right (2012).
    When I added some fuses and stuff above the battery in my 2010, I did have to pay a bit of attention to not having my added stuff be right where those short felt-padded feet sit on the top of the battery.
  13. Air_Boss
    4,167
    1,167
    New Yawk
    Nothing like this in the v…
  14. MattFL
    MattFL Member
    181
    I don't remember the fuses, but the manual pictures above look familiar. It's my wife's car and I haven't had time to get out to it to figure it out yet, but I bet that's it. I'll post back after I verify this is what it was.
    This was a small private shop so we were almost surely the only Prius there at the time, so it must be from our car. Also we have the OEM size battery.
    Regarding Prius V: my apologies, I thought I picked the regular Prius forum. We have the regular Prius, not the V.
  15. Air_Boss
    4,167
    1,167
    New Yawk
    May look into one though, as a positional spacer for the aux battery compartment.
  16. ChapmanF
    17,763
    The photo with the fuses was from my car, where I added the fuses. They're not stock. It went with the part where I said when I added the fuses, I had to be careful not to have anything right where the felt-tipped feet of that part have to sit flat on top of the battery.
