3rd Gen EGR System & Service Cost at 9K+ if Head Gasket Blows
Discussion in 'Prius v Main Forum' started by Jon Johnston (JJ), Oct 4, 2025.
  1. Jon Johnston (JJ)
    Jon Johnston (JJ) New Member
    Fairfield, CT
    As probably many know, the third-generation Toyota Prius models, including the Prius v, are prone to EGR (Exhaust Gas Recirculation) system issues caused by carbon buildup in the EGR valve, cooler, and intake manifold ports. This blockage leads to rough idling, stalling, sluggish acceleration, and poor fuel economy, and if left unaddressed, can result in severe engine damage, including a blown head gasket. Regular cleaning of the EGR valve, cooler, and intake manifold every 50,000 to 100,000 miles is the recommended preventative maintenance to extend the life of the system and prevent costly engine repairs.
    My Prius V did not exhibit the idling, stalling, sluggish acceleration right up and until maybe just before the head gasket blew at 135K. Those symptoms were withing 100 miles of the gasket blowing. It did however begin showing decreasing AVG MPG from 60K. We went from 41.1 to 37.8 over the years between 60K and 135K and it seemed to start after I had the major service at 60K so I stupidly stuck my head in the sand and attributed the decrease to age and the servicing. I never went to the Internet and asked "what common issues with older 2012 Prius Vs?"
    However had I known that my dealership was going to tell me the cost to replace the head gasket and do the timing chain (a service that makes sense for a 135K Prius when doing the gasket) was going to be 9.5K, even I might have swiveled from work and life's other focus grabbers and asked this question.
    So, word to the wiser than me, check your EGR System!!!
    ps. pls. don't post on the $ unless you'd like to have a meaningful conversation around the steps we took to get that price way down (but still not nearly down enough for a 135K 14 yr. old car worth only 7K in perfect condition)
  2. rjparker
    10,134
    6,297
    Actually this is not correct. A stuck open egr valve can cause rough idling and stalling - it is designed to be closed and no flow at idle, low rpm and wide open throttle. Your egr valve was stuck open or more likely the head gasket was already bad. HG leaks are subtle and often confused with other misfire causes at first.
    For that money they are selling you a rebuilt motor, probably with a new short block to take care of the low tension rings - the cause of gen3 oil consumption and carbon build up.
    Dealers won't do a straight hg job because they often fail quickly. Not always if the hg is caught early but too many don't recognize the symptoms or believe the hundreds of posts that cold start stumbles are egr related.
    The reality is hg parts are about $500 and labor is often $1,000 to $1,500. Again pro shops don't want to risk it and be forced to fix it again under warranty if it fails in a year.
    Other options are professionally rebuilt engines shipped to your local independent shop for installed cost of $3,500 to $5k.
    Others buy a used in Japan low mile JDM engine for $1,000 to $1,500 plus a $1,500 install. In Japan these engines were used through 2021 with all major design problems addressed by 2016 including gasket design, intake, egr valve and ecu software for water pump logic.
    #2 rjparker, Oct 4, 2025
  3. PriusCamper
    PriusCamper Senior Member
    12,733
    5,148
    Pacific Northwest, USA
    In other words, the criminals at your Toyota Stealership are saying that they're going to charge quadruple of what an honest local mechanic would charge you to do the repairs. Don't waste your time talking to those con artists!
    Also, as @ChapmanF often points out we don't have absolute proof that a clogged EGR will cause a blown headgasket, it could just be Toyota screwing up their design and not creating enough strength where the head gasket fails between cylinder 1 and 2 because they were trying to fit a larger engine into such a small engine compartment starting in 2010 in US and 2009 in Europe...
    Also we do know a clogged EGR will make an engine run hotter, which could be a contributing factor to head gasket failure.
  4. ChapmanF
    18,148
    I don't think I know that at all. I'm pretty sure an engine with a clogged EGR will run at a coolant temperature around 85 to 95 ℃ pretty much like the same engine with working EGR, as regulated by the engine thermostat and fans, which handle bigger differences in heat load every time you go up or down a hill.
    The thing that EGR is known to affect (because that's what it's for) is the milliseconds-scale peak temperature inside the mass of burning charge during the power stroke. That's not to be confused with the steady temperature of the massive aluminum engine block and head, the gasket sandwiched tightly between them, and the coolant and oil circulating through.
    On the other hand, literature can be found linking subnormal EGR flow to detonation, and detonation to head gasket damage, so there is a possible causal path there.
