Tire Bulging
Discussion in 'Gen 5 Prius Main Forum' started by theRob, Oct 6, 2024.
  1. theRob
    theRob Member
    98
    116
    2023 Prius
    I hit a pothole today and now one of the tires has a little bulge. I’m going to replace it with a new one. I have the Toyo Extensa A/S II A. I got the car in April of 2023 and the car has about 6.7k miles on it. Will it be okay to just replace the 1 tire? I measured the tire tread depth (see below) and seems like the rear passenger has barely any wear. According to this site
    Details for Toyo Extensa AS II | Napa Tire & Wheels Napa, CA
    the tire depth is 9/32"
    Front Passenger (tire with bulge)
    Front Driver
    Rear driver
    Rear Passenger
    #1 theRob, Oct 6, 2024
  2. BiomedO1
    3,488
    1,811
    SacTown, Ca
    Yep; put the new tire on the drivers side front - that's usually the one that wears the fastest. You may also want to skip a rotation; only rotate the passenger side. Leave it there for 10K miles, then continue the 5K miles rotations. That should pretty much even out all 4 tires.
    Hope this helps...
    GcinFl and theRob like this.
  3. Gokhan
    Gokhan Senior Member
    6,147
    2,431
    Paramount CA
    Most importantly, make sure that it is identical in brand and model to the original tires. Once the dealer installed the P-metric Toyo (A29) instead of the ISO-metric Toyo (A41) on my previously owned 2020 Prius Prime XLE. They corrected it when I saw it. My 2021 Prius Prime Limited has Dunlop tires.
    theRob likes this.
  4. theRob
    theRob Member
    98
    116
    2023 Prius
    I ordered from tirerack.com it’s the same exact one. Thanks!
    #4 theRob, Oct 6, 2024
    Gokhan likes this.
  5. nagrath
    nagrath Member
    145
    49
    Putnam County, New York
    2023 Prius Prime
    XSE
    My 19" toyo extensa rear tire just developed a sidewall bulge too (I never wanted those 19" tires but all the cars for sale had them in 2023). I have 15k miles on mine though - I am guessing I'll likely need 2? Its the rear passenger side. Think there's any chance for a prorated replacement (or a warantee one? I heard there was a recall on other Extensa sizes for sidewall issues)? I'm pretty annoyed especially if I am going to have to get 2 tires plus alignment. They never should have put these 19" tires on this car - the 17's should have been standard across the board.
    Tande likes this.
  6. BiomedO1
    3,488
    1,811
    SacTown, Ca
    You can just move that tire to the rear axle; it'll do the least amount of damage there. Whenever you get it serviced; just make sure that tire stays on the rear axle.
  7. Gokhan
    6,147
    2,431
    Paramount CA
    It looks like Toyota has two OEM 19” tires—Toyo Extensa A/S II and Michelin Primacy A/S—as well as a winter tire (Michelin X-Ice Snow).
    I would get the tire from the dealer, as it comes with a warranty. Bulge or nail, they will replace it immediately.
    19” tire on the Toyota tire center
    For 17”, there are Toyo Extensa A/S II and Bridgestone Ecopia EP422 Plus fuel-efficient OEM tires as well as the non-fuel-efficient, non-OEM Goodyear Assurance Maxlife 2, the latter of which I would avoid because of the lack of fuel efficiency. There is also the winter tire Michelin X-Ice Snow.
    17” tire on the Toyota tire center
  8. nagrath
    nagrath Member
    145
    49
    2023 Prius Prime
    XSE
    Thanks, I won't let them force me into 2 new tires then, and will skip rotating it then. Looking forward to ultimately getting rid of them tho- are the Michelins better?
  9. Gokhan
    6,147
    2,431
    Paramount CA
    Michelin OEM tires also claim excellent fuel efficiency (aka very low rolling resistance). Given that Michelin is a better brand than Toyo in general, yes, the Michelin OEMs are probably better than the Toyo OEMs. They are a lot more expensive though, but perhaps they last a lot longer as well.
    #9 Gokhan, Oct 5, 2025
  10. Mendel Leisk
    41,316
    Just to summarize the OP pics:
    front/right: 9 (32ths) (has bulge)
    Front/left: 9
    Rear/right: 9
    Rear/left: 10
    (all numbers slightly less)
  11. ETC(SS)
    7,134
    Asked and answered.
  12. VelvetFoot
    VelvetFoot Active Member
    531
    168
    New York State
    2026 Prius
    On a couple of side notes, I destroyed a tire on a pothole in my MINI. 195 55 16 Bridgestone Driveguard runflats. Not just a 'bubble', which is not good, but destroyed. Rim was okay.
    Runflats suck.
    In another observation, don't wider tires usually go hand in hand with low profile tires? Why even make a 19" wheel available, have to suffer with the weight, ride, and hazard compromises with a low profile tire if it's going to have the same 195 width as the 17" tire? Maybe a little better handling and mostly looks, I imagine.
    douglasjre likes this.
  13. Gokhan
    6,147
    2,431
    Paramount CA
    Only looks.
    VelvetFoot likes this.
