Long beep when opening the rear hatch
Discussion in 'Gen 5 Prius Main Forum' started by mannymendez25, Oct 4, 2025.
  1. mannymendez25
    mannymendez25 Member
    66
    Miami
    2020 Prius
    I have noticed recently that there is a long beep when opening up the rear hatch. It doesn't happen all the time. When opening the hatch, I typically get a beep, beep-beep. Sometimes, I get a beep, beeeeeeeeeeeep.
    I can't replicate it but it typically happens when I am getting out of the drivers seat and press the hatch button on the dashboard.
    Has anyone experiences this? What does that extra-long beep mean?
  2. RandyPete
    RandyPete Active Member
    403
    167
    Santa Margarita, CA, USA
    2024 Prius Prime
    XSE
    On the front door, two beeps means door was just unlocked. One beep means door was just locked.
  3. VelvetFoot
    VelvetFoot Active Member
    532
    172
    New York State
    2026 Prius
    Are these beeps coming from inside or outside the car?
    edit: I just perused the manual. Do you have a power 'back door'? Could have something to do with that.
    If so, you'll have to read the manual, I can't figure it out, and I'm not getting the power option so there's no need. :)
    #3 VelvetFoot, Oct 7, 2025
  4. RandyPete
    403
    167
    2024 Prius Prime
    XSE
    Its complicated ! If you have power back door it gets even more complicated. I suggest you get your owners manual out, or a pdf copy of it, and figure out your particular situation.
    #4 RandyPete, Oct 7, 2025
  5. RandyPete
    403
    167
    2024 Prius Prime
    XSE
    oops. Do you have a gen 5 prius or a 2020 prius implied by your signature/profile. If 2020 prius, try posting to the 2020 prius group. Good luck.
    #5 RandyPete, Oct 7, 2025
    GcinFl and Brian1954 like this.
  6. mannymendez25
    66
    Miami
    2020 Prius
    The issue is with my 2023.
  7. PhoS
    PhoS Active Member
    252
    204
    Nowhere
    2023 Prius
    Limited AWD-e
    It's a feature not a bug.
  8. mannymendez25
    66
    Miami
    2020 Prius
    I reviewed the owners manual but I didn't find anything related to the back door beeps. Here is what is happening.
    - Sometimes when I press button #1 (back door opener switch) it beeps once, it opens, and once the door stops opening, it then beeps twice beep-beep (this is how I always remembered it since I bought the car)
    - Sometimes when I press button #1 (back door opener switch) it beeps once, it opens, and once the door stops opening, it then beeps once but much longer. beeeeeeeeeeep (This annoying long beep is recent but now happens more often)
    I have both scenarios caught on video.
    beep
    https://photos.app.goo.gl/8dWB28s3TJzsiY9BA
    beeeeeeeeep
    https://photos.app.goo.gl/apKRMPCMY6613YqN6
  9. Hammersmith
    Hammersmith Senior Member
    2,302
    2,316
    North Dakota - USA
    2023 Prius
    Limited AWD-e
    If it's beeping at all after opening, that means it's trying to tell you something's wrong. I think the long beep means it thinks one or both of the power struts is going out. Hopefully it's just a configuration error, but I'm a little concerned something was wrong long enough that it's now damaged one of the struts. If so, get it to the dealership before your warranty runs out because those things are EXPENSIVE.
    One option you can try is to clear out everything by disconnecting the 12V battery for several minutes. You'll have to manually push down the hatch the first time after reconnecting the battery, but it should operate normally after that.
    FYI, I've also got a power liftgate and mine has never made any noise after opening.
    KMO likes this.
  10. KMO
    KMO Senior Member
    1,947
    676
    Finland
    2023 Prius Prime
    Yes, I'd say that's miscalibration - it's beeping because it's stopping because it thinks something's in the way. It's just two variations on a "blocked" complaint.
    You could check that it beeps similarly if you block it while opening. And you could try setting a lower opening height to confirm that it doesn't beep it if it is set to stop earlier.
    Opening height can be set from menus in the car, or just hold the open/close button on the bottom inside of the door for 2 seconds while it's in the open position you want - it'll beep 4 times to confirm.
    That would all confirm that it's lost track of what its maximum opening height should be.
    And leaving it set to a lower open position would hide the problem, but it would come back if you reselected "fully open" in the menu (or by holding the button for 7 seconds).
    As Hammersmith suggested, 12V disconnection should make it recalibrate its fully open position.
  11. mannymendez25
    66
    Miami
    2020 Prius
    OK, as recommended, I disconnected the battery for about 15 minutes and I am still getting the beeps when the hatch reaches the top. Sometimes I get no beep (which based on this chat is normal), sometimes I get two quick beeps (beep beep) and sometimes I get one long beep (beeeeeeeep) as shown in my posted videos above.
    I then took the advice of some to adjust the height of the hatch opening so it doesn't open all the way. Bingo, no beep when opening is done. Obviously this is just a workaround. I do prefer it open all the way.
    I then proceed to YouTube and watched about 5 Prius reviews. I can hear the initial beep with the lights flashing when pressing the button but never hear the double beep or long single beep in any of the reviews.
    I guess my next step is to visit Toyota service since these beeps don't seem to be normal.
    I appreciate everyone's input in helping me determine there is an issue.
