Featured Interesting postings on other forums re wear and fuel stabilizers
Discussion in 'Prius, Hybrid, EV and Alt-Fuel News' started by mikefocke, Oct 8, 2025.
  1. mikefocke
    3,988
    1,801
    Sanford, NC
    fuel stabilizers test over 5 years
    Sae.OrgWebapp Wear - Hybrid vs Plug In vs ICE
    davecook89t likes this.
  2. ColoradoBoo
    ColoradoBoo Senior Member
    1,231
    824
    Monument, Colorado USA
    I saw that and was very surprised! I've always used Sta-Bil but am careful to not let the gas in the can get over 6-months old. (And I never leave gas in my small engines when they are stored during the off-seasons.)
    A good tip is always get the highest octane gas you can buy for those smaller engines....really makes a difference.
    drash likes this.
  3. wjtracy
    wjtracy Senior Member
    11,366
    3,608
    Northern VA (NoVA)
    Oh wow. Main ingredient hydrotreated petroleum distillates. That was my day job, I hydrotreated petroleum distillates for a career, "Hydro" short for Hydrogen of course. lab and commercial. But I was a "process" person who makes the stuff. not a "products" specialist with focus on additives. I would say the flammability has to do with evaporative losses of C4's, C5's etc. In some of my density tests reported here years ago, I saw 5% evap loss through a regular plastic...special gaso storage cans are treated to reduce that. One of the eco problems with E10 over E0 is that the alcohol tends to cause more evap losses basically it forces hydrocarbons into the vapor space. This was why California was slow to adopt E10 back in the day. Of course the fix was to force oil companies to heavy-up the gaso so adding ethanol was less problematic. Gee I don't know what chemistry is going on with the metal. Normally with fresh gaso you have vapor space filled with C4's C5's etc. and that keeps out O2/water and a fuller vessel would help. Once the C4's C5's are lost I guess air/moisture gets in there. I've gone to Hybrid car and EV mower, so I am about out of the gas can business. But I used to add Stabil to the gaso can.
    #3 wjtracy, Oct 8, 2025
  4. BiomedO1
    3,488
    1,813
    SacTown, Ca
    Nice to know that Sta-bil really works! I always put that stuff in my small engine gas cans. My two stroke gas usually goes almost a year, before I could use it all.
    hill likes this.
  5. bisco
    51,840
    i put stabil in our snowblower a few years ago. but it hasn't snowed since, and i wonder if it will start.
  6. BiomedO1
    3,488
    1,813
    SacTown, Ca
    I'd dump out any remaining fuel and put some fresh gas in it. You'll have issues starting it; due to the old gas and what's left in the carburetor; but a few burst of starting fluid should take care of that.:)
  7. VelvetFoot
    VelvetFoot Active Member
    532
    169
    New York State
    2026 Prius
    High test around here is ethanol free.
  8. Mendel Leisk
    41,317
    I’ve got a mostly full bottle of StaBil, must be 2 decades old, not sure what to with it, responsibly. Add a 1/2 cup after each fillup??
  9. VelvetFoot
    532
    169
    New York State
    2026 Prius
    Lawn tractor?
  10. Mendel Leisk
    41,317
    Where to add the occasional 1/2 cups? It’d be the Prius.
  11. VelvetFoot
    532
    169
    New York State
    2026 Prius
    I've burned miscellaneous stuff in small quantities at a time in the lawn tractor. Mineral spirits comes to mind, if I recall correctly, lol.
  12. ColoradoBoo
    1,231
    824
    Yep I'll dump anything left in my 2-gallon gas can into my Tundra every 6-months to ensure it's fresh. I've learned it's a big mistake to let gas sit in tiny engines like my gas weed wacker....end up taking it apart to clean out the varnish from the old gas and oil.
  13. Mendel Leisk
    41,317
    Maybe I’ll just pour it onto a tray of kitty litter, a cup or so at a time, let it vaporize. It’s what I do with used brake cleaner spray. I do try to minimize use of such stuff.
  14. ETC(SS)
    7,134
    I rotate my fuel every 6 months so for me the best fuel stabilizer is no stabilizer........
    I've never had any problems and my now 20 year old Zero-turn is still running and cutting grass.
    MY mileage.
    Yours might vary.
  15. BiomedO1
    3,488
    1,813
    SacTown, Ca
    Donate it to any small engine repair shop or independent equipment rental company. They're a dying breed, but we still have a few mom & pops still operating.
  16. Mendel Leisk
    41,317
    There's a guy up our block that'll take most anything; I gave him a can of degreaser, stuff was ancient but I'm sure still effective. Still, if I recall correctly the Stabil says to use within two years, and I may have had it closer to 20 years, lol.
    Not sure I want to spoon-feed our garage queen with it, likely going the evap in kitty litter route.
  17. bisco
    51,840
    we have a yearly hazardous waste pick up
  18. Mendel Leisk
    41,317
    We've got a nearby place for motor oil, but they won't take brake fluid. I've dropped it off at dealership before, hey I bought the new stuff from them, and they do a lot of brake jobs. Ditto for used coolant.
  19. PriusCamper
    PriusCamper Senior Member
    12,685
    5,121
    Pacific Northwest, USA
    Fuel stabilizers are primarily because the corn lobby profits off of poisoning our fuel supply with Ethanol, which absorbs water... It's absolutely essential to use ethanol-free gas on small engines like lawnmowers because fuel stabilizers don't work as well as eliminating the original cause of the problem. This website will help you find no-ethanol gas: Pure-gas.org - ethanol-free gasoline in the U.S. and Canada
  20. hill
    8,794
    Not only do (most) gas additives work - the same is true for diesel fuel additives. They will not only increase lubricity that keeps injectors & high pressure pumps in good shape, they also increase cetane (which is similar to the effect of octane) as well as prevent cold weather gel in freezing temps, & water dispersion. Sta-bil makes diesel additive, but there are other manufacturers that do better over all in many of the product benefits.
    The guy that @mikefocke posted in the OP does a great review, not only for gasoline additives, but in another revies he reviews diesel additives as well.
    #20 hill, Oct 29, 2025
