2006 Prius Oem Filter?
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Nate00, Oct 16, 2025 at 2:49 PM.
  1. Nate00
    Nate00 Junior Member
    2002 Prius
    Hello everyone I just got the 2nd oil change with valvoline restore and protect on our gen 2 and its helped reduce consumption. Only 1 quart in about 5k miles with 190K miles so its a lot better than 2.5 quarts burnt like before, also lots of hwy miles now.
    Current filter installed is a 90915-YZZD1 is that fine to use on it? The toyota website is telling me 90915-YZZN1 please let me know!
  2. Tombukt2
    12,768
    2,291
    I'm sure the numbers change several times over whatever so Toyoda tells ya probably correct. 8 run a 3600 on all my Gen 2 whoops
  3. Nate00
    2002 Prius
    Its a bigger filter and the dealer told me its not the right fit….
  4. dolj
    dolj Senior Member
    8,368
    4,264
    Wellington, New Zealand
    How did you arrive at fitting the 90915-YZZD1?
  5. Nate00
    2002 Prius
    Picked off the shelf and incorrect toyota website saying it could fit
  6. BiomedO1
    3,259
    1,719
    SacTown, Ca
    The D1 filter has about twice the capacity of the N1 filter. I believe the D1 is used on the 2.7L and V6 Toyota engines. The diameter of the D1 filter is also larger. The sealing o-ring of the D1 is the same as the outside diameter of the N1 oil filter - not sure if it's going to seal if your car calls for a N1 oil filter.
    There's also the question of at what pressure does the oil filter bypass valve open, if the filter gets plugged. Do they all pop open at the same oil pressure? Is the small displacement engine oil pump capable of generating enough oil pressure to open the bypass valve? While having a larger capacity oil filter is nicer to have, those basic questions above needs to be addressed.
    #6 BiomedO1, Oct 18, 2025 at 1:14 AM
  7. Tombukt2
    12,768
    2,291
    Good been running em for years now in all the toys here screws rt on . No it's not made for . Oh shucks
  8. Nate00
    2002 Prius
    So you’ve used these on your gen 2 prius? No issue?? I have the N1 now so maybe just replace for peace of mind…
  9. Tombukt2
    12,768
    2,291
    It's all I have in the shop fits all my toyoda's so I use it it's on all that are here now 06 07 08 Prius sienna van 02 Corolla 1z.
  10. Tombukt2
    12,768
    2,291
    Makes oil changes very easy
    priumium likes this.
  11. BiomedO1
    3,259
    1,719
    SacTown, Ca
    It's nice to know that they fit, but I wouldn't do that if the car is still under a power-train warranty. That's fair grounds to void that warranty; installing wrong parts on the engine.
    Just my two cents.......
  12. Tombukt2
    12,768
    2,291
    Yeah well that may be I hope to never have to have a vehicle in warranty personally that's for others if ya will
