Torn radio screen protector, 3rd Gen Prius - how do I replace? what's the part number?
Discussion in 'Gen 3 Prius Technical Discussion' started by andreimontreal, Aug 20, 2025.
  1. andreimontreal
    andreimontreal Active Member
    390
    118
    40
    Montreal
    I managed to tear the screen protector without damaging the screen (an alu pipe did that, enough said). Been looking for a replacement part, something, but I'm most likely not using the proper wording. What's the part or an alternative and how do I fix this?
  2. andreimontreal
    390
    118
    40
    Montreal
    I keep finding these "digitizer" parts. Is that what that part looks like? I thought it was just a piece of plastic, nothing electronic.
  3. andreimontreal
    390
    118
    40
    Montreal
    Update again. Took the screen out and it's 100% the digitizer. I ripped off the piece of plastic and it seems like I damaged some electric connectors as well - the digitizer looks pretty but doesn't work anymore. If you need to take the plastic off at least try heat to see if you can undo the glue or cut it with an exacto or scisors.
    I found the digitizer on aliexpress and ebay - now I'm weighin the costs of replacing it or getting a 3rd party NAV which can display the maps.
    Case closed.
  4. andreimontreal
    390
    118
    40
    Montreal
  5. andreimontreal
    390
    118
    40
    Montreal
    PS: looking at the cable, the numbers of wires seems off. Checking now more in detail.
  6. rjparker
    11,027
    6,916
    You need a used 57031-33011 head unit off ebay
  7. Grit
    Grit Senior Member
    6,577
    4,231
    Wilkes Land
    Good luck convincing him on that. He had a post with the rule that no one reply for him to read the check engine light codes and provide him the fix. He reiterated that over and over.
  8. Brian1954
    Brian1954 Senior Member
    2,665
    1,066
    South Central PA, USA
    Deleted my post.
    #8 Brian1954, Aug 21, 2025
  9. andreimontreal
    390
    118
    40
    Montreal
    At Toyota parts, the head unit for 6 inch is: 86804-47110 . The picture has it right.
    Why not replace just the digitizer?
  10. andreimontreal
    390
    118
    40
    Montreal
    What are you on about?
  11. ASRDogman
    ASRDogman Senior Member
    8,051
    4,082
    I'd go the cheaper easier way, replace the whole car....
    Grit likes this.
  12. andreimontreal
    390
    118
    40
    Montreal
    So here's the thing. I bought this 16 (Canadian) bucks piece, and it fixed the issue.
    Next time you want to discourage someone, I want you to take a look into the mirror and think seriously that maybe you are the problem and not the person in front of you. Still waiting an answer to my question, but since you gave none, willing to bet you're full of shit as I never had the check engine on.
    priumium and VelvetFoot like this.
  13. andreimontreal
    390
    118
    40
    Montreal
    No, it was an easy and inexpensive fix.
    ASRDogman likes this.
  14. ASRDogman
    8,051
    4,082
    I was being sarcastic..... :whistle:
  15. andreimontreal
    390
    118
    40
    Montreal
    "And then he started swinging a bat".
    My bad. Someone insisted on being an donkey, got riled up, I was reading every reply in assholeish subsequently.
  16. VelvetFoot
    VelvetFoot Senior Member
    1,407
    545
    New York State
    2026 Prius
    I'm amazed that you were able to fix it. Congrats!
  17. ASRDogman
    8,051
    4,082
    Believe me, I completely understand. Not a problem..... (y)
    It's why I use the ignore function for the know it all's and jerks....
    Finding those parts is the hardest part.
    My brother and I are looking for a glove box latch for a 97 Jetta. I'm possible!
    A friend of his is going to try and 3D Print one....
  18. andreimontreal
    390
    118
    40
    Montreal
    In this case, I checked on yt then jumped on amazon and aliexpress. I asked a couple of sellers, and the cheapest one was quick to respond. Apparently it's a common item that gets fixed on many Toyota/Lexus models. The part seems to be of a good quality too, looks good (better than OG I would say) and works well.
    frodoz737 and VelvetFoot like this.
  19. Sea Glass II
    Sea Glass II Junior Member
    I used your link to the Aliexpress part. It's over $50 US. $41... for shipping. It does not have a part number on it to find elsewhere. Thanks for all this info. I hope I can do the same. Does the hole head have to be taken out to make this fix?
    Cheers!
  20. andreimontreal
    390
    118
    40
    Montreal
    Yes, find instructions for taking out the radio. Remove the metal brackets on the side of the radio. Then it's 4 screws. Take the face of the radio off, undo the ribbon cables, 4 more screws around the screen and it comes off - the digitizer is attached with a ribbon cable as well.
    Are you looking at the product in post 12? I see 14.48 Cad and free shipping.
