Generation 4 on a tow dolly
Discussion in 'Gen 4 Prius Main Forum' started by motopat, Oct 19, 2025.
  1. motopat
    motopat New Member
    2018 Prius
    Who has pulled a generation 4 on a dolly? Front wheels up rear down. I haven't been able to get a clear answer of any problems.
    I did tow a generation 3, it would get wonky after but would correct itself in a mile or two.
    Sorry if this has been covered long ago I just couldn't find it...
    Thanks, Pat
    Tande likes this.
    51,841
    should be towing advice in the o/m?
  3. BiomedO1
    3,494
    1,815
    SacTown, Ca
    As long as it's not an AWD; your good with what you described. I've also done a gen3 on a U-haul dolly. Just double check the parking brakes before taking-off.
  4. motopat
    motopat New Member
    2018 Prius
    Thank you!
