Featured Some Good News On the Sodium Ion Battery Front?
Discussion in 'Prius, Hybrid, EV and Alt-Fuel News' started by PriusTech, Oct 20, 2025.
  1. PriusTech
    PriusTech Active Member
    246
    104
    Reno
    jacktheripper and PriusCamper like this.
  2. jacktheripper
    jacktheripper Senior Member
    266
    535
    As the first U.S. company to not only R&D but actually put Sodium-ion batteries into real, heavy use, we’ve learned a ton — and it’s not always rainbows and sunshine . It’s a powerful technology, but like everything else, it has its pros and cons. Thought I’d share a quick update from our journey so far:
    Cons:
    1. Still pricey — We don’t have enough competition at the cell manufacture side to push prices down. yet.
    2. Energy density isn’t quite on par with lithium yet, meaning it’s a little heavier for the same amount of energy.
    Pros:
    1. Built for extreme conditions — hot or cold, it just doesn’t care.
    2. Super reliable, with a wide voltage range (1.5V–4.0V per cell and even wider in some cases). It’s tough to accidentally drain or overcharge these things.
    3. And most importantly — safety. Compared to lithium, a punctured sodium-ion cell is honestly kind of boring… no fireworks, no drama:sleep:
    We’ve seen amazing progress this year and are continuing to invest heavily in this technology. Fingers crossed that by 2026, we’ll be able to smooth out most of the current downsides.
    Thanks to everyone who’s been part of this crazy journey and supported us along the way — stay tuned, more exciting updates coming soon to the Prius community!
    Best,
    Jack
  3. drash
    drash Senior Member
    2,576
    1,319
    Upstate NY
    So they do sell stuff with these batteries. For those who need a portable power station designed for the cold there is this:
    BLUETTI Pioneer Na Sodium-Ion Portable Power Station
    As @jacktheripper said it's a little pricey and a little heavier than your typical LFP Power Station of the same storage and power output but doesn't seem bothered by the cold.
    VelvetFoot likes this.
  4. VelvetFoot
    VelvetFoot Active Member
    532
    169
    New York State
    2026 Prius
    Is it bulkier? Doesn't look it.
  5. bwilson4web
    16,187
    Can we get them in AAA or AS size?
  6. drash
    drash Senior Member
    2,576
    1,319
    Upstate NY
    The same size and weight as the Bluetti AC180 which is 1,152 Wh so its not a tremendous difference.
  7. VelvetFoot
    532
    169
    New York State
    2026 Prius
    As a side note, I have two of them sitting around. I should put them through their paces. :)
  8. PriusTech
    246
    104
    Reno
    The vid says
    Pros
    1) will be half the cost of Lithium
    2) will last 3 to 6 times as long. That's up to 50 years. So it outlasts your car and then you can use it for your solar system
  9. VelvetFoot
    532
    169
    New York State
    2026 Prius
    Will there be fewer concerns about obtaining the raw materials to manufacture this type of battery?
    PriusTech likes this.
  10. PriusTech
    246
    104
    Reno
    YES
    Pros
    3) production is way more environmentally friendly than Lithium
  11. VelvetFoot
    532
    169
    New York State
    2026 Prius
    Sounds like a winner.
  12. Skwekel
    Skwekel Junior Member
    I see NexPower, SodiumHybrid - com, Is out of stock of everything. Do we know when these products will get back in stock? Also I see GreenBean has Sodium Ion Batteries and Dr. has a link to them on their page. Are these the same batteries, or modules? Does NexPower partner with GreenBean?
