AWD vs FWD
Discussion in 'Gen 5 Prius Main Forum' started by HamiltonPrius, Oct 14, 2025.
  1. VelvetFoot
    VelvetFoot Active Member
    532
    170
    New York State
    2026 Prius
    Have you seen much of a mileage hit, or is it hard to tell with a Prime?
  2. reservoirblue
    reservoirblue Member
    95
    73
    Woodacre, CA
    2024 Prius Prime
    SE
    Good question. Intuitively, yes,but i must admit I have not been paying much attention before or after. Handlig, especially cornering is noticeably better. The car feels nicely planted.
    VelvetFoot likes this.
  3. douglasjre
    douglasjre Senior Member
    2,164
    715
    Null, NL
    Pls send pix of wider tires on car. This sounds like a nice size. Who makes the rims
  4. reservoirblue
    95
    73
    Woodacre, CA
    2024 Prius Prime
    SE
    I kept the original rims minus the plastic covers. Pics will follow at some point :)
  5. douglasjre
    2,164
    715
    Null, NL
    Due to rims from third generation 4th generation and the Prius v fit on the 5th generation?
  6. Hammersmith
    Hammersmith Senior Member
    2,302
    2,316
    North Dakota - USA
    2023 Prius
    Limited AWD-e
    no
  7. reservoirblue
    95
    73
    Woodacre, CA
    2024 Prius Prime
    SE
    mva, douglasjre and VelvetFoot like this.
  8. VelvetFoot
    532
    170
    New York State
    2026 Prius
    Cool. '55s still have plenty of sidewall height.
    douglasjre likes this.
  9. reservoirblue
    95
    73
    Woodacre, CA
    2024 Prius Prime
    SE
    yes. I'm not a fan of the current short sidewall fashion, but for the 215 I'd consider anything taller "overkill".
  10. VelvetFoot
    532
    170
    New York State
    2026 Prius
    Also, nice pics of your reservoir blue Prius. Mine currently is on a ship off the coast of North Carolina. :)
    reservoirblue likes this.
  11. douglasjre
    2,164
    715
    Null, NL
    What's the details on the rims like who makes them and where'd you get them?
  12. VelvetFoot
    532
    170
    New York State
    2026 Prius
  13. Winston Smith
    Winston Smith Active Member
    357
    240
    OH
    2024 Prius
    LE AWD-e
    Is the Prius V the wrong offset? The bolt pattern is correct and not shared with the Gen IV regular Prius.
    I gave my 5x100 Prius wheels to a neighbor with a Corolla and have looked at Prius V 5x114.3 wheels for winter tire use.
  14. ETC(SS)
    7,134
    AWD????
    In a - PRIUS??? especially a G5 PRIUS???
    FWD is worth more to ME.
    No contest.
    It means fewer potential maintenance issues, and more likely to be driven by a cost-conscience owner who might have actually lifted the hood and checked their own oil by themselves every now and then.
    MAYBE even as often as the owner's manual tells them to.
    AWD doesn't bring enough additional capability to the game for a small, low slung eco-hatch to be worth the squeeze in my never to be humbled opinion.
    Isaac Zachary likes this.
  15. reservoirblue
    95
    73
    Woodacre, CA
    2024 Prius Prime
    SE
    Thanks.
    If you mean the ones in my pics, they are the standard rims that come with the 17" wheels minus the abs wheel covers.
  16. Gorgonzola
    Gorgonzola Junior Member
    31
    New Hampshire, USA
    2024 Prius
    LE AWD-e
    @reservoirblue - looks like you put center caps on the wheels to cover the hubs. Where did you get them/do you have a part # you can share?
  17. reservoirblue
    95
    73
    Woodacre, CA
    2024 Prius Prime
    SE
    Measured and bought them on Ebay. They are generic and cost about $ 10 for four ;) 56/60 mm.
    #37 reservoirblue, Oct 24, 2025
    Gorgonzola, douglasjre and VelvetFoot like this.
  18. VelvetFoot
    532
    170
    New York State
    2026 Prius
    I just did a search on TireRack.com . Selection of 195 60 17 tires is minuscule in comparison to 215 55 17... and the 215's are cheaper too. Unreal.
  19. ColoradoBoo
    ColoradoBoo Senior Member
    1,231
    824
    Monument, Colorado USA
    Yes, there's two drain/fill plugs on that little electric motor back there. Let me look at my maintenance notes:
    In my 2021, the top fill plug is easy to get to but the drain is NOT...ended up buying a long (8-inch) 10mm hex to be able to reach in there. Then, just refill with Toyota WS, takes about 1.4 Qts. I hate those pumps so just stuck a long hose in there with a funnel and poured it in from the right side of the car. I did mine at 26,000 miles but it wasn't even close to dirty will do future changes every 40,000 miles. Hey, she's almost due! It's the same funnel/hose I use for Prius transmissions...feed it down next to the firewall in the engine bay.
    You'll need two crush washers, 90430-A0003.
  20. Mendel Leisk
    41,321
    Thanks for the explanation. Concur about pumps: if practical, feeding in a tube with funnel is my choice; gravity is very reliable.
