Is there a way to safely disconnect the main airbag without disc the 12v battery?
Discussion in 'Gen 2 Prius Main Forum' started by xw20_driver, Oct 30, 2025 at 5:10 PM.
  1. xw20_driver
    xw20_driver Junior Member
    78
    40
    PNW
    I want to pull and reseat the steering wheel because it is off by a spline. When I last did it I disconnected the 12v battery cable. Is there a safe way to disconnect and remove the steering wheel airbag without disconnecting the 12V battery so I can preserve the MFD settings and records?
  2. ChapmanF
    17,928
    There might be, if you look in the wiring diagram and find all the fuses for circuits (there might be more than one) powering the airbag system, and you pull all of those (and then wait the prescribed amount of time before working on any airbags, just as if you had disconnected the battery).
    Toyota Service Information and Where To Find It | PriusChat
    I haven't looked, but you might end up finding some of the same circuits that power the airbag system also power the other ECUs whose settings you want to retain, so you may or may not be able to accomplish what you want.
    xw20_driver likes this.
  3. Hayslayer
    Hayslayer Member
    367
    207
    The other issue you'll probably run into is SRS / air bag system faults that may or may not reset. Do you have techstream or a good diagnostic tool that can reset them? Personally, I never touch air bag systems with the 12v battery connected. It's a self-preservation instinct after having seen a few activated for fun. Gotta be careful with that stuff, some models have internal inertia activation mechanisms, not just impact sensors in the car body.
  4. Mendel Leisk
    41,149
    I'd take the 12 volt battery disconnect ramifications, however remote, over the potential for airbag explosion, any day.
