Intake Manifold and EGR Cleaning/Replacement - How hard is it really?
Discussion in 'Prius v Care, Maintenance and Troubleshooting' started by ksyolsen, Oct 26, 2025 at 6:59 PM.
  1. Mendel Leisk
    41,149
    The only significant difference in 3rd gens (2010-2015) was Toyota FINALY ditching the low-friction piston rings, partway through 2014 model year (the earlier rings have proven prone to oil consumption).
    there were revisions to the EGR valve, and the intake manifold (apparently EGR passage revisions), but I’m sceptical they accomplished anything.
    I’ve got a 10, have cleaned the EGR twice now. The car has about 65k miles, we purchased new in 2010.
  2. rjparker
    9,999
    6,185
    Since you bought the parts I would install them after I verified they were oem. However I would keep the old parts just in case.
    I would definitely change the oil every 5k miles and change the engine coolant every 30k. Those are the things that have worked for me on a 340,000 mile v.
    I proactively changed the egr valve with the redesigned version and had the latest ecm software updated. In Europe there was an October 2014 recommendation to update the ecm to extend head gasket life. This was the only Toyota recommendation specially addressing head gasket fails and was released to Europe only. However it is assumed the US code, which was updated many times, would have included any reliability improvements.
    Your car has had the inverter issue resolved which is a good thing. My inverter failed early as well without warning. I have changed the hv battery with oem and the brake booster which had a special extended warranty, now expired.
    #22 rjparker, Oct 28, 2025 at 12:00 PM
    ksyolsen likes this.
  3. ksyolsen
    ksyolsen New Member
    Sunday
    Haslett, MI
    2013 Prius v wagon
    Thank you! Yeah, I plan on keeping the old EGR valve and cooler to clean and store as spares.
    What all do I need to do while I'm in there?
    Intake Cleaning
    EGR Pipe cleaning
    EGR valve swap
    EGR cooler swap
    PCV valve replacement
    Spark plug replacement
    do I need a new intake gasket?
    Also, I was recommended to replace the water pump while I have it all apart, as well as I have read people suggest the thermostat too since it's inexpensive.
    Given everything we've talked about, should I go ahead with those replacements as well? It's about $260 for an Aisin water pump and thermostat from RockAuto (the Aisin one from Amazon is $145 but has some sketchy reviews).
    I look at it in two ways:
    - Replace now while I have it apart as a form of "insurance"
    or
    - Wait on the water pump. Keep an eye on temps over the winter using OBD scanner. And then either: in 30k miles replace when I do a coolant change, or if temps start climbing then do it?
  4. Mendel Leisk
    41,149
    With 165k miles, if the water pump's never been changed, it's living on borrowed time.
    Amayama will have one at my door for ~$163 CDN, all-in, and so far never any extras, other than price and shipping. No tax, duty. Might be different now, with current US situation. Anyway:
    They'll also have the thermostat, worth replacing as well.
    If you don't know the car's history, sure. They were supposed to be changed (per Toyota) at 120k miles or 12 years (150/12 in CARB States).
    With 165k miles I would definitely replace all the pliable gaskets interfacing with the intake manifold; they're not expensive. My Amayama invoice, in 2022:
  5. ksyolsen
    ksyolsen New Member
    Sunday
    Haslett, MI
    2013 Prius v wagon
    You sir are amazing, thank you!! I will check those out. Thank you!
    Edit: Not bad! (assuming no exorbitant fees). I don't see the thermostat though.
    Thermostat from RockAuto:
    Searching for part number on Amayama:
  6. Mendel Leisk
    41,149
    You will know the bottom line, before committing. For me in Canada it's definitely cheaper, to ship from them (either from Japan or UAE), versus from the States, about 50 km's to the south of us. :rolleyes:
  7. ksyolsen
    ksyolsen New Member
    Sunday
    Haslett, MI
    2013 Prius v wagon
    Here 's my cart. The EGR valve kit I ordered from eBay comes with the gaskets (except the egr cooler to exhaust one - 25685-37010).
    I think this should be all I need.
    Water pump (THANK YOU for showing me this site! Looks like it will save me quite a bit!)
    Thermostat
    PCV Valve
    Intake gasket (had to order from Amazon, since they are out of stock)
    EGR Cooler to exhaust gasket (just in case)
    throttle body gasket (in case I end up taking that off)
    I already have:
    - spark plugs
    - EGR valve and cooler on order
    - coolant
    It arrives later than when I was planning on doing it, but oh well, I don't think a few extra hundred miles will kill it at this point (knock on wood ha!)
    Anything I am missing?
  8. Mendel Leisk
    41,149
    These are the 3 pliable gaskets involved, all at the intake manifold, copy/pasted from my invoice:
    #1: Toyota 17177-37030 - GASKET, INTAKE MANIFOLD TO HEAD, NO.1
    #2: Toyota 22271-37010 - GASKET, THROTTLE BODY
    #3: Toyota 25628-28010 - GASKET, EGR INLET
    I'm not sure of your part no's, some may be supersessions, not sure. Anyway, those are the 3 worth changing.
    Everything else is steel, in my opinion quite durable.
    There is one gotcha with those steel gaskets, they're all kinda dimpled in, so you can place them concave or convex. I pulled mine off the first time without noting, but later watched a youtube, a mechanic who very carefully removed them (for first time), and noted the direction of the dimples. I made a sketch (attached).
    In the attached pdf, the mention of "applying tape" is NOT required, IF you remove the cooler lower bracket nut AND stud, then you don't need to remove the studs at the cooler connection to exhaust manifold, you're able to just pull the cooler straight forward, since all the lateral positioned studs have been removed. Besides saving the hassle of backing out those two studs, they will retain the gasket there, which is easy to miss, drops down, hard to recover. Also facilitates reinstall, just hang the gasket on the studs.
    #28 Mendel Leisk, Oct 29, 2025 at 2:31 PM
  9. ksyolsen
    ksyolsen New Member
    Sunday
    Haslett, MI
    2013 Prius v wagon
    Thank you for the breakdown/diagram :)
    Looks like this was superseded with 17177-0T020
    Check!:D
    This one comes in the EGR kit according to the pictures, so should be good there too! :cautious:
    Thanks!!
  10. Mendel Leisk
    41,149
    Ahah, a supersession. (y)
    There's one gotcha with the gasket at throttle body, there's a plain version (the part no I posted is that one), and there's also one with an extra mesh spanning the opening. Priuschat member @Merv Himself published a youtube on EGR cleaning, had one of the mesh style, found it didn't fit, just reused the existing.
  11. ksyolsen
    ksyolsen New Member
    Sunday
    Haslett, MI
    2013 Prius v wagon
    The valve arrived and the cooler is out for delivery as well.
    Here’s what came in the valve kit. Seems legit to me. Anything stand out to you or does it check out?
    Thanks!
  12. Mendel Leisk
    41,149
    The gasket in the bag with red tape looks to be for the EGR pipe to intake manifold connection.
  13. rjparker
    9,999
    6,185
    Yes you have oem and it's the kit version with gaskets built for the tsb at 1/3 off the valve alone.
    There are at least seven visible differences disregarding packaging (which often is counterfeited as well).
    Two take a good eye to detect.
  14. ksyolsen
    ksyolsen New Member
    Sunday
    Haslett, MI
    2013 Prius v wagon
    Sweet! thank you!
    From that image looks to me like the following?
  15. rjparker
    9,999
    6,185
    Two hard ones remain but you did point out the bottom right screw head and the two bottom arrow items I was not counting.
  16. ksyolsen
    ksyolsen New Member
    Sunday
    Haslett, MI
    2013 Prius v wagon
    Is the OEM one slightly curved, and the aftermarket one straight?
    I'm at a loss for the other one haha.
  17. bisco
    51,719
    looks like the ends of the stud threads are different
  18. bisco
    51,719
    and there's something shiny on the bottom of the round black part
  19. rjparker
    9,999
    6,185
    Correct. Plus the black cable receptacle is at an angle on the new oem.
    Final exam
    Oem or counterfeit?
  20. ksyolsen
    ksyolsen New Member
    Sunday
    Haslett, MI
    2013 Prius v wagon
    Counterfeit, final answer
    rjparker likes this.
