Intake Manifold and EGR Cleaning/Replacement - How hard is it really?
Discussion in 'Prius v Care, Maintenance and Troubleshooting' started by ksyolsen, Oct 26, 2025 at 6:59 PM.
  1. ksyolsen
    ksyolsen New Member
    Sunday
    Haslett, MI
    2013 Prius v wagon
    EGR Cooler from eBay Japan arrived as well
  2. Mendel Leisk
    41,154
    Options, as needed: your existing EGR valve could be fine. Not that hard to clean either. The cooler is tougher to clean but doable as well, if it comes to that.
    ksyolsen likes this.
  3. ksyolsen
    ksyolsen New Member
    Sunday
    Haslett, MI
    2013 Prius v wagon
    sounds good! It’ll be interesting to see what condition they’re in!
    also, I ordered a cheap oil catch can on Amazon with some rewards points I had because I figure why not if I’m already in there.
    My understanding is you just run some tubing from
    The PCV system / breather hose to the catch can and then the output just gets routed back to the intake and you can mount it by the front driver side headlight housing? (That’s my very rough generalized understanding haha)
  4. Mendel Leisk
    41,154
    The most expedient oil catch can connection is to cut the existing PCV hose at the middle, push on 3/8” brass barb splicers (PEX connectors work as well, and are more easily removable as needed), push 3/8” ID fuel line (SAE-J30R7 or …R6), run those to your oil catch can inlets and outlets.
    To return the system to stock, a replacement hose is about $10 USD, part no: 12261-37060. It’s item 12661 here.
    I went “upmarket” some on my OCC, have dual Moroso 85474 Air/Oil separators. They’re pricey though, and getting more so.
    Lots do mount by the drivers headlight; I opted for below the intake manifold, on a bracket atop lower cross beam (front jacking point beam. They’re bottom draining, most practical access during oil change:
    #44 Mendel Leisk, Oct 31, 2025 at 9:59 AM
  5. Mendel Leisk
    41,154
    Looks like I’ve reiterated what’s mostly covered here.
  6. ksyolsen
    ksyolsen New Member
    Sunday
    Haslett, MI
    2013 Prius v wagon
    Perfect, thank you!!
    I'll check that out :)
  7. ChapmanF
    17,933
    The comparison I keep wanting to see is how the revised Toyota valve compares inside to the original Toyota valve.
    So far, everybody who has bought one of the revised ones has been like, "not me, I'm not opening the cover on this valve I just bought!".
  8. rjparker
    10,001
    6,187
    I tried one once and it took a no code original egr to a P0401. It would stick open right out of the box. I did not take it apart to avoid trouble returning it. It went back and the updated Toyota version went in.
    From an Amazon review:
    #48 rjparker, Oct 31, 2025 at 1:13 PM
  9. ChapmanF
    17,933
    Yeah, that's the inside of a cheap knockoff. We've seen those before.
    There is a genuine Toyota-issued update to the original Toyota EGR valve. We know it's physically a bit larger and the wire harness needs to be untaped a little for the plug to reach.
    That's the one I'd be interest in seeing inside pictures of.
