Brake Booster Malfunction
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by KBee, Feb 16, 2022.
  1. rjparker
    10,025
    6,202
    I would just replace the master cylinder for $1300 or $1400 (you listed two different prices) and call it a day.
    That installed price is decent assuming new parts; they may be getting a good Toyota discount on a pre-tariff part that could go away. Jump on it.
    I don't understand why the pump costs $1800 installed, it is usually cheaper. Perhaps this part was hit with a tariff.
    You could contact Toyota Corporate but it will be a waste of time on a 14 year old 190k car. Their 10 year 150k warranty on this system was already extended from the factory 3 year 36k mile warranty.
    #101 rjparker, Nov 5, 2025 at 9:29 PM
  2. ASRDogman
    ASRDogman Senior Member
    7,506
    3,885
    The main reason to replace both is because of cost. And it's very likely when one fails,
    the other one is close behind.
    There is a lot of work involved in removing each. So if you only replace one part, when the other
    fails, you have to pay the labor, again. You may get lucky, and if you are willing to take that chance,
    go for it.
  3. ChapmanF
    17,968
    The unit above has around a dozen little valves in it, nearly all of the possible points of failure for the typical "internal leakage" issue.
    The unit below just has a lot less that's likely to go wrong.
    If an internal leakage issue gets addressed quickly, anyway. Letting it go until the pump is making runs just seconds apart has a side effect of putting a whole lot of extra use on the pump and accumulator, so that can make it more prudent to replace that unit as well.
