Rear Passenger Seat Belt Wont Retract 2014 Prius
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by DPZ, Nov 8, 2025 at 1:40 PM.
Tags:
  1. DPZ
    DPZ Junior Member
    Arizona
    The passenger-side rear seatbelt will not retract. It is pulled all the way out and has zero retraction. I removed the trim panel to expose the tensioner behind the headrest. I was then able to carefully wind the belt all the way back in hoping that it would then reset. Unfortunately it didn't do anything. Upon slowly pulling the belt out a little bit it still did not have any tension and does not rewind even an inch. The Prius is a 2014 and I have owned it since 2017. I don't think it was ever in an accident and the seat belt is not filthy dirty. It was working fine until one of my daughter's friends pulled it all the way out saying it would not go back in(retract). Does any one know how to repair this? Is there a tab I need to push or does it have to be completely replaced?
    Thank you
  2. BiomedO1
    3,414
    1,774
    SacTown, Ca
    The return-spring and possibly locking mechanism is broken. replace it with a junk yard or new unit.
  3. DPZ
    DPZ Junior Member
    Arizona
    can the spring be rewound
  4. ChapmanF
    17,980
    Offhand, I would guess not. It isn't built to come loose like that, so it seems the most likely explanation is that something broke, rather than slipping off in some kind of reversible and rewindable way.
    But yours may be the first post ever about such a thing happening, so there might not be a lot of PriusChat experience to bring to bear on your question.
  5. BiomedO1
    3,414
    1,774
    SacTown, Ca
    I don't think so; it's like a garage door spring. More than likely the end tab of the spring broke off. You can probably take it apart and bend a new end-tab, but I'd probably look at cost and availability of replacement first, to see if your wasting your time and effort.
    DPZ likes this.
  6. DPZ
    DPZ Junior Member
    Arizona
    Have you ever taken one out? I just called a junk yard and they wanted $50 for one that they would pull from a wrecked car. A rebuild service charges $80.
  7. BiomedO1
    3,414
    1,774
    SacTown, Ca
    IMHO; my time is worth more than $50. If it's the right color and in good shape, I'd probably go for the junk yard unit. that belt should only be bolted down at one or two points - so quick and easy.
    You can tinker with the old one when you have time to kill.:D:whistle: and you'll probably find some use for that belt.
    DPZ likes this.
  8. DPZ
    DPZ Junior Member
    Arizona
    Thank you. I was just concerned that a used one at a junk yard has been in an accident . There are comments online about post crash or non crash tensioners. Does that matter?
  9. ChapmanF
    17,980
    I'm not sure the rear belts have tensioners. You'd know if it does; there'd be a yellow electrical connector on it.
    I think some retractors have tension-limiters also, which twist irreversibly in a hard-enough crash. I don't remember for sure, but there might be a label or mark on the belt at the point where it's supposed to stop pulling out before the limiter has twisted, so if it can be pulled out farther than that, it shouldn't be reused.
    DPZ likes this.
  10. DPZ
    DPZ Junior Member
    Arizona
    has anyone removed one removed the rear seatbelt tensioner. I do not see any electrical connectors
  11. DPZ
    DPZ Junior Member
    Arizona
    So I made another attempt at winding it carefully and was able to get it to wind up and stay wound up. However now it wont unwind at all and is locked.
  12. ChapmanF
    17,980
    I'm not surprised. The front retractors include tensioners: small bombs that are detonated by an electric current on the yellow connector, and pull you back hard in the seat.
    Unless I'm wrong, the rear belt retractors just plain don't have that.
    DPZ likes this.
  13. DPZ
    DPZ Junior Member
    Arizona
    Update.. I was able to remove the rear belt.. had to remove all of the trim pieces as if you were removing the hybrid battery. Also had to remove the trim piece that goes around the rear passenger window as that one covers the seat belts mounting bolts.
    I am either going to send it to one of the following restraint repair companies:
    MyAirbags - We Help You Save Money On Seatbelt And Airbag Module Repairs
    Seat Belt Repair Service | Airbag Module Reset - Safety Restore - Safe
    Home
    Airbag Modules Reset & Seat Belt Repair – Repair My SRS
    Seat Belt Repair | Get Your Seat Belts Repaired - Fast Turnaround
    Or
    I am going to a junkyard to find a match.
    What I am not going to do is go to the dealer and pay over $200 for a new ...!
    #13 DPZ, Nov 8, 2025 at 3:49 PM
