Walmart W46B24R battery
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by pasadena_commut, Nov 6, 2025.
  1. pasadena_commut
    pasadena_commut Senior Member
    2,608
    771
    Southern California
    FYI
    Bought a new 12V for the Prius yesterday from Walmart. Model number is W46B24R and it was the only Prius battery on the shelf. A few observations that might be of interest.
    First, the battery shown on the website as I write this:
    Free Shipping! EverStart Platinum AGM Automotive Battery, Group Size S46B24R, 12 Volt, 410 CCA - Walmart.com
    is not what they had in this SoCal store. The one on the web site looks like the OEM battery in my car, black everywhere and with a grid pattern on the ends. The battery in the store is marked "W46B24R", which isn't on their website, and the sticker says "410 CCA Res. Cap 75". It does not have an Ah rating on the battery anywhere. The top is black but the rest is grey, and the sides are smooth, without the grid pattern on the ends. It is still made in Korea. Serial number starts with "HAN". I will post a picture soon.
    The website price is $189 "when purchased online" (or not, because the one online is not the same battery), but $195 in the store. Plus of course the various fees and taxes which brought the total to $230.95. $12 back if/when I bring the old OEM one in.
    There is a vent hole of the expected size in the expected place in the edge of the black lid near the positive post. However, looking through that hole it appears to dead end against the side of the lower case. Perhaps that is some sort of film there that the vent adapter will penetrate, but it sure looks like a wall of plastic. So at this point I would give 10:1 odds for it not being ventilated.
    The weight was 14360 g, nearly 4 kg more than the current weight (10638 g) of the 4 year old one in our Prius. That OEM battery may be dried out, but it isn't 4 kg dried out. There must be a lot more lead in the Walmart model. Also that is 31.7 pounds, but the Walmart website says 26 pounds.
    Manufacturing date was 7/25 and voltage was 12.43V.
    Spent most of yesterday charging it fully, before the planned 2 hour discharge (to estimate capacity). Started at 13:30 and gave up at 23:30. The BatteryMinder 1500 charger was stuck at 1.5A from 13:30 to 20:30, then it was in absorption phase until I gave up at 23:30. Garage was getting cold, I didn't want to do the initial charge too far from 20C-25C, and it was down to 19.1C.
    This morning used the HF "Viking" tester in CCA mode and it read:
    SOH 100% SOC 100% CCA 717 13.00V 4.18 mOhm
    Since it wasn't really 100% charged, wanted to top it off. The BM1500 has a tendency to do a long 1.5A charge even when it starts on a nearly fully charged battery, so this morning charging was finished with a BatteryTender Jr. That only took 4 minutes at around .7A to get up to 14.38V where it switched to absorption while the current fell rapidly until it hit float mode 16 minutes later.
    Tomorrow hopefully I can do a 2 hour 2.5A discharge test to get a rough estimate of the capacity, charge it up again (which should only take around 4 hours with the BM1500) and then into the car it goes. My gut feeling is that this battery is more than 45Ah, more like 50 or 55 Ah. We will see.
    xw20_driver likes this.
  2. pasadena_commut
    2,608
    771
    Southern California
    Here are the pictures. The battery is of course 90 degrees at each corner, the trapezoidal shape is a camera distortion.
    The vent hole dead ends into something but it probably isn't the grey plastic of the lower case. It looked that way with my flashlight but with my son's cell phone light it is closer to white, and has a texture like a very tightly packed furnace filter. So we think that is more or less what it is, a dense plastic fiber mesh. Note that this material can be seen around the port hole in the upper left and upper right corners of the square that holds that circular bit.
    Did the 2 hour discharge yesterday on the fully charged battery (12.94V, so a little surface charge still on it), exactly 5Ah out, and after 2 hours VOC was 12.70V (and had been flat for an hour). Capacity? Good question. Many AGM SOC tables put 12.70V at 100%, others have it between 90% (12.75V) and 80% (12.50V). We can't use 100%, as that would give infinite capacity. Assume a line between those points and it comes out to:
    SOC = 40*V - 420 ; {12.5<= V <= 12.75}
    Plug in 12.7 to get SOC=88%. Total capacity would be 5Ah * 100/12 = 42 Ah. Very approximately. Probably yet another 45 Ah battery. Makes sense, the plate geometry does not have a lot of wiggle room given the case geometry, at least if the long axis of the battery is perpendicular to the plane of each plate, and the capacity is proportional to the plate area.
    The battery does test bizarrely high though with the HF "Viking" tester. After this discharge,recharge, and sitting overnight it read:
    SOH 100%, SOC 100%, Ah 100, 13.01 V, 4.12 mOhms (more than twice the Ah of any other S46B24R)
    SOH 100%, SOC 100%, CCA 728, 13.01 V, 4.12 mOhms (in CCA mode, 75% higher than the sticker)
    The new battery recovers much faster than the old one. Will plot the discharge/recovery curve and post it later.
    Technical note. While it is "quick" to discharge 5Ah at 2.5A in 2 hours, recharging takes considerably longer. The BatteryMinder 1500 puts out a maximum current of 1.5A, so one might think, "5/1.5, it will take 3.3 hours". Nope. The bulk charging phase is relatively quick and that took 2.5 hours, but the absorption phase was only down to .37A after 6 hours and had not completed (as far as the charger was concerned). I didn't want to stay up any longer (it was 23:30) at that point and unplugged it, but I estimate it was going to finish at 6.5 or 7 hours. Oddly, charging faster during bulk doesn't necessarily decrease the total time significantly. See the two traces for .2C and .4C about 80% of the way down the page here:
    How Fast Can an AGM Battery be Charged? - Marine How To
    #2 pasadena_commut, Nov 8, 2025
  3. pasadena_commut
    2,608
    771
    Southern California
    Two problems installing it, one small, one big:
    1. The hole for the vent is slightly larger than the adapter that fits the OEM battery. Gave it 3 wraps of teflon tape and it will probably stay in.
    2. Battery doesn't fit where the old one did. The battery is within the size spec for S46B24R batteries (the Duralast one from Autozone is 9.3", this is 9.25"), but it is about 1" longer than the OEM battery and apparently slightly wider, although we couldn't even measure the difference in that direction. When I tried to lower it into position it either hung up on the anterior part of the "cradle" (the part that keeps it from sliding forward) or it jammed in the side to side (with respect to the car's axis) direction. Basically the black cradle needs to shift about 1/4" in the anterior direction and about 1/8" outward towards the passenger side. Except there isn't that much play available in the holes around the two bolts holding it, and the little metal prong from the black "tray" engages with the body and that also limits motion. Stupidest battery tray ever - really glad I didn't run into this issue changing a failed battery in a Walmart parking lot on a trip!
    Is there another "tray" available?
    Note in the second picture the bigger one looks taller than it is because it is sitting on a doubled over piece of cardboard. It may be 1/16" to 1/8" taller than the OEM though.
    Thanks.
  4. Brian1954
    Brian1954 Senior Member
    2,176
    852
    South Central PA, USA
    Does your Gen 2 Prius have the smart key system?
    There are two different battery sizes. A smaller battery if the car does not have the smart key, and a larger battery if the car has the smart key. The Walmart battery that you purchased is the larger battery.
  5. Hayslayer
    Hayslayer Active Member
    390
    220
    The old battery you have is NOT an original TrueStart S46B24R. The prius TrueStarts didn't have hard plastic handles as far as I can remember, they had cloth strap handles. That's likely an aftermarket model that someone slapped a sticker on, and looks to be maybe a S34B20R size, which was used on Prius Gen 2 models 2004-2009 that did not have SKS, and some C models iirc. Actually, looking closer, the sticker has a 21181 number on it, which is the S34B20R.
    Also, look at the base of the terminals on the old battery, that's not the Toyota design. All those little spokes sticking out around the circumference has 3rd party aftermarket written all over it, like a Marathon or something. Marathon also has the ribs on the edges of the top like your old one. I think Interstate is the same. probably all from the same source.
    This link is for the S46 model, idk if they have a S34, but if they do (or did) it would be similar. It even has the plastic handle. If you look at the last photo in the link you can even see the impression of a seal cap under their marathon sticker that is a match to the seal cap on your old battery. Maybe Toyota re-sourcing supplies and rebranding during covid, or someone pulling a fast one on you. I have a couple S46 models in the garage. A 3/22 and a 1/19 date sticker. They're both YUASA, as it should be.
    and...an S46 bracket is a bolt in replacement for a S34 bracket. A few bucks at a salvage yard or about $30 new from Toyota..
    Best S46B24R 12V Battery for Toyota Prius | 2004-2018 Models | AGM Auxiliary
    #5 Hayslayer, Nov 8, 2025
    dolj and Brian1954 like this.
  6. pasadena_commut
    2,608
    771
    Southern California
    Sadly the battery is is just what it claims to be. That's the battery the local Toyota dealers were selling at the time. Not as good as the ones they were selling years earlier? Shocking.
    It does look like the picture in that link, but the specs don't match. The Marathon battery is 9 3/4" long, like the Walmart one, not the 8" of the smaller battery.
    The car is nonSKS. I thought by 2007 Toyota had given up on the 36 Ah vs 45 Ah battery and was just shipping all the cars with the larger battery. Apparently doing so by making a midget S46B24R.
    Going to try to find a tray at the LKQ tomorrow. Part number is 74440-47020 for the larger one.
  7. Hayslayer
    390
    220
    The battery in the link is a S46 size, your old battery is a S34 size. Even the part code on the sticker is a S34 code, but it could be from any third party. I have to admit, it's the only battery I've ever seen with a wrinkled sticker. Google the number 00544-21181-320. It shows as a S34 TrueStart part code. Regardless, you can't go wrong by moving up to the S46 size.
  8. pasadena_commut
    2,608
    771
    Southern California
    I recall that sticker being flat when I bought it.
    One more nail in the coffin for the "Ah" mode on the HF Viking battery tester. I thought it was 45 Ah (probably misread the 45 RC) and so set that, and the tester would read 45 or 42 or whatever. I bet if I set it to 70 or 36 it would just return that value. Or not, because the Walmart battery returns 100 when the tester is set to 45.
  9. pasadena_commut
    2,608
    771
    Southern California
    Went to the LKQ today and picked up a tray. Looked at 5 cars and every one had rust on the tray. Luckily one just had a little bit in a couple of spots, so I took that one home, sanded off the rust, cleaned it up with isopropyl alcohol, and painted those areas. We only had red touch up paint on hand, so it looks bad. Not that anybody is ever going to see this tray, so ugly is not a problem.
    LKQ pulls the 12V batteries out of the cars before putting them out, and while I would have thought they would have thrown the hold down and its nut and bolt into the battery well that wasn't the case on any of them. However I did find a hold down eventually in the same car as the least rusty tray. It was buried under a pile of plastic panels, a spare tire, and all sorts of other garbage in the trunk area. Wasn't sure if it was identical to the one on my car now, so took it home too, just in case.
