Lowest mile Gen 2 Prius. 5,156 miles. Back on the road after sitting 12 years.
Discussion in 'Gen 2 Prius Main Forum' started by ericbecky, Nov 1, 2025.
  1. ericbecky
    ericbecky Hybrid Battery Hero
    4,441
    3,332
    Madison, Wisconsin
    A couple days later I got back to the shop and the goal was to assess whether it was roadworthy enough to bring it to my home.
    I put it up on the lift at the shop. Didn't find any more chewed harnesses, no fluid leaks, or any showstoppers. That said the tires certainly were a little bit questionable, being pretty dry rotted from sitting.
    Scanned the car and found the check engine light was on because of a problem with the driver front wheel speed sensor. I inspected that while I was underneath the car and didn't find any obvious debris or blockage, nor any chewed wires. That would have to be added to the list of things to track down.
    The one thing there was a lot of was spiders and spider webs. A little freaky but I didn't want to mess with it too much because I didn't want them getting all over the shop.
    There was little rust on it for a Wisconsin car, even though it sat so long outside on a concrete parking pad, The underside looked great as far as I was concerned.
    I checked the hybrid battery again just to make sure it really was healthy. Everything looked good so I wrapped up and hopped in for the 26 mile drive home.
    Again, it was a nerve-wracking drive, but at least I felt a little more confident than the initial drive.
    Given all the dirt, grime and mouse debris, I wore my mask on the way home. (So don't judge if you ever see someone driving in a car with a mask on! They have a reason!)
    I made the mistake of turning on the climate control. Oh boy! Chewed up pieces of car insulation, napkins, dust, mouse droppings, etc flew everywhere. Gross! I immediately turned it off and added that to the list of tasks!
    The multifunction touch screen was non-responsive. Added that to the list of tasks to investigate.
    Got a nice massage while driving because the tires definitely had flat spots from sitting so long.
    Arrived home at 5,155 miles and 51 mpg 20251008_121036.jpg 20251008_120008.jpg 20251008_120254.jpg 20251008_123122.jpg Screenshot_20251008_114709_Dr Prius.jpg 20251008_132641.jpg 20251008_135004.jpg
    #41 ericbecky, Nov 9, 2025
    xw20_driver likes this.
  2. ericbecky
    4,441
    3,332
    Madison, Wisconsin
    Nice, but gross. That's a fair assessment when I got home. Because the car had such low miles, much of it on the surface might appear nice. But as soon as you look below the surface, or open the doors and inhaled, it was gross. Really gross. If you've ever come across mouse nests you know what the smell is.
    In these pictures you'll see the mouse nest, and all the black dots are mouse poop.
    I took a bunch of initial pictures of the interesting little features that were still present, like the airbag warning tag, and the written instructions below the CD changer slot.
    The prior owner also included some bags of items from Toyota including oil filters, license plate frame, and other goodies.
    The car had factory cloth floor mats as well as rubber mats for the front driver and passenger footwells.
    As previously mentioned, the exterior was covered with plenty of dirt, grunge, and lichen. I couldn't really tell the condition of the paint other than the clear coat was peeling off the rear spoiler.
    The biggest challenge for this day was when I removed the glove compartment and found the extreme mouse nest jammed in there. I had an initial clean out of it, but I knew I would need to visit this over and over again.
    An interesting side note I forgot to mention. In the morning before picking up this car I happened to meet up with a friend of mine who used to work at the local Toyota dealership. He was helping me with a key for my Nissan Leaf.
    I mentioned to him about this car, because I knew it was serviced at his dealership. Before I even got too many details out, he immediately knew the owner and the car. You certainly remember a unique low mile car like this, especially one that got a $10,000 add-on PHEV system. You see, my friend was one of the very few authorized installers in the country that could install Hymotion systems at a dealership.
    Anyway, he told me a funny story about how one day this car came in for service and when he accessed the rear hatch of the car he noted there was about 300 lb of pennies in the back!? He had to move them around in order to get at the place where he was working on the car. Good thing the springs had been upgraded when the PHEV system was installed!
    I only found a couple of pennies when I did my cleaning, but I did find an empty coin roll paper sleeve for quarters. Fun.
    20251008_152709.jpg 20251008_155721.jpg 20251008_162937.jpg 20251008_162943.jpg 20251008_163145.jpg 20251008_163155.jpg 20251008_153423.jpg 20251008_165119.jpg 20251008_164536.jpg 20251008_155301.jpg
    #42 ericbecky, Nov 9, 2025
  3. ericbecky
    4,441
    3,332
    Madison, Wisconsin
    Since the car ran and drove, next up was checking out the status of the Hymotion PHEV system. I knew I would have to remove it to properly clean the car. I was also pretty sure I didn't want to leave it in there since it's kind of a unique thing that takes up a lot of space.
    Having worked on hybrid cars and EVs for over 20 years I know quite a bit about these systems and have come across them many times. Usually it was to decommission them and remove the system and the wiring harnesses from the customer's car. A rather involved job.
    I figured if the system worked it could be installed into some other enthusiast's car, or if it didn't work it could be dismantled and used as parts for other projects.
    I initially had bypassed the system, because I didn't know whether or not it was safe. I removed the bypass plug and hooked everything back up properly. And started at my assessment.
    Made sure there wasn't any high voltage leak to ground nor any obvious external damage to any of the high voltage wires. I also pressed the inertia reset button. This is a resettable switch that denergizes the system should it ever be involved in some sort of impact. Once that checked out I started up the car and turned the system on.
    The Hymotion system has its own self-diagnostics and reports out any errors via a blinking red LED on the dash.
    I have the installation manual as well as the owner's manual for these systems. And a good chart of what each of the blink codes means.
    Turns out it was flashing six blinks.
    Consulting the chart, it indicated a problem with the battery sub module temperature sensor. So that meant opening up this high voltage pack for closer inspection.
    Once I opened it up, I could clearly see that mice had been inside here as well! I started inspecting the wiring of each sub module and sure enough found one with broken and chewed temperature sensor wires.
    Fortunately, being the nerd I am, I have some old Hymotion modules with the temperature sensors are still attached. I opened up a spare module, set it near the damaged one, and plugged in the spare module's temp sensor into the main system.
    I went to the front of the car, turned on the Hymotion system and everything came to life! No more blinking error codes from the Hymotion system.
    From there I charged up the Hymotion system via the bumper plug. And later drove the car in EV mode with the Hymotion system contributing to the propulsion.
    Amazing.
    A car that sat 12 years, unused and the hybrid battery came back to life, and so did the Hymotion PHEV system. I wouldn't have imagined it was possible.
    20251009_114505.jpg 20251009_115859.jpg 20251009_135015.jpg 20251009_142210.jpg Screenshot_20251009_142324_Photos.jpg 20251009_143404.jpg 20251009_185324.jpg 20251009_144228.jpg
    #43 ericbecky, Nov 9, 2025
    gafortiby likes this.
  4. ericbecky
    4,441
    3,332
    Madison, Wisconsin
    Now that I knew the Hymotion system was working, I took a quick side quest to swap out the Multi-Function Display (MFD) since the touch screen wasn't responding.
    Fortunately from working on hybrids for many years I had a spare MFD sitting around. So I took out the front vents and upper trim work and quickly had the replacement swapped in and working.
    I still had all the rear trim work removed but it was piled up on top of the Hymotion system and main battery in the hatch area. But I would deal with that another day.
    #44 ericbecky, Nov 9, 2025
  5. ericbecky
    4,441
    3,332
    Madison, Wisconsin
    Then the day came to remove the main Hymotion system itself. The batteries and electronics unit. I would leave the actual wiring harness in for a little bit longer since that is a job in itself which involves a lot of reconnecting spliced wires, clipping off where it's tied into other harnesses, etc.
    The system itself weighs about 200 lb. So I was not looking forward to lifting it, but I knew it had to get out of there so I could clean underneath it.
    Again all I can say is, "gross". The rear interior panels that surrounded it had their insulation chewed up and turned into mouse nests. And then the back was used as public restroom for many generations of mice.
    I used my pet odor spray to spray those panels let them soak while I went back inside to eat my Wheaties so that I could lift out the system.
    Removing the system itself was rather uneventful, I managed to get it out myself and set it on an old desk I use as a mobile workbench at times. And then I transferred it to the best rolling cart I had around; an old family kids wagon. That's where it still sits today.
    So if anyone's interested in getting an A123 Hymotion L5 5Wh PHEV system installed in their Gen 2 Prius, give me a call or a private message and we can work something out.
    I sprayed down the other parts of the panels in the rear and let that soak.
    Meanwhile I'd noticed the exterior lichen had caught the attention of folks who walk down my alley. It was hard for them to not pick at the car as they walked by. So I left a nice sign that said Biohazard Do Not Touch on the car. I figured that might deter the casual passerby.
    20251011_150332.jpg 20251011_174251.jpg Screenshot_20251011_150820_Photos.jpg 20251011_134919.jpg 20251011_173912.jpg 20251011_173725.jpg 20251011_180115.jpg 20251011_173813.jpg 20251011_181205.jpg 20251016_111900.jpg 20251011_144219.jpg
    #45 ericbecky, Nov 9, 2025
    gafortiby, ETC(SS) and Prodigyplace like this.
  6. ericbecky
    4,441
    3,332
    Madison, Wisconsin
    I took the Prius to a local shop to get new tires put on. Hankook Kinergy ST. They are a low rolling resistant tire that I've been happy with on other cars of mine in the past.
    This trip added an additional 1 mile to the odometer: 5,156 miles total for those keeping track at home.
    Next up was finding the cause of the front driver side wheel speed sensor error.
    Jacked up the car and took off the wheel. Unbolted the sensor from the knuckle to make sure there wasn't any debris, a cracked sensor, or a damaged ring on the hub. Nope. All that look good.
    So I started following the sensor wire up into the area behind the plastic wheel well cover.
    Ugh. More evidence of mice. The fabric insulation on the backside of the cover was all chewed up and a bit of a nest created. And a little more visual inspection found where the mice had chewed the wires.
    The wire damage wasn't on the sensor side of the harness, it was actually on the car side of the harness. So that meant I'd have to call around to some colleagues to find a parts car I could clip a pigtail off of and splice in. Which I did the next day.
    This repair isn't one for using cheap butt splice connectors. The specific ones I use for this cost about $2 apiece and have integrated shrink tubing on them. Especially important in this high moisture area.
    20251020_155328.jpg 20251020_155505~2.jpg 20251020_155654.jpg 20251020_161428.jpg 20251020_161602.jpg 20251021_184130.jpg 20251022_133534.jpg 20251022_145330.jpg 20251022_145816.jpg 20251102_182048.jpg
    #46 ericbecky, Nov 9, 2025
  7. ericbecky
    4,441
    3,332
    Madison, Wisconsin
    The same day I repaired the speed sensor wires I had another go at the climate control circulation fan behind glove box. Remember the big mouse nest I pulled out from there?
    Well guess what? There was even more!
    Rather than trying to just clean it through the little slot where the cabin filter slides in, I decided to remove the fan housing in its entirety. This made the cleanup much easier.
    After I got it reinstalled, I turned on the fan. I was glad I had my mask on, because once again, chewed up bits of insulation, napkins, etc came blowing out the vents.
    I spent some time turning on and off the system while switching between different vent settings to try to get the debris out of the vents. Once in a while debris would get caught in the vent grates and I'd use a pick and a vacuum to suck the debris loose from where it was lodged. Good times!
    Finally the debris diminished to a small amount, but I guess over time there still could be pieces that work loose every so often.
    20251022_153031.jpg 20251022_153104.jpg 20251022_153150.jpg 20251022_153656.jpg 20251022_161506.jpg 20251022_172018.jpg 20251022_173240.jpg 20251022_173547.jpg
    #47 ericbecky, Nov 9, 2025
  8. ericbecky
    4,441
    3,332
    Madison, Wisconsin
    Next up was to completely empty out the rear of the car from the base of the rear seats all the way back. This means the hybrid battery, the back seats, every single bracket including the one underneath the 12 volt, all the venting, all the trim, and the battery fan.
    This is because each of these items in one way or another were touched by mice and needed to be cleaned up and disinfected.
    I wasn't worried about refurbishing or deodorizing them at this time. I just needed them out.
    Once everything was out, it took most of the day too spray things down and wipe things out. Mask on, gloves on, lots of spray and paper towels.
    When the hybrid battery was removed, since I already knew the electronics were damaged I didn't clean that at all. But I did take a quick look at the battery posts, buss bars, and voltage sensing wiring. I thought it marginal at best, so I set the pack aside and put in an order for new OEM wire frames, new OEM buss bars, new OEM nuts, and new OEM voltage sensing wires.
    20251023_150521.jpg 20251023_150118.jpg 20251023_151543.jpg 20251023_152417.jpg 20251023_153549.jpg 20251023_170111.jpg 20251023_170155.jpg 20251023_170219.jpg 20251023_171914.jpg 20251023_164022.jpg 20251023_154235.jpg 20251023_155113.jpg
    #48 ericbecky, Nov 9, 2025
    gafortiby and xw20_driver like this.
  9. ericbecky
    4,441
    3,332
    Madison, Wisconsin
    Next it was time to tackle the Hymotion system's wiring and decouple it from the stock wiring.
    I went back and looked at my notes from long ago from working on these systems. It had been a few years since I'd had to decommission one. But once I started on it, the memories came back and it was out within a few hours.
    It ties into different places like the computer behind the glove box where it ties into the EV mode white wire. Then behind the power button. Underneath the driver side dash. It continues along the entire driver side of the car underneath plastic trim.
    It ties into the high voltage battery leads as well as the rear tail lights, and the 12 volt battery pack.
    The trickiest places are by the high voltage computer itself, but it's doable.
    In some places the Hymotion harness is simply tapped onto wires and it can simply be clipped off. And other places where wires have been cut and then routed through the main Hymotion harness and back to its regular route. So those needed to be restored. Of course after all this it needs to be wrapped in protective sleeves or electrical tape.
    The Hymotion dash button needs to be removed and unplugged. Added a note to myself too find a dash blank to cover the spot where the switch used to be.
    Under the dash and at the computer behind the glove box those wires simply needed to be capped.
    On all good days work getting the wiring back to stock.
    This should make it so that any future techs that work on the car won't be so confused by all the extra Hymotion wires.
    20251026_104153.jpg 20251026_105501.jpg 20251026_103700.jpg 20251026_110620.jpg 20251026_110744.jpg 20251026_111206.jpg 20251026_112042.jpg 20251026_112348.jpg 20251026_112442.jpg 20251026_113952.jpg 20251026_122816.jpg 20251026_104728.jpg 20251026_114037.jpg
    #49 ericbecky, Nov 9, 2025
  10. ericbecky
    4,441
    3,332
    Madison, Wisconsin
    On October 29th I borrowed an ozone generating machine. I piled the interior trim, metal brackets, etc into the car and I gave it two 15 minute sessions of ozone, with 6-hour breaks in between.
    The next morning I moved everything back out so I could work on refurbishing the brackets.
    As part of the process I also started working on the battery pack, removing the damaged electronics end and replacing it with a spare one I had here.
    In the process, I noticed that the temperature sensor wiring harness for the battery was chewed off and damaged. So I dug up one of those out of my spare parts as well.
    Removed the battery modules from the bottom of the case so that I could clean out everything and replace the temperature sensors. Also put on the new buss bars, wire frames, nuts, and voltage sensing wires. Also replaced the main negative lead and the safety cutoff holder with used ones that were in much better condition.
    As I was reassembling things, I realized I didn't order enough nuts for the battery module posts. So I placed the order and put on some used nuts temporarily so I could start and move the car.
    The brackets themselves were cleaned off with a wire wheel and then spray painted with some rustoleum primer.
    I've attached a photo of how bad the electronics end of the battery pack was. Also a screenshot of the battery data from the Dr. Prius app.
    20251030_092254.jpg 20251027_124020.jpg 20251030_092737.jpg 20251030_102331.jpg 20251030_104742.jpg 20251030_121241.jpg 20251030_121821.jpg 20251030_123308.jpg 20251030_125623.jpg 20251030_130940.jpg 20251030_132647.jpg 20251030_132916.jpg 20251030_145150.jpg 20251030_155553.jpg Screenshot_20251030_150037_Dr Prius.jpg
    #50 ericbecky, Nov 9, 2025
    otatrant likes this.
  11. ericbecky
    4,441
    3,332
    Madison, Wisconsin
    I started November with opening back up the hybrid battery again, and swapping out the remaining used nuts on the battery module posts with the additional new ones I previously had forgotten to order.
    Putting the lid on the hybrid battery I moved back up front to replace the upper glove box lid. I noticed that it had a typical problem where the housing for the hinge cracks, which makes it so that the lid won't open all the way. In addition, the spring starts to slightly raise the dash pad cover. As usual, I had a spare one of those sitting around for just such an occasion.
    After this, I moved on to doing some more documentation of the condition of the engine compartment, interior and exterior. I contacred a detailer to help with additional cleaning tasks and I wanted them to fully understand what they were getting into.
    I did a bunch of additional disassembly under the hood like removing headlights and removing the cowl tray because I wanted to make sure the areas underneath them got cleaned, as well as provide more access to the engine itself for cleanup.
    I apologize if some of these pictures are duplicates from other individual posts.
    A couple other fun things.
    I snapped a picture of the oil change sticker inside the car that matched the online Toyota service records for this car.
    I also grabbed a big chunk of moss that was growing in the windshield wiper area and saved it for later to grow in with some other house plants or something just for fun.
    20251101_115119.jpg 20251101_115125.jpg 20251101_135613.jpg 20251101_135920~2.jpg 20251101_140109~2.jpg 20251101_132020.jpg
    20251101_132212.jpg 20251101_132218.jpg 20251101_132244.jpg 20251101_132256.jpg 20251101_132325.jpg 20251101_132333.jpg 20251101_145342.jpg 20251101_145349.jpg 20251101_151137.jpg 20251101_153622.jpg 20251101_154231.jpg 20251101_154454.jpg 20251101_154537.jpg 20251101_154558.jpg 20251101_154626.jpg 20251101_154729.jpg 20251101_154850.jpg 20251101_132353.jpg 20251101_141358.jpg 20251101_141106.jpg
    #51 ericbecky, Nov 9, 2025
    gafortiby, otatrant and Prodigyplace like this.
  12. ericbecky
    4,441
    3,332
    Madison, Wisconsin
    November 3rd was the first day that the detailer was coming to begin the exterior cleaning.
    I quickly removed the gasket that was still attached to the rear bumper from where the Hymotion system outlet had been affixed
    I took some last-minute pics of the original patina of the car.
    The cleaning was a slow go. Lots of soaking to let the water and soap saturate the dirt, grime, and lichen.
    It was a good first attempt at cleaning with promising, but not complete results.
    20251103_104244.jpg 20251103_104422.jpg 20251103_104752.jpg 20251103_104759.jpg 20251103_104830.jpg 20251103_104837.jpg 20251103_104900.jpg 20251103_105038.jpg 20251103_105129.jpg 20251103_105421.jpg 20251103_115550.jpg 20251103_115734.jpg 20251103_134621.jpg 20251103_141327.jpg 20251103_141343.jpg 20251103_143821.jpg 20251103_143824.jpg 20251103_143840.jpg 20251103_171721.jpg 20251103_171733.jpg
    #52 ericbecky, Nov 9, 2025
    gafortiby and Prodigyplace like this.
  13. ericbecky
    4,441
    3,332
    Madison, Wisconsin
    The detailer came back for a second day and took another shot at the exterior and cleaned more of the interior panels. I had them taken out of the car. In the end I'm not sure if that made things easier or harder.
    I took some pics late in the day after he was gone but things were not fully assembled yet.
    In the evening, I decided to do some more of the work myself on the headlight assemblies and the engine compartment. As well as the hybrid battery fan.
    Late that night I used the dealership's online booking feature to schedule a 7:30 am appointment the next day for its first oil change since awakening from its 12 year slumber.
    I quickly reassembled the rear interior, etc. and went to bed.
    #53 ericbecky, Nov 9, 2025
    gafortiby, Prodigyplace and otatrant like this.
  14. ericbecky
    4,441
    3,332
    Madison, Wisconsin
    Friday, November 7th, 2025 is when the car returned to the dealership of its origin for its first oil change in 12 years.
    I left my house at 5,156 miles.
    This car was sold to the original owner from the very same dealership on August 26th, 2006. First oil change at that same dealership was February 23rd, 2007 at 201 miles.
    It had 13 oil changes since then, the previous one on October 18th, 2013 at 4,889 miles.
    This would be its 14th oil change at 5,180 miles, 191 miles and 12 years since the last oil change.
    As part of the service the dealership did an inspection and found a few thingsthat needed attention. Like the fact that I hadn't replaced the cabin air filter or rear windshield wiper yet. The biggest item of note were that the shocks could need some servicing. So I added that to the list of things to attend to.
    As part of the service, the dealership provided a complimentary Carfax which fully documented this vehicle.
    The recommended 5W30 oil was put in and the total cost of service was $88.88.
    I drove home and arrived with 5,206 miles on the odometer and got 52.2 mpg for the 50 mile round trip.
    I knew it would take a day or so for the service to be reflected in the online Toyota service record. So I waited patiently.
    20251107_065412.jpg Screenshot_20251107_070955_Dr Prius.jpg 20251107_072312.jpg 20251107_073021.jpg 20251107_073028.jpg 20251107_073223.jpg 20251107_073232.jpg 20251107_091231.jpg 20251107_091241.jpg 20251107_094352.jpg 20251102_165015.jpg 20251109_193444.jpg 20251107_094947~2.jpg 20251107_094629.jpg 20251107_094642.jpg
    #54 ericbecky, Nov 9, 2025
  15. ericbecky
    4,441
    3,332
    Madison, Wisconsin
    When I got home from the oil change I did some more inspection under the hood. It was amazing to see how clean it was around the oil cap compared to all the other cars I've ever owned.
    That said, I found that there were still mouse debris remnants that seemed to be magically appearing on top of the engine coverings. Mainly seeds and sunflower hulls.
    I did some investigation and found that there was actually a mouse nest made of insulation inbetween the two layers of metal in the hood. So I started digging that out.
    I also found lots of debris underneath the foam insulation that is attached to the hood. Geez! When will it end?
    20251107_100107.jpg 20251107_100122.jpg 20251107_100133.jpg 20251107_100836.jpg 20251107_112251.jpg 20251107_112340.jpg 20251107_112552.jpg 20251107_112832.jpg 20251107_113012.jpg 20251107_113044.jpg 20251107_113124.jpg
    #55 ericbecky, Nov 9, 2025
  16. ericbecky
    4,441
    3,332
    Madison, Wisconsin
    The next day the oil change was reflected in the online Toyota service record so I grabbed a screenshot. So interesting to see.
    There's still one major area of the car that we had left uncleaned which was the rear hatch surround.
    It was a grungy mess. It also had the typical small separation/gap between the upper and lower panels in the top corners of the opening. This would allow water to get in the car.
    I decided it would much easier to just remove the entire lift gate than to work around it for cleaning and sealing.
    With the help of an assistant we removed the lift gate and set it aside.
    I spent the day cleaning the opening and finally getting to the point where I could give it a final wipe down with degreaser in order to prep it for sealant.
    The 3M degreaser is something I was introduced to at one of my first jobs. We used it for prepping metal to be painted. It's the smell of my youth. It's quite expensive but does a great job.
    By this time we started to have snow flurries. Since the liftgate was off the car, it left the rear exposed to the elements, so I moved the car into the garage.
    I happened to have some roof sealant handy that could be used at low temperatures, so I decided to give it a try. I generally use small spatulas, wooden stir sticks, or a thin flat blade screwdriver in order to spread the sealant around. It wasn't pretty, but I was able to fully seal the leak-prone seams.
    Fortunately, this isn't really an area you notice once the lift gate is reattached. But I won't get to that for a little while.
    It's too cold outside for the next few days so I'll finish cleaning the liftgate itself later in the week.
    Screenshot_20251108_095423_Chrome.jpg 20251108_142029.jpg 20251108_142033.jpg 20251108_142102.jpg 20251108_142112.jpg 20251108_142116.jpg 20251108_142123.jpg 20251108_142140.jpg 20251108_142609.jpg 20251108_142849.jpg 20251108_144003.jpg 20251108_145849~2.jpg 20251108_151032.jpg 20251108_154239.jpg 20251108_154817.jpg 20251108_160911.jpg
    #56 ericbecky, Nov 9, 2025
  17. pasadena_commut
    pasadena_commut Senior Member
    2,662
    790
    Southern California
    Interesting read.
    One caution - a car with that much mouse poop in it is not just stinky, it is a major health hazard. Perhaps slightly less so in your locale than here in California, where we have to worry about hantavirus. Not sure which mask you are using, but N100 or P100 filters with a seal all the way around the face and mouth that tests as no leaks is what you want. The 3M respirator's from a big box store will work for most people. Skinny people with convex areas on the face have a hard time getting a good seal, and facial hair under a seal will make most respirators leak.
    How are you going to disinfect inside the dash? Killing all the possible pathogens often requires wiping down surfaces with bleach or equivalent. Hard to do to the inside of a car's HVAC system. Ozone generators will get rid of the smell (eventually) in cars. I don't know if that method is sufficient to sterilize the innards of the ventilation system though. Ozone is sometimes used for that purpose in buildings, so maybe?
    gafortiby and ericbecky like this.
  18. indel
    indel Member
    136
    49
    Northwest Indiana
    I am late to the party. Just got linked to this thread through reddit.
    Barcelona red being my most favorite color in the Prius, it makes me so sad that the owner ignored the vehicle for so long. If I ever had an opportunity buy a low(er) mileage red from 2nd or 3rd gen, I would restore and use it daily. Never getting rid of it.
    Thanks for taking the time to post so many updates and pictures here.
    ETC(SS), xw20_driver and ericbecky like this.
  19. ericbecky
    4,441
    3,332
    Madison, Wisconsin
    @indel To be honest, I did most of the catch-up documentation posts yesterday, just prior to the Reddit post, so this is the first time most folks have seen the detailed pics and descriptions. Welcome.
    I agree with you about the Barcelona Red. Other favorites of mine are the Habanero (orange) used for the Prius C and the Dark Cherry Pearl (purple) used for the Gen 3 Persona Edition of the Prius.
    #59 ericbecky, Nov 10, 2025
  20. ericbecky
    4,441
    3,332
    Madison, Wisconsin
    Cleaned the rest of the edges of the liftgate and reattached. Did some other cleanup on trim rings, rear wiper arm, air box, and rims.
    Doing another once over on the interior looking for little spots that need touch up cleaning.
    It's really coming together
    And as I was sitting around, here was my random writing to make a sales pitch about the Prius.
    Go back in time...
    Do you remember the first drive in your New Prius?
    Do you remember how it felt to get to 50 mpg that first time?
    Or how fun it was to watch the cool dash animations?
    And how you knew right away the Prius was something special.
    While you can't truly go back in time, you can get that New Prius experience again.
    And this time you'll have all the knowledge from your years of Prius ownership.
    You'll know that the Prius was the most reliable car you've ever owned.
    You'll know that the Prius can easily go the distance. 100,000, 200,000, 300,000 miles...more!
    You'll know that if you take care of the Prius, it will take care of you.
    This is your chance to never miss an oil change.
    Never miss that tire rotation.
    Never miss that semi-annual wax and wash.
    This 2006 Barcelona Red Prius has a nearly-New odometer reading of 5,500 miles.
    That right: Five Thousand Five Hundred.
    Etc , etc, etc....
    20251113_163854.jpg 20251113_163907.jpg 20251113_183918.jpg 20251113_184118.jpg 20251113_185306.jpg 20251113_191319.jpg 20251113_165824.jpg 20251113_170137.jpg 20251113_163858.jpg
