Cannot complete replacement brake booster air bleed procedure
Discussion in 'Gen 3 Prius Technical Discussion' started by George Jung, Oct 31, 2025.
  1. George Jung
    George Jung Junior Member
    Las Vegas Nevada
    Ive tried everything to get the air bleed procedure to complete but it is not working.
    I replaced the master cylinder and abs accumulator a few months ago and have not been able to do the bleed procedure.
    I bought a 50 amp charger, im reading 14 volts when i try to start the procedure and its still not working.
    I got the vxdiag cable. I was trying to use it with techstream 18, Ive now signed up for the toyota two day subscription ands its still not working
    I also have a code for steering angle sensor. I replaced the clock spring with steering angle sensor twice with used oem ones from ebay and steering angle sesnor is still not reading, it always reads 850.5.
    I checked the voltage and resistance checks for the l51 connector that is said to do in the manual, its still not working. Ive attached the DTC's im getting.
    Im so desperate to get this to work, ill do anything, somebody please help.
  2. ASRDogman
    ASRDogman Senior Member
    7,534
    3,892
    50 amps??? OUCH! That is WAY too much for the 12v battery. 5 amps is enough.
    What device are you using for the procedure? Is it an aftermarket techstream cable? If so, that is
    likely your issue. It's common. Some say there is a certain cable to buy to get it to work.
    alteck has a tool, I'm not familiar with it, but others are. I have the D8Tools device that is very good.
    I'll be using it when I do the brake job in the future.
  3. Brian1954
    Brian1954 Senior Member
    2,135
    827
    South Central PA, USA
    Did you buy a new or used part?
  4. George Jung
    Las Vegas Nevada
    New. I've verified it was the correct part number.
    Brian1954 likes this.
  5. George Jung
    Las Vegas Nevada
    I've tried multiple cables. Nex IQ USB link 3 ($800 adapter for heavy duty diesel) , the vxdiag vcx nano, i tried using my friends scan tool, with all of them i immediately get and "air bleeding failed" message when i try to start the procedure. Ive verified that the parking brake switch is showing on, brake pedal switch showing off, etc. I do notice that some of the accelation/deceleration sesnors are displaying a non zero value when the car is stopped and i'm trying to do the procedure? could this be causing it to fail?
    Also i should note that a few months back i had blown the 125a fusible link and bypassed it.. Not sure if that would have any impact because i am reading 14 volts in tech stream not in ready mode when i have the charger connnected.
  6. ASRDogman
    7,534
    3,892
    I seem to remember someone saying the car had to be on, but not ready? I'm not really sure.
    It was a while ago.
    Perhaps search prius chat for that procedure and you'll find the issue.
    A lot of people seem to have a similar issue. Usually it's because of a pirated copy of techstream,
    and/or cable.
    Maybe try it with the parking brake off? Or the opposite of where it is while your bleeding?
    I think you can just do a regular bleed procedure, instead of going through the whole thing again.
    I don't know about the other sensors. But since you have the scan tool, you want to check why
    they are showing zero, and if that is normal or not.
    Obviously, you should check all the wiring to make sure nothing is damaged.
    You can get the Xtool D8 (and now D9) for less than $800.
  7. George Jung
    Las Vegas Nevada
    I've tried everything that's been suggested in previous threads, amd the manual, short of replacing the ABS actuator again, as i just put a brand new one in there a few months ago. I spent the $80 for the two day license and used the official Toyota TIS software or whatever its called now. Ive spent hundreds of dollars on multiple cables and dongles that were said to work by people on here. VXDiag, mongoose, high dollar scanners, etc. I recently bought the TopScan Bluetooth dongle that a person on youtube posted a video using to complete the bleed procedure. This time it actually allowed me to go through the steps, but i didnt hear the pump running at all. Well I would herar it turn on for a split second and stop as I pressed next on each step. I was just getting one burst of brake fluid.
    The pump also performs the same way when i activate one of the ABS relays on the utility menu on Techstream. I Hear it for a split second then it turns off.
    Is there anyway i can do any troubleshooting to verify that a new ABS accumulator will actually fix the problem, because i doubt it. Could it possibly be a bad ECU or something, even though the CANBUS check isn't showing any issues?
    Please somebody help, ill pay for a virtual consultation if they can walk me through troubleshooting my ecu and whatnot with a multimeter.
  8. ChapmanF
    18,050
    If this is a gen 3, the ECU is included in the actuator assembly.
    Didn't see this post earlier. No ouch. 5 amps is on the battery label for a charging current.
    The car is IG ON while you're doing the bleed procedure, and the car's electrical equipment is drawing power. At a Toyota dealer, doing any sort of long procedure where the car has to be IG ON, they'll have something like this hooked up to the battery:
    It won't be set for 'charge' mode, but for 'power supply' mode. It's supporting the power being used by the car, so the 12-volt battery does not lose charge.
  9. ptrustfull
    ptrustfull Junior Member
    Suriname
    2012 Aqua
    I had this problem on a CT200h. There were some fault codes about steering angle sensor and zero point thing. Forgive me for not knowing the exact codes. I purchased a second hand abs module and pump. After replacing the unit i could bleed the system right away. I assume your problem lies in the new unit. Double check the part number
  10. indel
    indel Junior Member
    42
    17
    Northwest Indiana
    Curious about this problem. Following...
  11. rjparker
    10,065
    6,234
    How did you bypass the 125a? Can you post a pic?
    That certainly is not right. There is an "Accumulator Sensor" (accumulator pressure represented in volts) you can graph.
    Based on the attached replacement video, that sensor should start the pump around 3.1v and stop it around 3.8v. One of your techstream screenshots shows it at 3.58v.
    It might help isolate the problem if you know what your pressures are doing.
    Accumulator Sensor 3.1v - 3.8v
    Initial startup after bleeding. Each brake depression causes about 2 seconds of runtime after the first cycle.
    The repair manual pdf on the Accumulator Sensor shows a range under certain conditions of 2.9v-4.2v
    This video fairly comprehensively documents the replacement bleeding and calibrations.
    #11 rjparker, Nov 19, 2025 at 12:52 AM
